how much lift
MO, I just read the specs on your 5" lift. It says 4.5" springs plus 0.75 spacers. That 0.75 spacer may make the difference. The problems I posted about was 4.5" springs only. 1.75" spacers more than solved it, 0.75 might have been enough (it seems to be in your case) but I used what I happened to have laying around.
so Ill need to buy coils
its not like G-cherokee coils on a TJ
wow with a SOA ill need to lift the front 6.5'' so it means ill have to change the LCA and UCA ......... :wall:
there goes the low budget
And track bar... and sway bar links... and shocks... and brake lines... and you'll want big tires... so you'll want to regear...
I'm running 33's on my truck with 3.07 gears and i still get 28 mpg straight 6 renix 5-spd
my truck turns them just fine.
doubt that....i ran 33's w/3.07 and got 12mpg...have you changed the speedometer gear for the tire size change so that you are actually getting the correct odometer reading instead of one thats way off....i have 4.10's now and get roughly 22MPG...plus the comanche 4.0 5spd from the factory was only rated at 23MPG
Hey for the tires.. If you don't mind switching tires around alot, you could use your 35s on your YJ on your MJ.. If the bolt pattern is right... I know on the TJ it's 5x4.5 not sure on YJ or MJ.
Just a thought.
Just a thought.
non cuze I got grand wagoneer diff on my YJ and the bolt pattern is 6x5.5
and there both 35'' now no need to change
