JCole Posted February 19, 2011 Share Posted February 19, 2011 Would you guys post some pics of your soa setups. My truck is a on road 90% of the time type of truck, I have a dana 35 in the rear of my 89 sb 4x4 comanche. My new dana 35 is out of a cherokee. Here are my questions.. Where did you get your perches? I want the weld on ones. Was spring wrap a problem? How did you fix it, if it was? What did you do for shock mounts? Pics would be awesome..... Thanks guys Link to comment Share on other sites More sharing options...
johnnyc Posted February 19, 2011 Share Posted February 19, 2011 IIRC, I got the spring perches and shock mounts from Ruffstuff. Link to comment Share on other sites More sharing options...
JCole Posted February 19, 2011 Author Share Posted February 19, 2011 IIRC, I got the spring perches and shock mounts from Ruffstuff. Do you have any issues with spring wrap? Link to comment Share on other sites More sharing options...
mnkyboy Posted February 19, 2011 Share Posted February 19, 2011 Longer perches will help with axle wrap,my perches are 7-8" long and I have little to no axle wrap. Link to comment Share on other sites More sharing options...
Automan2164 Posted February 19, 2011 Share Posted February 19, 2011 Hornbrod got his perches from Mopar, and they ended up being long. IIRC, he said they worked great, and weren't that expensive. Rob L. Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 19, 2011 Share Posted February 19, 2011 http://www.jegs.com/i/Mopar%20Performance/312/P4120074/10002/-1?CT=999 Link to comment Share on other sites More sharing options...
mjeff87 Posted February 19, 2011 Share Posted February 19, 2011 ^^^I used the same ones but.... if you're going to put them on a D35, the tube OD may be a bit too small for those to fit without building up a lot of weld material. Jeff Image Not Found Link to comment Share on other sites More sharing options...
Pete M Posted February 19, 2011 Share Posted February 19, 2011 Dana 35 eh? what gear ratio? what size tires are you planning to run? My perches are nothing special and the only wheel hop I've experienced was on a real long full-throttle gravel-ly uphill climb. I have added a second main leaf to my packs. don't under any circumstance remove the big overload leaf. it goes a long way towards controlling 'wrap and doesn't inhibit travel. :thumbsup: Link to comment Share on other sites More sharing options...
kyleag89 Posted February 20, 2011 Share Posted February 20, 2011 Out of curiosity whats the difference between welding new shock mounts on the axle tube, or using the stock mounts on top like Mjeff? Link to comment Share on other sites More sharing options...
mule13 Posted February 20, 2011 Share Posted February 20, 2011 when i did my soa i used a ford 9 inch rear end. i used the perches that were on the axle cut them off and moved them to fit . when i got it running it did have axle wrap and hop bad in sand. i went to tractor supply and bought some tractor turnbuckles and some cold roll steel rods and made braces. i actually made mine kinda short because i only grabbed 1 rod instead of 2 and i live so far from the store iwasnt going back. it worked though so it was all good. when i soa my yj i used the bought perches from a 4x4 shop and welded them on didnt have any axle wrap with the yj. i think the lightweight of the mj bed makes you hope and wrap alot. Link to comment Share on other sites More sharing options...
JCole Posted February 20, 2011 Author Share Posted February 20, 2011 Dana 35 eh? what gear ratio? what size tires are you planning to run? My perches are nothing special and the only wheel hop I've experienced was on a real long full-throttle gravel-ly uphill climb. I have added a second main leaf to my packs. don't under any circumstance remove the big overload leaf. it goes a long way towards controlling 'wrap and doesn't inhibit travel. :thumbsup: I have 4.10s with just a 30 or 31 tire. 95% on road with maybe just a hunting trail or so. Link to comment Share on other sites More sharing options...
Pete M Posted February 20, 2011 Share Posted February 20, 2011 that's a lot of lift for only 31s. sure you need that much? Link to comment Share on other sites More sharing options...
JCole Posted February 20, 2011 Author Share Posted February 20, 2011 that's a lot of lift for only 31s. sure you need that much? how much lift do you think I will have with a soa and stock sb 89 4x4 leafs? Link to comment Share on other sites More sharing options...
mnkyboy Posted February 20, 2011 Share Posted February 20, 2011 About 5" it takes 6"-6.5" up front to make it level. Here's mine with just the soa for comparison,it also has 31x10.50s in the pic. Here it is soa rear and 5" front with 31x10.50s Link to comment Share on other sites More sharing options...
alleydog Posted February 20, 2011 Share Posted February 20, 2011 I used the regular size weld on oerches, and a stock spring. I definitely have some spring wrap and wheel hop. I'm thinking about a traction bar or making some longer perches. Link to comment Share on other sites More sharing options...
Pete M Posted February 20, 2011 Share Posted February 20, 2011 that's a lot of lift for only 31s. sure you need that much? how much lift do you think I will have with a soa and stock sb 89 4x4 leafs? 5-6.5 inches depending on the condition of the leafs and the perch used. follow up question, why are you contemplating that much lift? Link to comment Share on other sites More sharing options...
JCole Posted February 20, 2011 Author Share Posted February 20, 2011 that's a lot of lift for only 31s. sure you need that much? how much lift do you think I will have with a soa and stock sb 89 4x4 leafs? 5-6.5 inches depending on the condition of the leafs and the perch used. follow up question, why are you contemplating that much lift? Because I didnt want to use lift blocks. Link to comment Share on other sites More sharing options...
Pete M Posted February 20, 2011 Share Posted February 20, 2011 lift blocks in an SUA configuration will lower your truck, not raise it. :thumbsup: blocks were never in the cards. given any thought to a 3" lift with full lift packs? got a budget for everything yet? also, how much freeway travel will the truck be doing? Link to comment Share on other sites More sharing options...
JCole Posted February 21, 2011 Author Share Posted February 21, 2011 lift blocks in an SUA configuration will lower your truck, not raise it. :thumbsup: blocks were never in the cards. given any thought to a 3" lift with full lift packs? got a budget for everything yet? also, how much freeway travel will the truck be doing? Round trip to work and back 35miles. Plus a trip or two from Tennessee to Ohio. As far as budget, I have between 3k and 5k to spend on the truck total. Link to comment Share on other sites More sharing options...
Pete M Posted February 21, 2011 Share Posted February 21, 2011 a quality 3" lift will perform much nicer on the road and still work wonders offroad. :thumbsup: Link to comment Share on other sites More sharing options...
