88swampedmj Posted October 26, 2006 Posted October 26, 2006 i have the pos peugot... i know i need to change the oil in it but the drain plug is a B**** i can't find anything to fit in the square hole to let the old oil drain... i tried the regular sockets... is there a tool? or trick? i couldnt use vicegrips bc theres no room to turn them
mjeff87 Posted October 26, 2006 Posted October 26, 2006 It's an 8mm (or 5/16") square plug. You can file down a sacrificial 3/8" extension to fit, or file two sides off an 8mm allen wrench to fit, or if you can find a small piece of square stock in either size you can use that and turn it with a wrench. HTH, Jeff
Kenosha Warrior Posted October 26, 2006 Posted October 26, 2006 Oizarod has had luck with filing down a 3/8" drive and going from there. talk to him.
Pete M Posted October 27, 2006 Posted October 27, 2006 Yup, me too. I dug out an old extension that didn't stay on the ratchet anymore and ground down 2 sides. Make sure you only take off a little at a time, as it's really easy to end up with a 7mm and round out the hole. Don't ask me how I know. :oops:
fiatslug87 Posted October 27, 2006 Posted October 27, 2006 I recommend cutting off the end of the extension past the ball bearing and squaring off the shaft. I tried the easy way of just grinding off two adjacent sides but it was too weak and it broke.
Oizarod115 Posted October 27, 2006 Posted October 27, 2006 i just ground the end where the ball was.... mine wasnt to tight, but thats a good idea to cut off the end and grind further back, also helps with clearance i bet. but yeah, 3/8" extension works. gotta grind for a while though, grind, check, grind, check
mjeff87 Posted October 27, 2006 Posted October 27, 2006 if all else fails and you can't get it out, you can still fill the box via the shifter housing (remove shifter and pour it in). I usually refill my AX that way (but the shifter pops out very easily, unlike the BA10 :cry: ) and leave the fill plug out.....stop adding when it starts to dribble out the fill hole. You would just need to put in a measured amount since the plug would still be installed. Jeff
Oizarod115 Posted October 28, 2006 Posted October 28, 2006 if all else fails and you can't get it out, you can still fill the box via the shifter housing (remove shifter and pour it in). I usually refill my AX that way (but the shifter pops out very easily, unlike the BA10 :cry: ) and leave the fill plug out.....stop adding when it starts to dribble out the fill hole. You would just need to put in a measured amount since the plug would still be installed.Jeff thats how i filled my BA10... its not THAT bad, but you have to take the consoles/shift boots out which is annoying... the actual shifter is only held in by 3 bolts, the boots are much more obnoxious. can you beleive i added nearly 4 quarts to my puke-goat? :eek:
Pete M Posted October 28, 2006 Posted October 28, 2006 Yes, yes I can believe that. But only because I've done similar. Heck, on that last trip the trans was literally dry (after it blew a hole through its side) and it still got me home. :D It was noisy enough to hurt your ears and the last few mile I was stuck in 3rd, :roll: but still...
Oizarod115 Posted October 28, 2006 Posted October 28, 2006 Yes, yes I can believe that. But only because I've done similar. Heck, on that last trip the trans was literally dry (after it blew a hole through its side) and it still got me home. :D It was noisy enough to hurt your ears and the last few mile I was stuck in 3rd, :roll: but still... my theory on the common blowout of BA10s is fluid loss, i think the split case causes leaks in alot of cases, because my BA10 was PERFECT when i bought the truck, daily drove it/ trips to my brothers 100+ mi with no fluid, and its TERRIBLE now. barely get it into 2nd, hard to get in 1st, grinds into 4th unless i put it up near 3rd then into 4th
Pete M Posted October 28, 2006 Posted October 28, 2006 From what I remember, the big leak on mine was the driveshaft seal, but would only apply to 2wds.
Oizarod115 Posted October 28, 2006 Posted October 28, 2006 From what I remember, the big leak on mine was the driveshaft seal, but would only apply to 2wds. mine leaks everywhere except there haha. it smells as if the fluid is leaking onto the clutch and burning off. and the bottom of the case is disgusting. i can't actually tell if ive got a rear main leak at all :roll:
88swampedmj Posted October 31, 2006 Author Posted October 31, 2006 thanks for the help guys.. mine doesnt seem to be leaking at all but i know there is water in there.. so my oil is prolly milk now.. but mine won't go into 4th at all.. it just grinds tryin.. i think its a gonner.. but hopefully it will if i fill it full of good oil.. otherwise.. time to save up for a ax-15
