Andy Posted September 2, 2011 Posted September 2, 2011 Hey, I know there are a couple of other forum posts on here about this - but I wondering if anyone has any fresh information. I need to find a new MAT sensor for my '88 Comanche and I'm hitting walls everywhere I go - I've checked all the online places mentioned on here (Rockauto, Tomco, Standard) along with all the local part stores and dealers, everyone tells me that it's no longer available. Any tips you can give me would be appreciated, thanks.
Akula69 Posted September 2, 2011 Posted September 2, 2011 Unfortunately I was unable to find one either and resorted to collecting 2 or 3 at the JY and using one that worked.
sinkrun Posted September 2, 2011 Posted September 2, 2011 Which one is the MAT I have a couple motors going to junk soon and am pulling anything usable from them.
Akula69 Posted September 2, 2011 Posted September 2, 2011 The rear of the manifold. As you stand at the fromt of the engine its the second from the right rear. Has a two wire harness that comes out the top.
HOrnbrod Posted September 3, 2011 Posted September 3, 2011 These are all aftermarket direct replacements for the Renix MAT sensor, CHRYSLER 33002382 AIRTEX 5S1004 AUTO-TUNE PT9599 BIG A 53-1009 BORG WARNER WT5502 CHRYSLER 33002382 ECHLIN TS5016 FILKO CS-62 GP/SORENSEN 779-19015 KEM 139-411 NAPA TS5016 NIEHOFF TS81351 NIEHOFF WA629EL STANDARD/HYGRADE AX9 TOMCO 12120 WELLS SU330
Akula69 Posted September 3, 2011 Posted September 3, 2011 Thanks for that info Don. I need to look some of those up becasue the only after market ones I have seen no longer have the pigtail harness on them, just a plug molded into the top of the sensor. The corresponding attachment on my engine bay harnesss will not reach the MAT sensor unless it has the pigtail on it :(
HOrnbrod Posted September 3, 2011 Posted September 3, 2011 After I posted the cross reference list, I did look all of them up. Couldn't find any of them. :( Weird...............
MJRemi Posted September 3, 2011 Posted September 3, 2011 TeamCherokee carries them under "Engine-Electric". Hopefully it's a complete set up.
Andy Posted September 6, 2011 Author Posted September 6, 2011 Thanks for the ideas, I did find that sensor on TeamCherokee (Intake Air Temp Sensor #17221.01) - but it specifies that is is for 1991-96 models only. I'm not really sure what the difference is but I want to make sure that it will work with my Renix system. I'll give them a call and see what they have to say - if that's a dead end I guess I'll start going through junk yards too.
tj21 Posted September 30, 2011 Posted September 30, 2011 Did you have any luck finding a new mat sensor? I've been struggling with this same issue.
RDAN1 Posted November 23, 2011 Posted November 23, 2011 Did you have any luck finding a new mat sensor? I've been struggling with this same issue. Has anyone located a source for the Renix era MAT sensors other than JY's ????
Jeep Driver Posted November 23, 2011 Posted November 23, 2011 viewtopic.php?f=2&t=33023 Is this what you are talking about here?
RDAN1 Posted November 23, 2011 Posted November 23, 2011 http://www.comancheclub.com/forums/viewtopic.php?f=2&t=33023 Is this what you are talking about here? Yes. Does the one you used also work on a Renix 4.0 ?
Jeep Driver Posted November 24, 2011 Posted November 24, 2011 http://www.comancheclub.com/forums/viewtopic.php?f=2&t=33023 Is this what you are talking about here? Yes. Does the one you used also work on a Renix 4.0 ? There are two versions I found.........1/4 NPT or 3/8 NPT. You need to figure out what you have. Advanced Auto has the BW 'big' book they should be able to find the related 3/8 NPT one if that's the one you have.
