THIS would be the PERFECT MJ Bed....
Especially for anyone building an MJ715..
M101 trailer:
From this thread:
http://www.pirate4x4.com/forum/showthre ... 210&page=2
Pics above from:
http://www.whiteowl.com/trailers.html
There's actually an M101a1, an M101a2 & an M101a3, I'm trying to find the correct dimensions for all,
some say 76" long for the a1, others say 96' (one source even said 55" long :nuts: )
Either way it looks like it would be pretty easy to cut down.
The width between wheelwells seems dead on for us (~43")
Found this on another forum:
DIMENSIONS
Overall:
Length .................................................. ............................147 in. (373.38 cm)
Width .................................................. ............................73.5 In. (186.69 cm)
Height of Chassis .................................................. .................35 in. (88.9 cm)
Height of Cargo Trailer (M101A2 and M101A3):
Empty............................................. .....................................83 in. (210.82 cm)
Loaded............................................ ....................................79 In. (200.66 cm)
Cargo Body (Old Style):
Length............................................ ...................................76 in. (193.04 cm)
Width .................................................. ...........................65.5 in. (166.37 cm)
Height .................................................. ...............................18 in. (45.72 cm)
Tread .................................................. ..............................72 in. (182.88 cm)
Cargo Body (New Style) (M101A2 and M101A3):
Length............................................ ......................................100 in. (254 cm)
Width .................................................. ...........................73.5 in. (186.69 cm)
Height .................................................. ..........................19.84 in. (50.39 cm)
TOWING INFORMATION
Towing Attachment .................................................. ...............Drawbar Coupler
Towing Vehicle .................................................. ...............CUCV Series, HMMWV
Series, 2-1/2 Ton series,
5 Ton series
WEIGHTS
Payload (Maximum):
Cross-country .................................................. ...................1500 lb (681 kg)
Highway .................................................. .......................2250 lb (1021.5 kg)
(Personal note. I've towed 3,000 lb many times with no problem)
Empty:
Wheels .................................................. .........................1225 lb (556.15 kg)
Front Support Leg............................................... ................115 lb (52.21 kg)
Total 1340 lb (608.36 kg)
With Payload:
Wheels
Cross Country........................................... ....................2640 lb (1198.56 kg)
Highway .................................................. .....................3360 lb (1525.44 kg)
Front Support Leg
Cross-country........................................... ............................200 lb (90.8 kg)
Highway .................................................. .........................230 lb (104.42 kg)
Total
Cross-country........................................... .....................2840 lb (1289.36 kg)
Highway .................................................. ......................3590 lb (1629.86 kg)
Here's the thread:
http://www.steelsoldiers.com/trailers/30370-m101-dimensions.html
:agree:
That would be a good alternative for the MJ box :idea:
Looks easy enough to build too :brows:
And........wouldn't require the $250 per pair of MJ tail lights :yes:
Ebaying your taillights & tailgate could almost pay for the trailer. :smart:
Only issue could be the width:
I be it would still look great with the MJ lines, but narrowing it might be better for a trail truck (atleast on tight NE trails).
DIMENSIONS
Overall:
TOWING INFORMATION
5 Ton series
WEIGHTS
Payload (Maximum):
Empty:
With Payload:
Wheels
Front Support Leg
Total
Here's the thread:
Thanks for posting that. :thumbsup:
I actually found that thread, then could not find it again later. :nuts:
They list the width between the wheel wells elsewhere in that thread,
I thought it had said ~43", but re-reading the thread, it's posted as 45.5".
Ours is also under 48" ( :dunce: engineers), so 45.5" should be nearly dead on.
If you are half descent at fab work i think this could be a very cool look, plus you could have a trailer that matches the truck!
:D
Thanks for posting this up, i'm definitely going to look into doing this on mine, especially since my bed is beat to crap & i'm not very good with body work...
