MJ is dead Posted July 3, 2010 Share Posted July 3, 2010 Ok, So I've read everywhere, including my owners manual that there was only a 16 and 23 gallon gas tank size available in 87. With the 23 gallon being more common in the longbed. here's where things get weird. Mine is full at just shy of 12. Is it possible that I have a 16 gallon with 4 Gallons of crap in the tank, or is there a 12 gallon option out there? I'm a confused little greaseball here fellas. :nuts: Link to comment Share on other sites More sharing options...
Pete M Posted July 3, 2010 Share Posted July 3, 2010 early years of longbeds had 16 standard and the 23.5 optional. shortbeds were all 18. Maybe your fuel gauge or fuel float isn't working perfectly anymore. :dunno: Link to comment Share on other sites More sharing options...
MJ is dead Posted July 3, 2010 Author Share Posted July 3, 2010 Gee pete, its only 23 years old, how could it go bad? :rotf: Might not be a bad time to swap in a Cherokee cluster eh? Link to comment Share on other sites More sharing options...
jimoshel Posted July 3, 2010 Share Posted July 3, 2010 How do you know the tank is empty? Put a one gallon gas can, full, into the back of the truck and drive it until it dies. Put in the gallon spare and head for the nearest station. Then see how much it takes to fill it. Or, drain the tank at home. Then refill it from measured containers. Edit;SDak? Better make it a five gallon can. Link to comment Share on other sites More sharing options...
MJ is dead Posted July 3, 2010 Author Share Posted July 3, 2010 Hahahahaha Jim, you make it sound like there is only two cities in SD. Yes, we DO have running water and electricity here. Link to comment Share on other sites More sharing options...
dakineJ Posted July 5, 2010 Share Posted July 5, 2010 Happy 4th ! I think there was a 13g or 13.5g tank, pretty sure that's what I have in my '87. Link to comment Share on other sites More sharing options...
akamcbird Posted July 5, 2010 Share Posted July 5, 2010 the empty lite comes on when theres around 2 gal. left in the tank... so only 2 gal. of sludge in your tank, if you clean it out don't be surprised if it starts leaking... Link to comment Share on other sites More sharing options...
johnj92131 Posted July 5, 2010 Share Posted July 5, 2010 Just checked the 1/88 parts book. MJ lists both 16 and 23.5 gal tank for gas and diesel, also lists an 18 gal fuel tank for Gas, Injected. XJ 2 tanks only for either gas or diesel, 13.5 and 20.2 gal. So no 13.5 gal tank for the MJ Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted July 5, 2010 Share Posted July 5, 2010 More info here; viewtopic.php?f=9&t=10054 Link to comment Share on other sites More sharing options...
aemsee Posted July 5, 2010 Share Posted July 5, 2010 how much do you want to trust a sheet that lists 84 Comanches? :D . I remember a similar thread a while back. Guess it never got resolved? Link to comment Share on other sites More sharing options...
jimoshel Posted July 5, 2010 Share Posted July 5, 2010 That list just has to many in accuracies to be used for a final word. Link to comment Share on other sites More sharing options...
johnj92131 Posted July 6, 2010 Share Posted July 6, 2010 Nice spread sheet. Is there a FACTORY source document to back it up? Besides the factory parts book, I have an 87 Comanche owners manual. That manual say nothing about a 13.5 gal. tank. It list 2 fuel tank sizes - 60.5 liters (16 gal. U.S.) and 89 liters (23.5 U.S. gal.). I think the confusion about the 13.5 gal tank may have come about because the same factory manuals also list the Imperial Gallon size of the smaller 60.5 liter tank as 13.3 Imperial Gallons. It is very reasonable to "think/assume" the 13.3 imp. gal. tank is the same size as the 13.5 U.S. gal Cherokee tank. Besides after looking at all the numbers on that spreadsheet, I would find it very hard to notice the difference between 13.3 and 13.5. Would be nice if that sheet were updated and corrected. It could be VERY useful. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted July 6, 2010 Share Posted July 6, 2010 My 87 when it reads empty is actually still about a quarter tank full. I kinda like it like that because it will make it tought to actually run out of gas. Ive run it for quite a while past E, just to see what will happen, and have yet to put more that 14.5 gallons or so to fill it up at that point. Just cause you read it at empty doesnt mean your tank is that much full of crap... just means that the float is not reading like it should. Link to comment Share on other sites More sharing options...
MJ is dead Posted July 6, 2010 Author Share Posted July 6, 2010 Don't get me wrong, its not a problem, in fact like you said, its actually kinda nice. I'd much rather have me float tell me I have less gas than more. I was just curious more than anything. The PO rednecked the hell out of this thing, ya never know if he popped a different tank in there Link to comment Share on other sites More sharing options...
