streetjeep2.5 Posted May 12, 2010 Posted May 12, 2010 I know it may seem a bit dumb, but I am bugged by how the rear wheels on an MJ are about 1 to 1 1/2 inches deeper into the fender well than the front wheels. I want to fix that. Options: 1. Aftermarket wheels with less backspace, but then they stick out too far on the front if the same width. :ack: 2. Aftermarket wheels and put 8" wide on the back and 6" inch on the front, but that does not trip my trigger either. :shake: 3. Stock wheels for the back widened by 2 inches, but MAN! That's expensive with shipping, etc., to the places I know of, unless anyone knows of a place in the St. Louis area that does that work, maybe Kansas City. :???: 4. Different looking wheels on the back than the front. YUCK! :grrrr: 5. 7 inch wide wheels where the front have the same backspacing as the stock wheels, but the rear with 1 to 1 1/2 inch less backspace. :???: 6. Spacers, but it would need to be at least 1 inch spacers. :dunno: Quickest fix is spacers, and that, too, is about 80 smackeroo's. And, I've heard pro's and con's to spacers. Truck is highway only, 4x2, but occasionally hauls a fairly hefty load of stuff needed for landscaping, etc. Ya'all got opinions? Know of aftermarket wheel companies that offer variable backspacing on the wheels I choose? Spacers a safe option? :roll:
DJM/78 Posted May 12, 2010 Posted May 12, 2010 Your cheapest bet is with spacers for the rear , however depending on your lift offset wheels will rub on the inner and outer fender in the front anyway . IMHO I like the look of the offset wheels , if you run down to a wheel shop you could get more of an idea of a custom offset that will be different from front to back but with matching offset wheels I can't even tell the difference , much less noticeable than stock offset wheels .
vaquaro Posted May 12, 2010 Posted May 12, 2010 Just some food for thought , narrower rear track reduces under-steer . Take a look at old sportscars with achaic suspention like our trucks used this narrower rear axel trick to improve handling :cheers:
mvusse Posted May 12, 2010 Posted May 12, 2010 The rear axle on an MJ is no narrower than the front axle. The body is just a lot wider. I have run spacers for a year and a half without problems. Before that I ran spacers on my Suburban for years without problems. If I may suggest a brand, I would say to go with Spidertrax hub centric ones. The ones list 87-06 Wrangler are the ones you need for an MJ. They are 1.25" (gives you a 2.5" wider track), which is just about right.
ComancheKid45 Posted May 12, 2010 Posted May 12, 2010 x2 on the Spidertraxx.......Ive had no issues with mine :thumbsup:
Geonovast Posted May 12, 2010 Posted May 12, 2010 You guys are silly... getting rid of the rake.... making the rear axle wider so it looks like it isn't narrower... MJs have a distinctive look. Personally I vote to keep it :D
Eagle Posted May 12, 2010 Posted May 12, 2010 Ya'all got opinions? Yupp. Spacers a safe option? Yes ... if you get the ones that are machined from solid billet, not castings. They are expensive. My opinion: If it ain't broke, don't fix it.
comanche12 Posted May 12, 2010 Posted May 12, 2010 or get 9" ford rear like mine and its make my wheel look alot smaller on truck since the axle is alot wider :) :yes:
87Warrior Posted May 13, 2010 Posted May 13, 2010 I have had a good experience with the SpiderTrax spacers on my TJ. I wanted to keep the factory Moabs with 35s. As previously mentioned, hubcentric is the key to a safe spacer on a Jeep.
streetjeep2.5 Posted May 13, 2010 Author Posted May 13, 2010 Thanks for the input. Will shoot for the 1.25 spacers. BTW, its a 4x2 so no lift and 225/70R -15 tires. More a "cosmetic" than practical thing.
