TooTall Posted March 2, 2010 Share Posted March 2, 2010 can 35 inches of meat be put on 6.5 inch of lift or am i going to have to cut or think of a smaller tire size????? :eek: Link to comment Share on other sites More sharing options...
Pete M Posted March 2, 2010 Share Posted March 2, 2010 Nothing wrong with 33s. :thumbsup: What are you doing for gearing? Link to comment Share on other sites More sharing options...
james750 Posted March 2, 2010 Share Posted March 2, 2010 You'll have to cut. Technically they will fit. But when your wheel travels up, it will rub because the wheel wells are not large enough to handle that size tire. Link to comment Share on other sites More sharing options...
TooTall Posted March 2, 2010 Author Share Posted March 2, 2010 411s but eventually a conversion on transfercase or atlas won't be doing many crawls at all mainly for hunting truck! Link to comment Share on other sites More sharing options...
Pete M Posted March 2, 2010 Share Posted March 2, 2010 35s only give you 1" more ground clearance. Link to comment Share on other sites More sharing options...
TooTall Posted March 2, 2010 Author Share Posted March 2, 2010 thanks sounds like 33's are the best then. :nuts: Link to comment Share on other sites More sharing options...
Pete M Posted March 2, 2010 Share Posted March 2, 2010 less trimming and fewer headaches. :D Link to comment Share on other sites More sharing options...
Philistine Posted March 2, 2010 Share Posted March 2, 2010 less trimming and fewer headaches. :D That's true but, they're not 35's! Link to comment Share on other sites More sharing options...
redneck23ms Posted March 2, 2010 Share Posted March 2, 2010 they will fit but you will need to do a bit of trimming and bumpstopping. i run 36"tsl(they run small for 36s though) on the same amount of lift with no trouble. Link to comment Share on other sites More sharing options...
cracker Posted March 2, 2010 Share Posted March 2, 2010 You can run 42s on 7" of lift :D Link to comment Share on other sites More sharing options...
mvusse Posted March 2, 2010 Share Posted March 2, 2010 I ran 33s with 6.5" lift and decided to cut my front fenders instead of bump stopping. Travel limited by shocks, lots of flex, it worked well. I got 35s about a month ago, had to cut more on the front fenders, had to cut some on the rear fenders (rear sits at ~8"), but not really noticeable, and now the inside of the front fenders is in the way. Can't cut that. There are no sharp edges to cut my tires, but I will still have to bump stop. One of these days I will stuff the tire up against the top of the wheel well tight enough that it can't turn with a front locker that will force it to turn and blow an axle shaft or u joint. But I love my tires. Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted March 2, 2010 Share Posted March 2, 2010 I run 35" tires on my MJ with 6.5" of lift and have trimmed VERY little on the front and have no issues. Uptravel is not everything... bumpstop it correctly and it will force the other side down. Anyone who tells you that 6.5" of lift is not enough for 35's does not have their suspension setup correctly. Here is a pic of the area's I've trimmed on the front. I have not touched the area's that the flare is still attached. The rear I did trim a bit and I'm running TJ flares. I did this more for getting rid of the rust issues than I did for tire clearance. It stuffs the 35's without issues in the front. I also run 35's on my XJ with only 5" of lift and very minimal trimming (have not trimmed higher than the body line on the flare area). I have no issues stuffing them either while offroad. I score over an 800 on the RTI ramp (30deg). Link to comment Share on other sites More sharing options...
Pete M Posted March 2, 2010 Share Posted March 2, 2010 can 35 inches of meat be put on 6.5 inch of lift or am i going to have to cut or think of a smaller tire size????? :eek: What are you doing for gearing and axle strength? Link to comment Share on other sites More sharing options...
