Comanche_Fanatic Posted January 20, 2011 Posted January 20, 2011 Sup y'all? I bought my MJ a while back and got her running again. Now I've thought through about the things I plan to do for her. it'll be a long build though due to shortage of cash. After driving the MJ for a while I've found some things I need to do before I go major. I plan to make a 1/2 ton workhorse out of it, like a 5.9L, NV4500, and NP231. I need to get it tuned up to new first though. Near-future plans will be included next post
btm24 Posted January 20, 2011 Posted January 20, 2011 is this the same as this one ? http://www.comancheclub.com/forums/viewtopic.php?f=7&t=27835 Brandon
Comanche_Fanatic Posted January 20, 2011 Author Posted January 20, 2011 Plans Short-term -change engine oil -change transmission fluid -change clutch fluid -change differential fluid -change brake fluid -change p/s fluid -change blinker fluid -change coolant -seafoam -replace spark plugs -replace fuel pump/filter -replace fuel filter -replace distributor cap -replace rotor and wiring -replace wiring harness -replace O2 sensor -replace crank sensor -replace hoses -replace serpentine belt -replace head gasket -replace valve cover gasket -replace catalytic converter -replace fuse box/fuses -replace lighting -replace taillights -replace windshield wipers -check bearings and all moving parts -check timing -check valve cover -check manifolds -check brakes -add tailpipe for muffler -install muffler bearings -install electric fan -install custom rear-view mirror -have it detailed -fix A/C and Heat -install radio/speakers -paint exterior OD green clearcoat -add bedliner -replace front clip -replace fenders -replace doors -restore interior -repair and restore dents/scratches -scrape rust off (if any) Long-term -rebuild 2.5L and AX5 -5.9L Magnum engine -NV4500 transmission -NP231 transfer case -HD front and rear axles -4.58 gears -OME leafs and shocks -Olive drab green clearcoat -black bedliner/lettering/star -undercoating -black 15x8 steel wheels -31' mud terrain tires -lighting kit -roll cage -bumpers -winch -black diamond toolbox ps. ones already done are in red
Comanche_Fanatic Posted January 20, 2011 Author Posted January 20, 2011 is this the same as this one ? http://www.comancheclub.com/forums/viewtopic.php?f=7&t=27835 Brandon ah man why'd u post before my plans list... yes its the same one
btm24 Posted January 20, 2011 Posted January 20, 2011 I'm sorry lol and if this is the same truck why have to build pages about the same thing? lol Brandon
Comanche_Fanatic Posted January 20, 2011 Author Posted January 20, 2011 this is last one, gonna let other pages die. will be doing all my posting here
Comanche_Fanatic Posted January 20, 2011 Author Posted January 20, 2011 I really hope your joking on some of that. I am, on some of them :rotfl2: :thumbsup:
Dirteatr717 Posted January 20, 2011 Posted January 20, 2011 Don't forget to change the blinker fluid :D
Comanche_Fanatic Posted January 20, 2011 Author Posted January 20, 2011 Don't forget to change the blinker fluid :D :shake: haha i won't! :thumbsup:
Comanche_Fanatic Posted January 20, 2011 Author Posted January 20, 2011 On my way to the bank i noticed a big loss in power when i press the gas slightly, aka merging onto major roads. i think its another fuel problem or a cylinder malfunction. so i've got to look into that when i do the tune up. when i got home i decided to check around the a/c and heat to see any problems. the thing is i don't have a wiring diagram so i don't know what fuses and wires are missing. i also tried to repair some of the wires under the hood, damn squirrels... and I'm also puzzled about what else is missing on the dash. i know one spot over the heat and ac is the radio, but whats the bottom one? here's some pics
Comanche_Fanatic Posted January 21, 2011 Author Posted January 21, 2011 kinda bored today :redX: wish i had my own garage full of tools and equipment and about $10k so i can fix up the MJ. of course thats a long way away lol. :wrench:
comanche12 Posted January 22, 2011 Posted January 22, 2011 kinda bored today :redX: wish i had my own garage full of tools and equipment and about $10k so i can fix up the MJ. of course thats a long way away lol. :wrench: TOTAL agree with you. I'm not even reach half way of tools that I need to work on vechicles. about 3/4 way to go to get full of tools that I need.
Comanche_Fanatic Posted January 22, 2011 Author Posted January 22, 2011 yeah i saw the 400+ tool set at Sears for like 500 bucks, might snatch that when i get the chance. its Craftsman and made in USA as well. it should get most of the job done, but special and larger tools i'll have to get separate
comanche12 Posted January 22, 2011 Posted January 22, 2011 sounds pretty good deal but IMO craftman is alright for use on vehicle. Snap-On and Matco are best tools to me to use on vehicles. IMO I like craftman's lifetime warrenty but I don't like their air power tools. they fail two times to me so I'm not gonna use their air power tools anymore. :(
Comanche_Fanatic Posted January 22, 2011 Author Posted January 22, 2011 yeah i was hoping for craftsman hand tools so i can use it on anything from cars, boats, small engines, home, woodworking. and use snap on for power and speciality tools. i can't get snap on everything cause its too expensive.
87Chief Posted January 23, 2011 Posted January 23, 2011 For tools, go to craigslist. Or a pawn shop... Great deals.
Comanche_Fanatic Posted January 23, 2011 Author Posted January 23, 2011 For tools, go to craigslist. Or a pawn shop... Great deals. good idea, i got a this set in a pawn shop back in Missouri. paid nothing but 5 bucks for them. and my dad said i was an idiot for buying them, hell I'm still using them a lot!
Comanche_Fanatic Posted January 26, 2011 Author Posted January 26, 2011 whew its raining, dark, wet, and cold outside. but i managed to take the fuel pump out and drop the tank. gonna transfer the gas to my Wrangler in the morning and fix whatevers broken.
Comanche_Fanatic Posted January 26, 2011 Author Posted January 26, 2011 looky what i found, on my brand new fuel pump filter.... the fuel system really needs to be cleaned out. i mean everything from the tank to the engine.
comanche12 Posted January 26, 2011 Posted January 26, 2011 looky what i found, on my brand new fuel pump filter.... the fuel system really needs to be cleaned out. i mean everything from the tank to the engine. yuck :ack: good thing that you caught it :clapping: clean it up!
Comanche_Fanatic Posted January 26, 2011 Author Posted January 26, 2011 finally got the tank out, all thats left is the fuel filter and the hoses. and yeah i am gonna clean it, that filter is disgusting lol. however i think the tank needs replacing, its dented in many places
MancheKid86 Posted January 27, 2011 Posted January 27, 2011 so you still going to transfer that gas? :shake: :yes:
