phenryiv1 Posted December 30, 2011 Share Posted December 30, 2011 I finally took my 88 Pioneer to have it painted. I am going from Garnet Red to a Chili Pepper Red, so no drastic color change. Anyway, I stripped off pretty much everything that I could take off that seemed reasonable. I removed: Bumpers Body side mounding Headlights/taillights/turn signals "Hockey stick" decals Badges "Jeep" tailgate stickers Over-the-rail bedliner Windshield trim Sill plates Complete grille assembly (had updated to a 3-peice version) Mirrors Wipers Wiper Cowl (replaced the cowl but removed the insert) Much of this stuff is off and will be painted/repainted in John Deere Blitz Black. I left on the truck: Flares Glass Lock cylinders Antenna base Door handles So the truck should be back next week, and I need to try to get things together so ease re-assembly. I found that most of the windshield clips cracked, and I was not really keen on the metal trim as it is. I read on here and other sites that I can either replace the clips and re-install the windshield OOOOORRRRRRR, I can try to install the rubber weatherstrip from a 95+ XJ. Some links talk about having to have the windshield out to do it. Others talk about having to grind off the tabs that hold the clips in place. I can't seem to get a straight answer. Can someone shed some light on the subject? CC link to past discussion: viewtopic.php?f=2&t=15224&view=next (By the way, the CC SEARCH function was not working when I made this post...I found that link through a Google Search. Please excuse if I missed some obvious CC threads.) Link to the rubber weatherstripping: http://www.teamcherokee.com/Weatherstrip/index.html (Last entry) Do I just press-fit the new rubber weatherstripping, or does it need to be glued in place? Can it be installed without removing the windshield? If I can't go with the rubber weatherstripping option, is there a trick to re-installing ther clips? They had an "L" bend that made it seem like there was no way to get them onto (or off of, for that matter) the tabs without breaking them. And can they be bought at a place like Fastenal? I also need a lot of the speed clips- the ones from the taillights, the front bumpers (those big ones), etc. Any suggestions on where to get them? I tried the automotive fasteners section at Lowes but they had nothing of the sort...at least not tin the proper sizes. Thanks in advance for any help that people can offer. Edit: Post day 1 teardown pics: Link to comment Share on other sites More sharing options...
Akula69 Posted December 30, 2011 Share Posted December 30, 2011 I am also going to switch to the later-model trim when we replace the windshield in the '89. As stated in the link you referenced, I expect to grind down the tabs for the old trim clips, and I will coat them with the zinc rust preventitive. As far as the new trim needing the windshield out - all I have read says this is not necessary and I realize the urethane only holds the glass (and the trim gets "glued" to the outer surface), but I can't help but believe that the fresh urethane (with the windshield replaced) will help hold the bottom edge of the trim in. Get you spped clips at NAPA or Auto Zone. Quantity in pack depends on size. Link to comment Share on other sites More sharing options...
Jeep Driver Posted December 31, 2011 Share Posted December 31, 2011 A good automotive paint store will have the trim clips and blind nuts.........or Fastenal for the blind nuts. If it were me..........I'd spend the $227 at Safelite and have them install a new windshield with the seal you want and be done with it, beats screwing up a new paint job or gooobering it up with sealant. Link to comment Share on other sites More sharing options...
phenryiv1 Posted January 2, 2012 Author Share Posted January 2, 2012 A good automotive paint store will have the trim clips and blind nuts.........or Fastenal for the blind nuts. If it were me..........I'd spend the $227 at Safelite and have them install a new windshield with the seal you want and be done with it, beats screwing up a new paint job or gooobering it up with sealant. The problem is that I'd still have to grind off all of the tabs that hold the OEM windshield clips in place. Is it possible to mark the location of the tabs and notch the rubber trim to fit around the tabs? Since the trim is just...well, trim...I was thinking that I could cut out where the OEM mounting tabs are located and could slide the rubber trim in place without having the tabs put too much pressure on the windshield at the tab locations. Thoughts? Link to comment Share on other sites More sharing options...
yellaheep Posted January 2, 2012 Share Posted January 2, 2012 Don't get hung up about cutting off those trim clips. You won't be needing or wanting to go back to that damn metal trim ever again. I've replaced ALL of my XJ/MJ project vehicle's windshields using the rubber trim. Definitely a better idea to install it correctly - cutting off the inner part of the trim that normally goes around the glass to hold it in place just makes attaching the outter part of the trim more difficult and ya have to use way too much of that gooey glue to hold it in place. Makes replacing the windshield a much more difficult job having to cut through and then clean out all that glue. You can order the pinch nut/clip fasteners from Fastenal. Haven't found a real cheap source but they'll have 'em. The local Ace Hardware stores around here carry the "specialty" fasteners in plastic drawer/bin boxes - sometimes you have to ask as they may keep these locked up to keep folks from running off with the pricey little things....... Link to comment Share on other sites More sharing options...
