dakal Posted January 28, 2011 Share Posted January 28, 2011 scout 44 in rear chevy 44 in front dodge disks 3/4 ton hydrobooster bread van heater,not installed yet in garage ford intermittent wipers, not installed yet in garage ford tarsus? electric fan not installed yet in garage different driveshafts of unknown origin. doubles though ax-15 unknown donor same with 231 Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 28, 2011 Author Share Posted January 28, 2011 bread van heater,not installed yet in garage Bread van heater? Please explain. Link to comment Share on other sites More sharing options...
dakal Posted January 28, 2011 Share Posted January 28, 2011 big international van. its the small heater by the drivers leg. the core is about 3/4 of the size of the mj. very small & compact. operated by water. hose in hose out. on or off switch. size 7.5x7.5x2.75. no fan but i have an idea. Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 28, 2011 Author Share Posted January 28, 2011 big international van. its the small heater by the drivers leg. the core is about 3/4 of the size of the mj. very small & compact. operated by water. hose in hose out. on or off switch. size 7.5x7.5x2.75. no fan but i have an idea. Interesting. Might be an easy way to obtain heat when the heater core blows up out or for auxiliary heat. Gotta be easier than replacing the heater core. :ack: Link to comment Share on other sites More sharing options...
dakal Posted January 29, 2011 Share Posted January 29, 2011 i had trouble with the mj heater assembly, so what to do, what to do. rip and tear is my motto. its been a cold winder so far with the window part way down, and no heater. long underwear yaa. this will give good heat i think. deciding the best place for it now. dave Link to comment Share on other sites More sharing options...
dakal Posted January 29, 2011 Share Posted January 29, 2011 i had trouble with the mj heater assembly, so what to do, what to do. rip and tear is my motto. its been a cold winter so far with the window part way down, and no heater. long underwear yaa. this will give good heat i think. deciding the best place for it now. dave heaters in, on my build thread. (88 mj changling) Link to comment Share on other sites More sharing options...
Boots Posted December 19, 2011 Share Posted December 19, 2011 2001 xj 5-speed 2000(I think) TJ np231 xxxx xj dana 30 (has factory 3.73 gears) xj door panels I think that's it, for now. Link to comment Share on other sites More sharing options...
carnuck Posted December 22, 2011 Share Posted December 22, 2011 What about parts from other MJs? ;) I have interior lights from an Army tank, Extended lower arms from an XJ I parted, TJ 6" coils, 'YJ brake hoses, Rough Country adjustable trac-bar, SOA swapped in XJ rear axle (with a D44 from a '66 IH waiting to go in) Canopy from an S10 shortbox, column with shifter from an Auto MJ (and Steering box from an FSJ waiting to go in along with a ZJ brake booster/master) AW4 auto from a '92 XJ, NV242 too Wiring harness from a '90 XJ (no more C101 connector!) 33/9.50/15 tires on '96 XJ rims Link to comment Share on other sites More sharing options...
1989 Eliminator Posted July 16, 2013 Share Posted July 16, 2013 1996 XJ brake booster and MC Here is my brake conversion... http://comancheclub.com/topic/39437-1996-xj-dual-diaphragm-brake-booster-conversion/ Link to comment Share on other sites More sharing options...
benjy_26 Posted February 2, 2014 Share Posted February 2, 2014 ZJ Upcountry coils CJ7 Copper radiator ZJ Trackbar and trackbar bracket AMC V8 PCV valve grommet Chevy Truck brake hoses w Link to comment Share on other sites More sharing options...
mvusse Posted February 2, 2014 Share Posted February 2, 2014 I have had a shortened 2wd Toyota drive shaft on mine, but since I mangled it I have a stock 4wd MJ one again. Rear axle is out of a 98 Cherokee. Front axle is out of an 89 Cherokee with 92 Cherokee steering knuckles and brakes. Font shafts out of miscellaneous XJs and ZJs. Front springs are aftermarket Control arms are aftermarket Track bar is aftermarket Front shocks are for some compact car Rear shocks are for a Toyota T100 Rear brake hose is for a 95 Dakota Front brake hoses are for a 95 YJ Rear brakes are from a 97 ZJ Shackles are meant for a Chevy Gauge cluster is from an 89 Cherokee Old front bumper was from a Cherokee Limited, current one is aftermarket. Diver side door from a Cherokee Both front fenders from a Cherokee Header panel and all parts that go with it are from a Cherokee Air filter box out of an XJ Topper I believe is for an S10 (was one it when I bought it) I'm sure I'm forgetting stuff. Updated list: custom driveshaft on the rear, shortened stock one on the front. F350 axles (D60 front, 10.25 rear). Aftermarket lift shocks on front. Ford front shocks on rear. TJ rear brake hose. Chevy 1500 brake hoses on front. Topper is gone (still for sale) along with bed. ZJ steering box. 01-04 V8 WJ steering pump. WJ pitman arm. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted November 14, 2014 Share Posted November 14, 2014 From 86 XJ Waggy: front end (Grille/header assy and chrome bumper), one front fender, doors with all power options, power antenna, cig lighter, clock, front skid plate, T/C skid plate, radio, dual tone horns, stainless windsheild trim From ZJ: Front sway bar From unknown MY XJ: Aluminum Limited or Up Country style lace wheels, Rear bumper-chrome- adapted to fit From 07 JK Wrangler: Front and rear shocks-adapted to fit From YJ Wrangler: Stainless stock length front and rear brake hoses From 06 Grand Caravan: Power steering resevior From 99-04 WJ: Electric cooling fan- adapted to fit Made a couple changes. I always had issues with the caravan resevior because one of the hose fittings wasnt the right size. I found one from a Dodge journey had the right size fittings and was deeper, so I have that now. Also installed a set of JK wheels with spidertrax adapters. Getting ready to go find a WJ booster and master to replace my vac leaky MJ booster. None of this includes the ton of parts transferred over from my 86 MJ. AC, PS, 4wd, 5spd, 4:10's Link to comment Share on other sites More sharing options...
dankicksass Posted November 14, 2014 Share Posted November 14, 2014 On my 91 4.0 HO AT 4x4... Cooling: RHD XJ 4.0 Postal vehicle radiator Engine: 99+ 4.0 intake VW VR6 ABV Bosch 21lb 4-hole injectors Brakes: WJ brake booster and master cylinder Chevy front brake hoses from the budget lift page Dakota rear brake hose from the budget lift page CJ rear brake cables from the budget lift page Chevy Venture fixed in-line proportioning valve for drum brakes Steering: WJ late V8 power steering pump for models with hydraulic radiator fan 99 Durango 4x4 non-plow steering box ZJ V8 complete steering linkage Suspension: WJ front control arms upper and lower Chevy lowering shackles 99+ Chevy Silverado noise recall leaf spring silencer pads TJ Daystar front bump stops Electrical: 99 Dakota V8 136A alternator Body: Wagoneer 4-light grille TJ Rubicon fender flares Toyota pickup 87-94 outside mirrors on summer cut doors 97 XJ doors for the rest of the year JK tail lights Sprinter chassis cab license plate lamps 88-98 Chevy C/K tailgate handle TJ spare tire mount Interior: Mercedes W210 wagon interior lights Toyota pickup 87-94 inside mirror with dome light Chevy hazard button ZJ automatic shift knob ZJ cloth bucket seats 97 XJ center console (Edited 11/28/14, did some upgrades.) Link to comment Share on other sites More sharing options...
Dadinator Posted January 30, 2015 Share Posted January 30, 2015 Fender grill front bumper and header from 91 xj ax15-np231 full gauges steering column and a bunch of smaller parts from 90 xj front axle from 95+ xj seats from 2000 dakota bed from different mj tailgate from different mj wheels from tj piece of sheet metal from old dishwasher for rust repair Have newer xj doors, but not installed yet. transfer case shift lever and knob from old snapper mower. Probably a bunch of other crap i am forgetting... Link to comment Share on other sites More sharing options...
dustyinthedirt Posted January 31, 2015 Share Posted January 31, 2015 Hey Hornbrod. do you have a build page? Link to comment Share on other sites More sharing options...
