I'm leaning towards a 3" lift and some 31's for the MJ, but I would like to see some pics of a 2" lift with 30's. Does anyone have any? I can't find any.
'Grandpa' has 2" in front (sagged 3" Rusty's coils), and stock (2wd) leafs out back,
with 30's:
Vs stock ht 2wd & 205/75's:
Foreman, do u have any rubbing issues? Also, is that 2" a suspension or body lift?
you can't body lift an MJ.
a 2" lift is much cheaper than a 3" lift and you can run either size tire with either size lift as long as you stick with Jeep rims (31s might rub a small amount on the lower control arms with Jeep rims). for 31s on aftermarket rims, you'll want 3" or some fender trimming.
Foreman, your truck has a great stance!
...must look away....must retain the notion of keeping it at stock height......must---I can't look away!!!!!
:fs2:
:yes: Your under the spell as I was when I first saw it. I can't take credit as this is how I got it a couple of weeks ago. I do like it though and thanks for the kind words.
