Comanche Overhaul
Theres been lots of debate about lift from a spring over. It depends on your axle and how old your springs are. I have heard 7 with new springs and anywhere in between 5 to 7. Mine is only at right around 5 because my springs are old.
this is what i did today. took a little longer then hoped but the drivers door is off. hopefully tomorrow the passenger will come off a lot faster.
but before you all say well it shouldnt have taken that long well i didnt unscrew the door. i cut the bottom half of the hinge off and took a metal punch to it until it popped off. it was hard seeing as i waited for the lip on the piece of the door to bend. but then the pin snapped and the bottom half of the hinge came off. now i have removable doors. i do have another set of doors with power locks and windows I'm gonna use as full doors and gonna cut the original doors up into half doors. pics up tomorrow of progress on the passenger side.
for a little advice. anyone who wants to take there doors off like i did use an air chisel. i got the passenger door off in less then a hour.
now i jus gotta fix the doors and weld in new body panels for the body to be done. then put in a new clutch for the transmission to be set. i also picked up a set of 33x12.5r15 for $100. the rims however don't fit so ill need another set or install them on the stock ones?
ive recently started to work on the body work of the bed and the tailgate handle broke so now i need a new one. anyone selling one or kno where i can buy one? none of the salvage yards in the area have comanches. can i use one from another truck? any info you have can help.
yea i thought the same thing but i did research and what i found was that once you unscrew the door it never closes the same again and it can leak and what not. but i read on another forum that someone did it the same way and it worked out fine.
normally unless your hinge is toast you can use shimms to adjust tyhe door to being perfect again. but uhile you have the hinge off at least you can fix the known problem of the hinge seperating from the body :thumbsup:
Both things can happen. there's simply no guarantee that it'll bolt back up the first try.
and you might want to pop that request in the classifieds. :thumbsup:
  • 3 months later...
havent updated this post in awhile but ill be sure to put up some pics later. i was jus wondering if anyone has any info on some 6.5" lift kits. ive been looking at both rough country and OME kits. jus wondering what people think bout these. if anyone knows how or were i can get a cheap lift let me kno. id like 6+ and to run 35s.
  • 2 months later...
Ok so I got the truck on the road and took it out and broke the transfer case. It won't stay in 4wd. But I did pick up a new one for free. I am looking to piece together a lift kit for the truck tho. Does anyone have any suggestions on what parts I should pick up from where?
  • 2 months later...
The floors are all set and solid.
Got the new ax15 in and all set :)
31" tsl super swampers
They look soo aggresive. Just need wheel spacers now cuzz they do rub a little bit.
I just needed to take this pic. She looked so nice when i walked out of the bank.
The first day out and the transfer case breaks. WTF
  • 2 months later...
bought a nice 99 xj from a friend a couple months back.
he said there was an overheating problem with the truck. i ran it for a bit to hear the motor and to see what was wrong. upon further inspection i noticed that he just recently replaced the radiator hose and didnt install the clamp right so it leaked bad. so i got it to run fine. the kicker was i only spent 400$ on the thing.
i got the xj running fine but then the mj started acting up and i needed to make a choice keep the xj or keep the mj. that was an easy choice. GUT THE XJ!
no more front clip or doors
took out the engine bay wiring harness and next the drivetrain
took out as much of the interior as i could to update the comanche