MancheKid86 Posted August 9, 2015 Share Posted August 9, 2015 3/4 elliptical leafs from unkown 1977 lincoln versailes calipers rear ford granada brake pads rear cj 5 rotors rear, scout d44 rear early 1970's ford truck ebrake cables chevy 241 internals in a 231 tcase 231 crawl box 89 yj ax 15 dodge brake booster/master cyl zj 1/4 thick tubed drive shaft front scout d44 front axle chevy 1 ton steerting 93 ho stroker xj xj seats soon to be 97+ swapped Link to comment Share on other sites More sharing options...
mvusse Posted August 11, 2015 Share Posted August 11, 2015 I have had a shortened 2wd Toyota drive shaft on mine, but since I mangled it I have a stock 4wd MJ one again. Rear axle is out of a 98 Cherokee. Front axle is out of an 89 Cherokee with 92 Cherokee steering knuckles and brakes. Font shafts out of miscellaneous XJs and ZJs. Front springs are aftermarket Control arms are aftermarket Track bar is aftermarket Front shocks are for some compact car Rear shocks are for a Toyota T100 Rear brake hose is for a 95 Dakota Front brake hoses are for a 95 YJ Rear brakes are from a 97 ZJ Shackles are meant for a Chevy Gauge cluster is from an 89 Cherokee Old front bumper was from a Cherokee Limited, current one is aftermarket. Diver side door from a Cherokee Both front fenders from a Cherokee Header panel and all parts that go with it are from a Cherokee Air filter box out of an XJ Topper I believe is for an S10 (was one it when I bought it) I'm sure I'm forgetting stuff. Some changes since then. Front axle out of an 89 F-350 Rear axle out of a 92 F-350 Power steering pump out of an 01 Grand Cherokee, modified for higher pressure Steering box out of a Durango, modified for longer stroke and hydraulic assist Pitman arm is not original, can't remember from what Wheels from a HMMWV, modified for 3" back spacing Tires from same (37x12.50R16.5 BFGs, military flavor) Shortened stock front drive shaft with conversion u joint Lengthened .250 wall front driveshaft with conversion u joint in the rear Front brake hoses from some vintage Chevy truck Link to comment Share on other sites More sharing options...
mikekaz1 Posted September 7, 2015 Share Posted September 7, 2015 Thought this might be interesting to see what MJ mods you have used from non-MJ vehicles on your MJs. I'm not talking about aftermarket parts/upgrades; I mean mods you've made to your rigs using actual parts from a non-MJ vehicle, like a Taurus fan, XJ/WJ master cylinder/booster, Ford 8.8 axle, etc. Here's my list: Buick steering wheel 2004 Wrangler power steering pump/brackets 2001 XJ intake manifold 1995 ZJ quick ratio steering gear box ZJ V8 sway bar, tie rod WJ lower control arms Mitsubishi CD player and sound system Mercedes W124 ambient temperature display Ford Explorer rear disk brakes 1996 XJ booster and master cylinder Porsche side marker lights Porsche 411 interior lights XJ bucket seats & console XJ power windows and mirrors Dual XJ electric fans Dodge 134A alternator Pictures or I don't believe! Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 7, 2015 Author Share Posted September 7, 2015 ^^ You calling me a liar newb? :rotfl2: Which one(s) did you want to see pics for? Link to comment Share on other sites More sharing options...
mikekaz1 Posted September 7, 2015 Share Posted September 7, 2015 ^^ You calling me a liar newb? :rotfl2: Which one(s) did you want to see pics for? Temp display and turn signals specifically. Thank you all and powerful wise one Also... do you notice a difference between old and new intakes? I have an extra new style that I've been throwing the idea back and forth Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 7, 2015 Author Share Posted September 7, 2015 Temp Display: http://comancheclub.com/topic/5323-mercedes-ambient-temperature-display-in-an-mj/?hl=mercedes Euro Turn Signals: http://comancheclub.com/topic/7189-euro-side-repeater-lights/?hl=euro New Intake Dyno Results: http://www.jeepstrokers.com/forum/viewtopic.php?f=5&t=387 Link to comment Share on other sites More sharing options...
mikekaz1 Posted September 7, 2015 Share Posted September 7, 2015 Bravo. I appreciate that! The ambient temp sensor looks great! Definitely want to do that one. And I guess you sold me on the intake swap... as the information I took on the quick read i did was a positive gain Link to comment Share on other sites More sharing options...
