mopwrd340 Posted January 14, 2010 Share Posted January 14, 2010 i have a chance to pull parts a 96 gc i pulled the seats to replace the buckets on my 88 manche what other parts could i use it has a 4.0 with 59.000 on it i could get the eng for $400 if i wanted any other drive train parts work thanks Link to comment Share on other sites More sharing options...
Geonovast Posted January 14, 2010 Share Posted January 14, 2010 There really isn't too much worth grabbing off a ZJ. The motor seems like a decent grab, I believe there are some differences in the ZJ motors, but pretty sure they can go in place of an XJ/MJ HO one. Link to comment Share on other sites More sharing options...
KYMJ Posted January 14, 2010 Share Posted January 14, 2010 If it has skids and towhooks, get those for trading/selling. Probably doesn't, however. Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted January 14, 2010 Share Posted January 14, 2010 Rear disc brake setup can fairly easily be adapted to other axles (D44 and Chrysler 8.25"). Link to comment Share on other sites More sharing options...
dasbulliwagen Posted January 15, 2010 Share Posted January 15, 2010 The front Dana 30 is a direct replacement for the MJ, But it is probably low pinion. Wheels will bolt up if they are ones you like. Link to comment Share on other sites More sharing options...
mopwrd340 Posted January 15, 2010 Author Share Posted January 15, 2010 no skids or hooks it came in with 4 donuts for tires hopefully i will be able to get the motor out of it when he gets tired of looking at it lol he bought it wrecked to put the t/c case in one and to put the motor in another .motor was for a 94 gc which i got to run after 2 years by grouding out the alarm system didnt use the t/c either ne needed a 231 and this was a 242 Link to comment Share on other sites More sharing options...
comanche87 Posted January 15, 2010 Share Posted January 15, 2010 The front Dana 30 is a direct replacement for the MJ, But it is probably low pinion. Wheels will bolt up if they are ones you like. i didnt know the zj front axle was the same. hmm thats an idea if need to replace at one point. Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 15, 2010 Share Posted January 15, 2010 Grab the steering box. It has a quicker ratio (12.7:1) vs. the 14.1:1 MJ box. Bolt-in too. But since it's a 4.0 the sway bar and tie rod won't do you any good. :D Link to comment Share on other sites More sharing options...
mopwrd340 Posted January 15, 2010 Author Share Posted January 15, 2010 ok i will pull the steering box is it also worth pulling the booster and master cylinder to i will use this in the future.i almost haved it ready to drive i am changing the cooling system to a open one :cheers: Link to comment Share on other sites More sharing options...
