Year, Make, Model:
1987 AMC Jeep Comanche
Image:
This is how I got it in May of 2009:
/uploads/archive/bfbca1bdea1d132132d8c805055a1cda/76e8377eca774da3ed90c24d986ad408.jpg
This is how it sits as of today:
/uploads/archive/bfbca1bdea1d132132d8c805055a1cda/036c412e0b126f0b930352e0118bfc28.jpg
Engine / Trans / Transfercase / Front axle / Rear axle / Wheelbase:
4.6L Stroker I6 / AW4 / Klune 4:1 / Modified 231 with 6 planetaries and SYE / Dana 60 Tera Hi Pinion front axle/ Dana 60 rear / Bilstein 9100 ACV coil overs in the front / 7100 ACV rear suspension
Build date: (its on the driverside door sticker, in the form of month and year)
Build Date is unkown as I didn't recall to check it before I swapped out the doors off of a 96 XJ
Current Location:
Located currently in Los Angeles, CA
Status:
Road worthy project that is 95% done and waiting for more use.
Notes:
Pretty much the whole vehicle has been changed from when it was first aquired. It used to be a 2WD with a Peugot Manual and is now an automatic 4x4. The frame rails have been plated as well as the drivers front wheel well. The interior floor has been cut and rebuilt to make room for a transfer case doubler and a completely flat belly pan. There is a home made fuel tank skid. Custom exhaust job. Traction bar. Custom rear bumper. Custom hybrid cage. Sits currently on 37" MTRs with alloy beadlocks. 7" custome 3 link lift with Bilstein suspension. Rock lights. Floor mounted transmission shifter. LOA rear with a modified OEM MJ leafpack. Much Much more.
Interior color is black and has a bench seat. Exterior color is now white but I am unsure as to what the original color was (dark charcoal?).
Mileage is to be estimated at 160K but the spedometer had stopped at 122K on the chassis
Current owner:
Me. Avery and it is in my back yard :cheers:
  • 1 year later...
  • 7 years later...
  • 1 year later...
Correct VIN 1JTMW6414HT163412
Body Model TL 61
*X1
-Y1
3LR
APA MONOTONE PAINT PACKAGE
CBA BENCH SEAT - STRAIGHT BK
CGX Head Restraints-Outboard Seating, RR
DDJ 5SPD MANUAL TRANS
DMR 3.55 Axle Ratio
DSA LIMITED SLIP DIFFERENTIAL
ERB ENGINE - 4.0L I6 MPI GAS
GAC ALL WINDOWS - TINTED GLASS
GEC Window - Left Side, Front, Sliding
HCC HEATER W/UPR LEVEL VENTIL - TYPE II
JAY Instrument Cluster w/Tach
JFH TACHOMETER - MECH
JGB Clock - Digital
JJA CIGAR LIGHTER - FRT COMP
KD8 STRIPE/BADGE/MOLDING/DELETE
LAP FUEL ECONOMY SHIFT INDICATOR LIGHT
LMA HALOGEN HEADLAMPS
MDA FRT LICENSE PLATE ATTACH REQUIRED
NAE EMISS CONTROL TESTING &&&& LABEL
PX6
QX6
SBA POWER STEERING
TBB CONVENTIONAL SPARE TIRE
WMC BASE WHEEL DRESS - UP (INCLS TRIM RING)
  • 7 months later...
Posted (edited)
Selling Dealer: BRIAN CHUCHUA'S 4 WD CENTER
Placentia, CA
Edited by jdog
spelling
  • fiatslug87 changed the title to 1JTMW6414HT163412
