October_V Posted April 18, 2010 Share Posted April 18, 2010 I have no junk yards to hunt in Juneau, anybody know a good place to shop for a replacement gas tank? I have a '90 4x4 SWB with the 4.0 Renix. I would think my current tank is approx 18 gallons. eBay has 18's and 23.5's. If I went large on a SWB, would it fit? Thanks for any help guys. josh- Link to comment Share on other sites More sharing options...
manche75 Posted April 18, 2010 Share Posted April 18, 2010 I just replaced mine this past weekend with one from carquest. I got it the day after i had ordered it. I think it was like $170 Straight-Up. Mine is a swb 4.0l too so pricing should be about the same. Link to comment Share on other sites More sharing options...
jimoshel Posted April 18, 2010 Share Posted April 18, 2010 A larger tank will not fit. They are to long. Link to comment Share on other sites More sharing options...
89eliminator Posted April 18, 2010 Share Posted April 18, 2010 i got mine from rockauto.com for i think $125 shipped. Link to comment Share on other sites More sharing options...
Wildman Posted April 18, 2010 Share Posted April 18, 2010 Where's the pictures of the leaking gas tank :dunno: Just where is the tank leaking???? At the O-ring for the sending unit?? At the supply line/return line on the sending unit cap?? Or, on the steel tank it's self?? I would say rockauto for your location, http://www.raybuck.com is another option. And no, you can not install a 23.5 LWB tank on a SWB MJ, it will hit the rear axle :eek: Just make sure you get a replacement tank for FI, one that has the reserve pan inside the tank. Link to comment Share on other sites More sharing options...
one_bad_MJ Posted April 19, 2010 Share Posted April 19, 2010 JB weld fixed mine costs 5.00 and 2 hours of your time Link to comment Share on other sites More sharing options...
87Chief Posted April 19, 2010 Share Posted April 19, 2010 :agree: Cheapest.. Link to comment Share on other sites More sharing options...
Eagle Posted April 19, 2010 Share Posted April 19, 2010 Are you certain the tank is leaking? Seems more often the leaks are where the two metal lines go through the fuel pump mounting flange. Link to comment Share on other sites More sharing options...
one_bad_MJ Posted April 19, 2010 Share Posted April 19, 2010 mine leaked on the outside twards the gas fill tube where all fo he road dirt and snow laid up in there. it has surface rust so i tool a pick and poked through the holesa nd cleaned them with a brass non spark wire brush on a drill then jb welded them wildmain siad thats the most common place for them to rot out. Link to comment Share on other sites More sharing options...
