OK, I'm looking at the final numbers for my front axle- how does running 64" width front and rear strike you guys?
9" of lift, 5.83 gears, 38" tires, 5 on 5.5", 1/2 ton knuckles
It's a Ford 9" front and Ford 9" rear. That's "wheel mounting surface to wheel mounting surface", which he explained was the outside of the brake roter.
:drool: drop-out-third-members :drool:
Hugging tree is cool if you are an enviromentalist :nanner: It all boils down to what and where you wheel. If you do a lot of trail riding... narrow is ideal, and so is a shorter whel base :brows: but if you rock rawl and have larger tires it is all about stance and being stable, so being wide is your friend
64" is a good width. But, I would make the front wider than the rear. Say 66" or 67" and the rear 64". Or make the front 64" and the rear 62". It helps when trying to get around a tree or rock when on the trail. Most one ton axles (full width) are this way. If you ask around, axle shops etc., they will confirm that most people who custom order or build axles go this route.
just my 2 cents again.
Width is a matter of preferance. Mine is 67" wms to wms.
But why limit yourself to 1/2 ton knuckles if your having custom axel houseings built ???? If your spending that amount of cash on a custom 9" front why would you use 1/2 ton stuff.....go with D60 outters , 35 spline Detroit Locker , 35 spline inner + outter shafts , ORD 5 bolt conversion hubs with Warn drive flanges.
If your only useing 1/2 ton stuff , save your cash and swap a stock HP D44 Ford front under it. I run 36's on my HP D44 with 4.88's locked , and only pop u-joints once in awhile......I always have spare axel shafts with me.
Not tryin to be negative......but your not gaining anything if you use D44 outters on your 9".....it's just money wasted for nothing.
Yeah I was wondering about that. It's a 2.5L so my weak link should be stalling the engine. Problem is there is like a 150% price jump between using 1/2 ton outers and 1 ton and that breaks me.
Then you start to wonder about the logic of putting all that money into a rust bucket MJ that was free, or at least I do. But the front axle is the one place I had budget and I thought matched 9" axles would be very cool - the real question should be maybe if it is worth having a front 9" 1/2 ton over a ford HP 44...
Short answer is it's not.
The 9" is a really killer strong gearset with plenty of options. But, with both the HP or LP D44 the weakness is the outer stub shafts as they have to neck down to accomodate the hubs (they're like, 19 spline..). EDIT: This is with a built D44. IE, my setup with a spool/chromos/superiors and drive flanges would qualify. You'd be running these same stubs with the 9" setup with half ton outers; so again they'd be the weak link.
I'd get a junkyard HPD44, or even a LP one (hey I did that!) or spend the dough now and get the 1-ton outers.
Oh, the 1-ton stuff, would it be kingpin?
Yup that's exactly what we're doing. My friend who's finishing the build back in Indiana is going to look for an F250 front D44 and we're cutting down to 63" WMS-WMS and a Ford 9" is going in the back, cut down to 61" with discs and a drain plug.
We considered an early bronco Front D44 but at 60" we're talking wheel spacers and a 60" back maximum...
As for gears I'm going with 5.89 in the front and 5.83 in the rear which is about 1% difference.
I'm skipping the D60 because of raw weight issues, plus the 9" in the rear is a bargin for me and I don't want D60 front and 9" rear.
the local shop up the street is trying to get rid of some unimog portals.. wanted me to buy them for the MJ :nuts: haha, he doesnt want them in his shop anymore. BUY THOSE!!!!
Mogs aren't the inital price thing... They get you later. Pinion conversion, brakes, narrowing or dealing with clearance issues...
Actually, what you can do, is use a stock axle, say D44 & D60, and adapt just the portal hubs to the axle... Rob Bryce (Exact Engineering) did that for one of his customers.. He did it on a D30 front end with 3.08 gears in the diff. It was for a rock buggy. No need to go any bigger as all the gear reduction is in the portal. Of course the housing was heavily trussed....
Its an idea...
Ryan
I'd wonder how much wound up being in it. I guess it would be as easy as narrowing an axle other than the outer stubs would probably have to be splined 'differently' which ultimately would probably lead to all new shafts. That's assuming that mogs don't use a closed knuckle CV or anything like that - I'll admit I know little about them.
That still leaves the brakes/bolt pattern too. Although, one can run what's there. But I'm not into 20" rims and 4-wheel drum brakes.
It does make me think though. Unfortunatly the Canadian military won't be surplussing mogs or their parts anytime soon. Or maybe that's for the better that they don't.