phenryiv1 Posted January 2, 2012 Author Share Posted January 2, 2012 Don't get hung up about cutting off those trim clips. You won't be needing or wanting to go back to that damn metal trim ever again. I've replaced ALL of my XJ/MJ project vehicle's windshields using the rubber trim. Definitely a better idea to install it correctly - cutting off the inner part of the trim that normally goes around the glass to hold it in place just makes attaching the outter part of the trim more difficult and ya have to use way too much of that gooey glue to hold it in place. Makes replacing the windshield a much more difficult job having to cut through and then clean out all that glue. You can order the pinch nut/clip fasteners from Fastenal. Haven't found a real cheap source but they'll have 'em. The local Ace Hardware stores around here carry the "specialty" fasteners in plastic drawer/bin boxes - sometimes you have to ask as they may keep these locked up to keep folks from running off with the pricey little things....... It isn't that I am afraid that I'll want to go back...it is that I will be taking a grinder to my freshly-painted truck. Plus I'll be dropping another few hundred dollars on a windshield to replace a perfectly-functional windshield. Had I thoight of the windshield issue before, I'd have dealt with the tabs BEFORE it went to paint. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted January 3, 2012 Share Posted January 3, 2012 If it were me..........I'd spend the $227 at Safelite and have them install a new windshield with the seal you want and be done with it, beats screwing up a new paint job or gooobering it up with sealant. ...and then if anything gets goobered or damaged, it's on them. That is a good price, even if they charged $25 or so extra for the rubber. Link to comment Share on other sites More sharing options...
yellaheep Posted January 3, 2012 Share Posted January 3, 2012 Use a dremel with a cut off wheel. Not a grinder. I'm sure you know someone who has a Dremel if you don't have one - they make short, easy work of removing those pins. They'll knock out easy too using a flat blade screwdriver and small hammer. Just give 'em a couple of moderate taps and they'll pop out. The windshield sealant can be used to cover the holes just fine. Link to comment Share on other sites More sharing options...
64 Cheyenne Posted January 3, 2012 Share Posted January 3, 2012 This is my DIY: viewtopic.php?f=9&t=32365 Worked out OK, only difference I will do next time is to not be cheap and spend the coin for automotive grade quick cure sealant. (took a long time for the urethane curing smell to go away from the inside of my truck) and the other change would be to put the sealant on the truck, then install the glass to the sealant that is already on the truck. Or as others have said, let the pros do it :wall: but that is another story as told in Mary Jane. Link to comment Share on other sites More sharing options...
64 Cheyenne Posted January 3, 2012 Share Posted January 3, 2012 Quote: "It isn't that I am afraid that I'll want to go back...it is that I will be taking a grinder to my freshly-painted truck. Plus I'll be dropping another few hundred dollars on a windshield to replace a perfectly-functional windshield. Had I thoight of the windshield issue before, I'd have dealt with the tabs BEFORE it went to paint." BTW I see you have a garage...(could warm the garage and gasket sealant to make removal easy) myself, I would remove the sides and top of the old WS glue/gasket with the HF tool, then cut the bottom with a bicycle cable as seen in this other DIY post: viewtopic.php?f=9&t=19487&hilit=slider+replacement Or let the pros do it..... Me, I'm short on funds so I got a brain that lets me do things cheaper in cash but usually costs me more in the long run with time. Indian injunuity! Link to comment Share on other sites More sharing options...
phenryiv1 Posted January 3, 2012 Author Share Posted January 3, 2012 Thanks for the tips above. My stupidity for not thinking far enough ahead and dealing with this while I was stripping the truck. I do have a dremel with a cutoff wheel, so that may be the easiest option. I don't mind getting a new windshield (I am already sinking way more $$$$ into this than its monetary value, but the truck has tremendous sentimental value, so while it isn't that money is no object, I don't have to worry about recouping my costs in dollars somewhere down the road. Also, as the MJ is not my daily driver, I have the luxury of time. I don't have to do anything with it right now. Link to comment Share on other sites More sharing options...
phenryiv1 Posted January 4, 2012 Author Share Posted January 4, 2012 Some early shots from stopping by to see the truck yesterday: Link to comment Share on other sites More sharing options...
Jeep Driver Posted January 4, 2012 Share Posted January 4, 2012 Wow, looks nice. How much did the paint job set you back? Link to comment Share on other sites More sharing options...
phenryiv1 Posted January 4, 2012 Author Share Posted January 4, 2012 Wow, looks nice. How much did the paint job set you back? With me doing nearly all of the prep work (save for 1 small spot of rust near the taillight that I wanted them to handle) and all of the teardown, I paid $850 for the paint and the application of the paint. I still have to do all of the reassembly, including purchasing all of the parts that I need to replace like clips and fasteners. Had I had them do it, I don't even want to know what they'd have charged. I had about 20 hours total in the removal of the decals, emblems, adhesives, trim, the accessory teardown, and the sanding. I wish that I had paid more attention to some smaller dings that were nearly invisible with the dull paint but are now pretty obvious. Link to comment Share on other sites More sharing options...
knever3 Posted January 4, 2012 Share Posted January 4, 2012 Looks nice. :cheers: Link to comment Share on other sites More sharing options...
vaquaro Posted January 5, 2012 Share Posted January 5, 2012 Great color , looks fantastic :thumbsup: Link to comment Share on other sites More sharing options...
phenryiv1 Posted January 5, 2012 Author Share Posted January 5, 2012 What is the best way to remove all of the old adhesive tape from the body side molding? Link to comment Share on other sites More sharing options...
phenryiv1 Posted January 9, 2012 Author Share Posted January 9, 2012 Washed a bunch of the small parts (in the dishwasher) to degreaes them for paint: And the results of the paint job, plus a partial reassembly. I used Krylon (the stuff for plastics) satin black spray bombs for the trim pieces. They turned out pretty good for a spraybomb job done in mid-40s weather. Link to comment Share on other sites More sharing options...
