will 33's fit?
33x10.5s will work great. 33x12.5s, not so much. It's not just width of the tire vs width of the rim though. 33x12.5s on factory rims will pull that big fat tire in reeeeeal close. aftermarket rims will push the tire out for more turning radius. but again, 33x10.5s will work in that aspect too.
keep in mind that you might have tire rubbing on the bed wall when the rear tires flex up. a set of quality wheel spacers should fix that (as well as make the front and rear match in terms of tire sticking out from the fenders). or you can extend the bumpstops. or both. :thumbsup:
extended bumpstops up front might be good too.
BFG makes a 33x10.0x15 all terrain tire. I had them on my XJ in the 31x10.5x15 size. Worked great for me,(sand,dirt,and rocks. never had them in mud so I don't know about that) :yes: When I went to 33x12.5x15 BFG M/T I had to get rims with more offset because they did rub on the frame in the rear. Hope this helps you.
wel i cut my fenders for wheel travel when i get "twisted" as we call it out here and i don't rub i have a coil spacer i believe in the front and i fit 33x12.50r15x10 and i rub a lil like hard turn but no sway bar either so its like a sec and goes away lol but i have another set out rims that i wanna put on the are a huge offset and never rubbed and a buddy of mine has them on his cherokee and likes them and they are 15x10 too wide and will not need wheel spacers i saw a wheel spacer break on a friend and ended up getting a axle.
Cody -
Please do us and yourself a favor and look on your keyboard for the period, comma, and caps lock keys. The English language is spoken in sentences, which allows one thought to be separated from the next thought.
The post above is (I'm sorry to say) essentially unintelligible gibberish -- all because you're in too much of a hurry to observe standard punctuation and capitalization. Seriously, it makes my head hurt just trying to read it.
come on man your on the computer, texting, working in the navy, you use short hand. Its a habit that they get you in during bootcamp. if you know anything about that. since it sounds like you do not know and sounds like you are a teacher! if its that big of a deal then don't read the post i put up!
I think what Eagle is suggesting; is that it might be easier to interact with you, if we knew what you were saying. :smart:
its whatever!!! some people help out and they don't have a problem with it! or maybe u can slow down and read. ill try to fix it but habit is something from work and that is what i do all day is short hand stuff and that,is the NAVY for you! but i'm not mad about it and really don't care! more like high school drama if you ask me on here we are all adults on here looking for answers and help ill try and fix a habit on here!!! so it makes everyone feel better on here and to get off my back!!! about this
**************************************NEW POST*************************************************
well!!!!! i cut my fenders for wheel travel!!!!! when i get "twisted" as we call it out here and i don't rub at all! i have a coil spacer i believe in the front and i fit 33x12.50r15x10. i rub a little like on a hard turn but no sway bar either so its like a sec and goes away!!!!!!!!! lol but i have another set out rims that i wanna put on the are a huge offset and never rubbed! a buddy of mine has them on his cherokee. he likes them and they are 15x10. they look too wide. will not need wheel spacers!!! i saw a wheel spacer break on a friend and ended up getting a axle in the end.
This is not a cell phone, and this isn't the Navy. Shorthand is not appropriate where it isn't necessary and where/when it makes things more difficult for the people with whom you hope to communicate.
In the Army we called it 'Basic Training." Yeah ... been there, done that, got the medals to prove it. Next insult?
Fair enough.
Ciao.
33s will fit the rim but will they be good for the lift your going to run is my thing.
I'm on 4.5 lift and 33s are my logic but would prolly leave little flex room. 31s would flex it out but look small on that lift. and hell 32s cost more then either but would prolly be the proper size. i guess for me (sorry to hijack) its about money in the end. so even if 33s are a tad big, its cheaper.
thank yall for the help. ill do a bit of trimming when i get the lift and such going. I'm just supper glad that i don't have to get new rims that can get into alot of $ (and i really like my rims). Ill look around for spacers also but i won't worry to much. In FL there are not any real hills and for the most part i do street driving with some mudding so i won't worry about the flex to much. :D thank yall so much once again :cheers:
Brandon
If muddin' is your thing, either stay away from the bfg AT, or just have a second set of rims/tires for muddin'. The bfg MT would be a good dual use tire.
oh do they suck for that? my pirelli all terrain tires work great for that type of off roading. I have never looked into any type of mud tire because all I ever hear is that they don't last long and they ride like crap on the road right?
Brandon
If you think your current tires work great, then you really need a set of mud terrains. There are basically 2 different grades of "mud terrain". Those that are designed mostly to be a more aggressive allterrain (meaning they still work good on pavement), and those that are balls-out mud tires (meaning, well, you know). go with the first ones if they are your only tires, go with the second if you have street tires too.
