skidoo_j Posted November 6, 2011 Share Posted November 6, 2011 I've recently decided to rid my self of the stubborn plastic tank. I found a prior thread covering using a Mac Brand expansion tank, pics from that post at bottom. http://macsradiator.com/shop/surge-overflow-tanks/replacment-jeep-radiator-fill-tanks.html I have previously replaced all the hoses trying to fix my leaking issue and now comes my problem. I cannot find the tee Item number 8 in the photo and searching the factory part number on google produced nothing. I found the heater valve (Item 3) at both napa and autozone, but no tee. I found a company that sells all the hoses and the tee but not just the tee. http://www.teamgrandwagoneer.com/parts/Detailed/1763.html ANY HELP would be appreciated... Also I'm wondering if anyone knows where I can pick up a new 2.5L expansion tank new. Or am i better of just using a universal tank for the conversion? http://comancheclub.com/forums/viewtopi ... 8&start=15 Here's some pictures for ya. Dave Edit::: I ended up replacing the J shaped tee with a Brass Pex Tee from local hardware. The hoses are 5/8" and a 5/8" barb tee was not available except in plastic. Pex is the flexible water pipe that they are using to replace copper. Link to comment Share on other sites More sharing options...
fiatslug87 Posted November 6, 2011 Share Posted November 6, 2011 Probably dealer only (if they still carry them) or at the junk yard for the tee. I've done this to mine and prefer the 2.5L overflow to a universal. It fits along the fender but the fuel pump resistor and the EGR solenoid(?) need relocation. I've always picked up the overflow at the JY, no help on getting one new. Seen used ones on eBay but usually pricey compared to JY. Link to comment Share on other sites More sharing options...
skidoo_j Posted November 7, 2011 Author Share Posted November 7, 2011 I contacted the dealer today. It's cheaper to buy all the hoses and the Tee from wrangler parts online then to order the tee. $46 dollars plus shipping at the dealer... Link to comment Share on other sites More sharing options...
gl1200aman Posted November 7, 2011 Share Posted November 7, 2011 The original tee had compression type clamps connecting the hoses. It never has reusable clamps. Link to comment Share on other sites More sharing options...
hick92 Posted November 7, 2011 Share Posted November 7, 2011 The original tee had compression type clamps connecting the hoses. It never has reusable clamps. why can't you use a normal hose clamp i did this for my fuel line and i double clamped the ends so it would hold Link to comment Share on other sites More sharing options...
skidoo_j Posted November 7, 2011 Author Share Posted November 7, 2011 I had cut off the compression style and was using hose clamps on the barbed end that is there, however after all the years the ends have deteriorated and i'm afraid if i tighten the clamps anymore the tee will collapse. Link to comment Share on other sites More sharing options...
hick92 Posted November 7, 2011 Share Posted November 7, 2011 oh ok i understand maybe i can find you one thats in good condition at the local junkyard Link to comment Share on other sites More sharing options...
skidoo_j Posted November 7, 2011 Author Share Posted November 7, 2011 That would be awesome. I don't' have a pick and pull near me anymore. I recently moved. :( Link to comment Share on other sites More sharing options...
PIKE Posted November 11, 2011 Share Posted November 11, 2011 I have switched from a universal expansion tank to the OEM 2.5 tank. Part# 52003213 It works much better. You will also need the cap. I don't have that part number. :cheers: Link to comment Share on other sites More sharing options...
skidoo_j Posted November 11, 2011 Author Share Posted November 11, 2011 I have switched from a universal expansion tank to the OEM 2.5 tank.Part# 52003213 It works much better. You will also need the cap. I don't have that part number. :cheers: Why? Because it holds more fluid? Looks? You have to relocate the fuel resistor, the fan relay and the egr control right? Link to comment Share on other sites More sharing options...
PIKE Posted November 11, 2011 Share Posted November 11, 2011 Yes holds more fluid, better quality, it doesn't leak, and the mounting holes are all right there. You can see where I relocated the fuel pump resistor. The EGR is long gone. Link to comment Share on other sites More sharing options...
skidoo_j Posted November 12, 2011 Author Share Posted November 12, 2011 egr long gone? did you just plug the port on the intake? or did you remove the valve too and make a block of plate there? I swapped my header out to day for one of the dyno max black jacks and the egr tube is a pain in the a$$ and it is now what is leaking. Link to comment Share on other sites More sharing options...
sinkrun Posted November 13, 2011 Share Posted November 13, 2011 I have the same universal overflow on the same conversion. It seems to blow fluid out the top of the lid since it has cut outs in it and I have to add fluid every so often. I like this upgrade with the factory tank I will be looking for one let me know if you find where to get it. Link to comment Share on other sites More sharing options...
