Goodyear Duratracs
My son has them on his Grand Cherokee. Lots of road noise. I had to pick his truck up from the airport the other day and needed to drive it about 45 miles. :eek:
I would imagine they would be louder on a Comanche than a Grand Cherokee.
Well I did dynamat the entire floor and back of the cab with some butyl sound deadener stuff :) :) jamminz.gif
I am not that concerned about sound because I'll be adding more sound insulation to the floor and cab corners up to the headliner plus headliner insulation. What I want to know is whether they run true and track well. I've had lots of really well made Goodyears and lots of really poopy ones and even some that were completely out of round. I am obviously only going to buy tires made in :USAflag: but it doesn't have to be the Duratrac. I've had tons of BFG MT's and they aren't siped you literally slide in any wet condition. I've had SSR's and they are siped and stop well but they are too much for what I'll be doing with my MJ.
All of our small fleet vehicles at the steel mine I work at have Duratracs on them. These trucks never see pavement and are around sharp blast rock and are spinning and pounded through potholes all the time. I never knew how much performance you can get outa a 2wd f-250 with a v8 when its not yours :rotf:
The tires hold up very well and do not fail till they have no tread left. They run a 235/85/16 size in load range E. I plan to get them for my 88 2wd MJ and mount them to Mamba 16in wheels.
Okay, let me put it to you this way. That Grand Cherokee is pretty quite. I could not imagine putting these tires on a Comanche especially if you need to drive the highway a lot.
