GirsMJ86 Posted December 16, 2005 Share Posted December 16, 2005 does anyone know the horsepower and torque specs for the 2.8L v6 engine in the 86 comanches? help would be great. thx alot. Link to comment Share on other sites More sharing options...
DirtyComanche Posted December 16, 2005 Share Posted December 16, 2005 GM 2.8L V6 - 115 hp @ 4800 rpm, 145 ft lb @ 2400 rpm Link to comment Share on other sites More sharing options...
GirsMJ86 Posted December 16, 2005 Author Share Posted December 16, 2005 hey thx alot been lookin for that info everywhere and couldnt find it. Link to comment Share on other sites More sharing options...
Pete M Posted December 16, 2005 Share Posted December 16, 2005 Less than a swapped-in 3.4L. :D Jeep on! --Pete Link to comment Share on other sites More sharing options...
whowey Posted December 16, 2005 Share Posted December 16, 2005 I was gonna say bad hp@worse RPM and Awful ft.lbs.@Even Worse RPM Link to comment Share on other sites More sharing options...
GirsMJ86 Posted December 19, 2005 Author Share Posted December 19, 2005 well all of you are right about the crap factor of this engine but its what i got stuck with if i wanted a 4x4 comanche. I'm gonna do an engine swap asap. if any of you have any good ideas on an engine to put in it with out any body cutting or anything it would help alot. Link to comment Share on other sites More sharing options...
DirtyComanche Posted December 19, 2005 Share Posted December 19, 2005 The only 'easy' swap is the 3.4. It's a pretty good motor though. You could throw just about anything in there, but it might get touchy. If you wanted to swap a 4.0 you'll need a donor vehicle (pretty much) as you'll need the tranny as well, and the radiator and supports, along with a bunch of fuel system stuff and all the electrical. There's a thread on that here somewhere. Link to comment Share on other sites More sharing options...
pingpong Posted December 19, 2005 Share Posted December 19, 2005 The 2.8 while a dog, can be a pretty long running motor, if taken care of. I had a S-10 with one, and when I sold it, it had 200,000 showing, and the guy I sold it o drove it another yr beore he sold it, and the person he sold it to is still driving it, and that was almost 3yrs ago. Rebuilding what you have wil be far easier and cheaper then swapping in another motor, unless you use a 3.4 and your current fuel system. If you change any of that you can start getting into big money. So keep that in mind. Patrick Link to comment Share on other sites More sharing options...
whowey Posted December 19, 2005 Share Posted December 19, 2005 The 2.8 while a dog, can be a pretty long running motor, if taken care of. I had a S-10 with one, and when I sold it, it had 200,000 showing, and the guy I sold it o drove it another yr beore he sold it, and the person he sold it to is still driving it, and that was almost 3yrs ago. Patrick Depending on the year of the S-10, you probably have the 'later' version of the 2.8l. GM dumped the earlier version onto AMC, and used the later one in its own vehicles. The later version solves alot of the longetivity issues with the motor. The craptastic carb though is really the culprit for the problems with power. Link to comment Share on other sites More sharing options...
pingpong Posted December 20, 2005 Share Posted December 20, 2005 Mine had a throttle body so I guess it was a later version. It was n't the most powerful motor, but the 3.73 gears in it did make it kinda peppy for a V-6. Also they were not GM's best motors either. They also had transmision issues. I got rid of the truck cause the whole front end needed to be rebuilt, it just wasnt worth spending 200 in parts just to have a vehicle with 200,000 miles on it, when I traded it for an Old firedepartment K-5 Blazer that had only 43,000 original miles on it :shock: :D Patrick Link to comment Share on other sites More sharing options...
GirsMJ86 Posted December 21, 2005 Author Share Posted December 21, 2005 thx for the talk on the motors its helpin out on options a bunch. ill keep all this in mind but the engine probly won't get much done to it for about a year or so. so whatever else you can put out there keep it comin. Link to comment Share on other sites More sharing options...
Eagle Posted December 24, 2005 Share Posted December 24, 2005 Keep in mind that a '91 or newer Jeep 2.5L 4-cyl with the MPFI puts out more horsepower and more torque than the 2.8L V6. The 3.4L GM V6 is a direct bolt-in, but the 2.5L is also a drop-in. Link to comment Share on other sites More sharing options...
GirsMJ86 Posted December 24, 2005 Author Share Posted December 24, 2005 alright hey thanks ill talk that over with my bud who is helping me restore this thing and see what he thinks. Link to comment Share on other sites More sharing options...