skidoo_j Posted November 13, 2011 Author Share Posted November 13, 2011 the tank is about $16 from anyone that sells crown products so like jeepparts.com quadratec rusty's etc. problems is i can't find any of them that sell the cap and i don't know if the cap comes with the new one, or if a generic cap from napa or autozone will work with the tank.. Link to comment Share on other sites More sharing options...
skidoo_j Posted November 14, 2011 Author Share Posted November 14, 2011 I have switched from a universal expansion tank to the OEM 2.5 tank.Part# 52003213 It works much better. You will also need the cap. I don't have that part number. :cheers: any idea where you got the cap? Crown does not list one... I called them directly and they told me they don't make a cap for it... I contacted quadratec and they don't have a clue because they have all the parts direct shipped from crown. Link to comment Share on other sites More sharing options...
skidoo_j Posted November 18, 2011 Author Share Posted November 18, 2011 I contacted my Local Jeep dealer today and they said the cap is nolonger an available item to order. I then found this company tuttle click crhrysler they list it. I've emailed them for availability, but $8 for a cap plus shipping is kinda steep!!! Link to comment Share on other sites More sharing options...
fiatslug87 Posted November 19, 2011 Share Posted November 19, 2011 I've seen caps that look similar to the originals (black with orange lettering) at O'Reilly Auto Parts. I'll get one tomorrow and let you know if it fits. Looks lik this. http://m.summitracing.com/parts/RNB-82594 Link to comment Share on other sites More sharing options...
skidoo_j Posted November 19, 2011 Author Share Posted November 19, 2011 I would really appreciate that. I'll order a new tank tomorrow if you can confirm the cap by dorman fits :) I figure something like this is out there because crown makes the tank and not a cap, so someone must make the cap. After all if your tank rots out odds are the cap is bad too. I unfortunately do not have the tank or the cap to go to the parts stores to mate up. Thanks again Link to comment Share on other sites More sharing options...
fiatslug87 Posted November 19, 2011 Share Posted November 19, 2011 Just got one, it fits perfectly, looks identical to OEM. Dorman number as above. Or you can try this: :yes: Link to comment Share on other sites More sharing options...
skidoo_j Posted November 19, 2011 Author Share Posted November 19, 2011 I actually did that with a milk jug. It just didnt want to stay in place very well Link to comment Share on other sites More sharing options...
skidoo_j Posted December 2, 2011 Author Share Posted December 2, 2011 quadratec had some issues with their inventory and for some reason sent me part 52003130 the power steering res. Keith at quadratec is working diligently to rectify it. Apparently they had several that were mis-marked and he is now locating the correct one to ship out. They have good cust service so far. will post once resolved. Link to comment Share on other sites More sharing options...
skidoo_j Posted December 3, 2011 Author Share Posted December 3, 2011 I guess it feels nice to help quadratec fix their issue of inventory and for them to correct their picture of products, but I didnt get a call back and don't know what I'm looking at for a lead time, atleast the truck can run with out it. Link to comment Share on other sites More sharing options...
skidoo_j Posted December 9, 2011 Author Share Posted December 9, 2011 I'm still waiting on resolve from quadratec. They tell me that Crown Automotive sent them the Power steering res with the coolant bottle part number hand written on it. I contacted Crown in Nevada and they said they've had no such complaints or issues... Called quadratec back today, now a full week from when I notified them of the issue and no solutions. I was told that they have 3 people working on it at crown. Now I've got quadratec's Crown Automotive sales rep name and number. He had today off What a headache for a coolant bottle. I had to drive the truck so now the overflow hose is just dumping on the ground. Link to comment Share on other sites More sharing options...
skidoo_j Posted December 14, 2011 Author Share Posted December 14, 2011 Rounding into two weeks with no resolve from quadratec / crown... Tomorrow I plan to call crown directly. Link to comment Share on other sites More sharing options...
skidoo_j Posted December 21, 2011 Author Share Posted December 21, 2011 On monday the 19th I spoke with quadratec again. They seemed to be in the same position they were 17 days prior. So I sent an email to Crown regarding my issue. With in 30 minutes I had an email back from crown clarifying that they are not the direct suppliers to quadratec for the bottle I had ordered. They stated they had plenty in stock and had no such issues. He also carbon copied the email to 4 people at quadratec including, two managers. Needless to say by 2 that same day I received notification of shipment. Fingers are crossed that they didn't just send me another power steering reservoir. Link to comment Share on other sites More sharing options...
