ComancheKid45 Posted January 22, 2010 Share Posted January 22, 2010 Alright well this isnt going to be immediate by any means but i have a friend with a 91 YJ that upgraded to full size Axles, Its a 4 cylinder with a Dana 30/35 combo, He offered to give me his gears (not axles just gears) for free, to my knowledge they should be 4:10 (4 cyl, mt), Could at a later time these gear sets be swapped into my MJ Axles? (currently at 3:55), or is there alot more to it than that? I would have a Garage or experienced mechanic do it 1 of these days but is it worth my time to keep these things around if i get them? Link to comment Share on other sites More sharing options...
Geonovast Posted January 22, 2010 Share Posted January 22, 2010 Yes, the gears are the same between YJ and MJ Dana 30/35s Double triple check the ratio. 2.5 could have received 3.55 if the trans is an AX-4. My first MJ is a 91, and it came with 2.5/AX-4/3.55 Link to comment Share on other sites More sharing options...
ComancheKid45 Posted January 22, 2010 Author Share Posted January 22, 2010 Alright, ill have 2 check them again, i know most 4cyl manuals had 4:10s but theyre are exceptions Link to comment Share on other sites More sharing options...
Pete M Posted January 22, 2010 Share Posted January 22, 2010 why on earth would he pull the gears? :hmm: the axles are valuable with the gears installed and set up. take those out and they're just scrap. :dunno: Be aware that used gears have no guarantee of ever running quiet installed in another axle. Like a lot of moving parts (bearings, U-joints, tires), they develop a wear pattern and the chances of precisely matching that pattern are pretty slim. Link to comment Share on other sites More sharing options...
Eagle Posted January 22, 2010 Share Posted January 22, 2010 Double triple check the ratio. 2.5 could have received 3.55 if the trans is an AX-4. My first MJ is a 91, and it came with 2.5/AX-4/3.55 They are coming out of a YJ. I don't believe the YJ was ever offered with a 4-speed. Link to comment Share on other sites More sharing options...
Geonovast Posted January 22, 2010 Share Posted January 22, 2010 Double triple check the ratio. 2.5 could have received 3.55 if the trans is an AX-4. My first MJ is a 91, and it came with 2.5/AX-4/3.55 They are coming out of a YJ. I don't believe the YJ was ever offered with a 4-speed. I've never heard of them coming with an AX-4 either, but hey, it's a Jeep. Especially with axle gearing, it never hurts to triple check anything. Link to comment Share on other sites More sharing options...
ComancheKid45 Posted January 22, 2010 Author Share Posted January 22, 2010 He twisted off the input shaft yoke of his 35 and upgraded.....the axles themselves i don't think have any issues other than that, He just offered me the gear sets since they would be an upgrade 2 me, lol his reasoning othewise is left to the wondering mind :shake: :dunno: :rotf: Link to comment Share on other sites More sharing options...
Geonovast Posted January 22, 2010 Share Posted January 22, 2010 Now... I may be wrong with this, having never had gears out of an axle.. but aren't the pinion and 'input' shaft on an axle the same piece? Link to comment Share on other sites More sharing options...
Pete M Posted January 22, 2010 Share Posted January 22, 2010 yeah, if he twisted off the yoke, what shape is the pinion in? They may seem free now, but it'll cost hundreds to get them installed. Link to comment Share on other sites More sharing options...
ComancheKid45 Posted January 22, 2010 Author Share Posted January 22, 2010 Ha Ha yeah i didnt figure it would be an easy and cheap task......i kinda think i should just pass these up and save the space of storage in my garage for something more worthwhile, lol Link to comment Share on other sites More sharing options...
Geonovast Posted January 22, 2010 Share Posted January 22, 2010 It might be worth it to grab the front gears if they're in good shape... but not really the rears. The D35 isn't worth putting the money into for a re-gear. Link to comment Share on other sites More sharing options...
88SporTruck Posted January 22, 2010 Share Posted January 22, 2010 D35 gears that have had the pinion yoke sheared off? RUN don not walk RUN away from that one. Take the front gears if they are free and in good shape but those rears are basically scrap. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted January 23, 2010 Share Posted January 23, 2010 if he twisted off the pinion yoke, the rear gears are JUNK. front gears are probably decent, but you need the carrier as well. I had jpdocdave swap my front d30 gears into an empty housing when I bent my d30 front....I didn't have another 4.10 set. the wear pattern is PERFECT...but he has 2500 in tools just for doing gears, and knows his crap. Rule of thumb....buy a new install kit for them, but get ALL of the old bearings and shims, as well as carrier...even if you have to pay for a carrier for him to use with his upgraded gearset. This will give the installer the most knowledge of how the gears were set up as possible...meaning setup will be easy. I'm told it's easier to set up gears with the axle in the vehicle, because the axle can't move when torque is applied. Dave did mine out of the truck, but would have preferred it in the truck. I used my old bearings, but he had to swap a good carrier bearing from my 3.07 carrier that came out of the "new" axle...quite a chore I'm told, as even with the proper bearing seperator/puller, they don't typically come off in good shape. -Pat Link to comment Share on other sites More sharing options...
jpdocdave Posted January 23, 2010 Share Posted January 23, 2010 I had jpdocdave swap my front d30 gears into an empty housing when I bent my d30 front....I didn't have another 4.10 set. the wear pattern is PERFECT...but he has 2500 in tools just for doing gears, and knows his crap. Rule of thumb....buy a new install kit for them, but get ALL of the old bearings and shims, as well as carrier...even if you have to pay for a carrier for him to use with his upgraded gearset. This will give the installer the most knowledge of how the gears were set up as possible...meaning setup will be easy. I'm told it's easier to set up gears with the axle in the vehicle, because the axle can't move when torque is applied. Dave did mine out of the truck, but would have preferred it in the truck. I used my old bearings, but he had to swap a good carrier bearing from my 3.07 carrier that came out of the "new" axle...quite a chore I'm told, as even with the proper bearing seperator/puller, they don't typically come off in good shape. -Pat thanks for the good words pat. i've been doing gears for a while, and i've spent a ton of money on tools souly used for gear installs, and i'm still learning better proper technique, and even better tools. setting up the gears out of the vehicle is ok if you have a way of securing it, just on jack stands does suck. there's also different style pullers that can remove the bearings without damage whatsoever, and i will be buying the dana specific puller soon. my advise on that is find someone that really knows what they're doing, not just thinks they know, and get their help. i agree with pete, they should've stayed in the axle, and there's a big chance they could make noise if you install them. if the rear is even useable. Link to comment Share on other sites More sharing options...
