89eliminator Posted October 10, 2006 Posted October 10, 2006 has anyone put rear disk brakes on their comanche? Is it easy/hard. I have all of the stuff for the brakes like rotors, calipers...
87manche Posted October 11, 2006 Posted October 11, 2006 not difficult. You'll want to bypass the load sensing valve in the rear so the discs get the right ammount of fluid. You can swap in a ZJ proportioning valve too, then it's like having factory discs.
mjeff87 Posted October 11, 2006 Posted October 11, 2006 Il'll let ya know in about a month :D I'm swapping discs onto the D44 I got. Like you, I already have all the parts (off a ZJ D44a in the junkyard) except the e-brake cables (which I forgot to get when I was down there this weekend, AGAIN). I'm gonna swap in a ZJ prop valve, too. Jeff
HOrnbrod Posted October 12, 2006 Posted October 12, 2006 BlueComanche - are you asking about rear disks on a D35 or D44 rear? If it's a D35, no need to swap out either the front prop valve or the rear load leveling prop, if they are working okay now with your drums.
Scott86mj Posted October 14, 2006 Posted October 14, 2006 I t was easy. Just Get ZJ disc brakes, TJ dana 44 axle retainer plates, redrill calipers retainer plates and backing plates to match flange pattern of you axle. Unless you have a C-clip axle then it should be a direct bolt in. If your have any questions let me know.
HOrnbrod Posted October 14, 2006 Posted October 14, 2006 Looks good! How much lift diid you gain w. the SOA? Also, I don't see it or is your e-brake cable hidden behind the spring?
Pete M Posted October 14, 2006 Posted October 14, 2006 An SOA lift varies. On any particular truck, going SOA will result in the truck being 5.5-6" higher than it was previously. But if you buy a front lift that advertises a certain height, the back end may not match the front because the rear height is relative and varies depending on the type of leafs used (2wd are about 1" shorter than 4wd) or how worn out or broken the old leafs are. Another variable is how much weight is in the bed. Some guys wheel with nothing but a spare tire, I have a custom rollbar, heavy bumper, and bring a bunch of spare parts/tools/gas/etc.
Scott86mj Posted October 14, 2006 Posted October 14, 2006 I used MJ brake lines and a clamp but I used the springs from zj. I got 5.5" on the SOA.
casey Posted October 18, 2006 Posted October 18, 2006 Scott, did you use the hardware from a ZJ 35 or 44 with discs to convert your 44? I figured they would bolt onto the 35 without much difficulty, but that looks sweet! We had a '98 ZJ for about 5 years and the 35 self destructed. The carrier bearings simply came apart. I saved the 35 that blew up for the disc set up. The ZJ 44 I replaced it with had the same brakes. BTW...Nice job. 8)
Scott86mj Posted October 19, 2006 Posted October 19, 2006 Casey it was a dana 35 out of a 95 zj. The dana 35 on your MJ has a different flange pattern. It is just off a little but you will have to redrill to match the pattern of your axle. Other than that it is easy to do. Check out this link it will show you how its done but that guy took his parts to a machine shop. I just drilled out myself with a drill press.http://www.pirate4x4.com/tech/billavista/Disc_brakes/index.html
HOrnbrod Posted October 27, 2006 Posted October 27, 2006 Scott; I did my ebrake a bit differently - used a slotted Ford clevis since I have Explorer rear disks.
bdjr Posted October 28, 2006 Posted October 28, 2006 hey hate to be stupid but where are your perchs. is it just the pic or are the not there? :dunno:
