231 neutral
jimoshel
Seems there is some discussion and disagreement as to whether the 231 transfer case has a true neutral, that is the front and rear drive shafts are separate from each other. The following may not prove anything but it gave me something to do.
First obtain a 231. This one happens to have a AX15 attached to it.
Image Not Found
Secure it to a firm, stable surface, clamping one drive shaft down so it cannot turn.
Insure transfer case is in neutral
Image Not Found
Now, using a drive shaft turning tool attached to the other drive shaft, try to turn that sucker.
Image Not Found
Those suckers are locked together.
Image Not Found
Hope ya'all enjoyed reading this as much as I enjoyed doing it. Jim comanche.gif
I should have mentioned that the unit I was foolin with came out of a 1988XJ. However according to the ID stamping it's a 1990 unit. I think one of the biggest sources of disagreement and confusion on what's what is due to the fact that our trucks are over 20 years old and very few of us are the original owners. Who really knows what was done to or swapped in them before they came into our possession? I still have it set up. Going out tomorrow and try what COMJNUT mentioned. Go thru all the gears and see what happens. Should have done it today but never thought about it.
I still say that you don't tow ANY jeep on a tow dolly.
there is not one single year that says it's OK to put the tcase in neutral and tow it. in fact, they all advise against doing so, and using a dolly. flat towing in N is acceptable, however...but most of us don't flat tow our jeeps.
it's just easier to avoid the hassle of even questioning the situation. I personally like not blowing up parts on newly acquired jeeps.
What do you guys that drop the rear D-shaft do about the slip yoke???
The only time I ever dolly-towed an XJ.. I used the recommendation in the owner's manual.. which is:
Manual tranny....
transmission in gear
T-case in neutral
Auto tranny...
Transmission in Park
T-case in neutral
the right way to tow on a dolly...remove rear drive shaft, it's only 8 bolts easy people! :nuts:
Eight bolts??
EDIT: See you caught it.
uh...yes...8, 4 that connect it to the rear axle, and 4 on the output from the t-case...oh wait I'm not stock in that aspect...dangit :rotf: I have a SYE, well then bag the output of the t-case, or you will have fluid all over the ground, and you will need to fill it after the dolly tow. :shake:
or just do the 4 and then tie the driveshaft up to the chassis :banana:
I have a old bank money bag I use when dropping the drive shaft. Just slip it over the end of the DS, draw the strings up tight. and tie it up to something underneath. Keeps the DS and the bearings in place.
eggzackery :jump:
91+ are true neutral.
87-91 are a grey area, and some were true neutral, some weren't.
Ok, I'll be checking mine while I'm doing the oil change...and with video! :clapping:
I disagree. The changeover was partway through 94 or between 94 and 95.
My 94 XJ's 231 (which is the original one it came with from the factory) does NOT have a true neutral. And not having a CAD, it cannot be towed on a dolly without pulling a drive shaft.
Our '93 XJ NP231 does have true neutral.
Our '94 YJ NP231 does as well.
Double checked my sources, and you are correct. 95 was the changeover year. Before that, its really hit or miss with no rhyme or reason. Some are, some aren't.
