October_V
October_V's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. I like to drive with the wind, or behind a big truck.
  2. I would love that bumper on mine. Where oh where did you score it? I just got my bushings from TeamCherokee. Red poly's.
  3. I understand that you would want to replace them with Ford 5.0L 19# injectors. They are a 4 hole spray and are drop in's. Should be better than stock, some believe they give better economy and more HP, but I doubt that.
  4. My cheap lift was not so cheap. I got under my 20 year old truck and needed lots of other stuff after the 40 bucks or so for shackles and pucks. Shocks, axle seals, leaf spring bolts/bushings, drag link, sway bar ends, steering stabilizer. Damn Lift
  5. Wow, I just lost my heat too. I was just going to swap in a new thermo, but I will keep an eye on this thread.
  6. Isn't it something like 86-89 the same? So what are you planning for the 2000 front end? Saving it or selling?
  7. These wires are from the Jeep wire harness, everything was cut and taped so I ordered a replacement dash harness plug to do the new in radio install proper and clean. I am inclined to agree with ur assesment of dimmer and power antenna. I'll have to dig into the dash again later and put these wires into the radio harness plug and see what happens but after I get more info.
  8. 1990 Comanche. I have 2 wires in the radio harness I can't ID. The blue with white stripe and the orange with black stripe. Any body know what these 2 are? I have the control head in and everything works just fine, I just hate not knowing what these are for. I do not have a power antenna. I can link a photo of these 2 wires later if needed. Image Not Found
  9. http://www.comancheclub.com/forums/view ... 71&start=0 here it is.
  10. As I understand it, if you look at the fancy Yellow/Red/Black after market ones for the HO series you will also cut out the oil puking in the air filter and just need to change one of the plastic vacuum line fittings on the intake. Here is a random link to VC's that I just pulled with google, http://www.jeep4x4center.com/jeep-valve-covers/ But I know there are others that know exactly what is needed to make one of these work on a renix head.
  11. Just a thought, my temp selector switch is non-op. I switch between hot and cold manually by moving the lever down low on the passenger side under the dash.
  12. I'll keep an eye on this thread to see when you are open to build more bumpers. They look really nice.
  13. Awesome! Thanks for the info! If I can't find them outside the dealer, I what to bring the dealer now.
  14. Bad news for me, no junkyards for me pilfer in Juneau. I will have to get the replacements new. I would like to save some money and stay away from the dealer/quadratec. I am looking to go to the hardware, off the self replacements. Grade 8, what diam, what length?
