DJM/78 Posted January 2, 2010 Share Posted January 2, 2010 I have noticed some of you guys have the rear interior panel under back glass . My truck came with the bench seat that I swapped to buckets and does not have that panel . What is that panel called ? Where can I find one ? Does anyone have one , pref. gray or black ? Or should I just make one ? Thanx Link to comment Share on other sites More sharing options...
Jeepcom23 Posted January 2, 2010 Share Posted January 2, 2010 Ive got the gray plastic piece that goes underneath the back glass for sale :D Link to comment Share on other sites More sharing options...
DJM/78 Posted January 2, 2010 Author Share Posted January 2, 2010 Is it a carpeted version or was that custom ? I don't know anything about them . How much ? Is it in good condition ? Link to comment Share on other sites More sharing options...
tallon2064 Posted January 2, 2010 Share Posted January 2, 2010 It is actually two separate pieces one plastic that goes directly under the window, and a cardboard one with carpet that goes to the floor from there. They both attach with clips, the plastic piece attaches with clips similar to the door panels, and the cardboard one has a type of spring clip. You could probably fab the cardboard/carpet one but the other you are probably gonna have to find at a salvage yard :wall:, which sounds a lot easier than it is, or purchase. Not sure if it was standard on all models or not. :dunno: Hope this helps a little. Link to comment Share on other sites More sharing options...
DJM/78 Posted January 2, 2010 Author Share Posted January 2, 2010 Thanks , there just isn't many to look at around here . :rant: Link to comment Share on other sites More sharing options...
Pete M Posted January 3, 2010 Share Posted January 3, 2010 I don't seem to have a photo of it :hmm: but I removed that panel long ago and replaced it with a sheet of 3/4" plywood bolted to the cab and then a piece of speakerbox carpet glued over it Now the back wall is useful! I can hang fire extinguisher brackets and such instead of that crap rolling around on the floorl. :D here you can see the carpet and that I covered the plywood and then on up all the way to the window edge. Link to comment Share on other sites More sharing options...
SuperWade2 Posted January 3, 2010 Share Posted January 3, 2010 Mine more or less matches the Carpet...and the plastic is the same are the rest of the pillar trim. If you posted a WTB and what color interior you have, some one might have one laying around... Link to comment Share on other sites More sharing options...
DJM/78 Posted January 3, 2010 Author Share Posted January 3, 2010 Thanks guys , that looks nice and clean , how I like it . :clapping: Link to comment Share on other sites More sharing options...
Jeepcom23 Posted January 3, 2010 Share Posted January 3, 2010 ive just got the plastic piece. You, a fellow CC member, can have it for shipping. Link to comment Share on other sites More sharing options...
james750 Posted January 3, 2010 Share Posted January 3, 2010 I found the carpet piece in a junkyard MJ. Link to comment Share on other sites More sharing options...
maddzz1 Posted January 3, 2010 Share Posted January 3, 2010 I might know someone with the black carpet piece, I will ask him. In my MJ I think the plastic piece was rattling due to a broken clip and the genius that used to own it must have thought it was the carpet piece and put two drywall screws thru it and right thru the back of the cab. I ASSume, to hold it in place. :fs1: :wall: :wall: Link to comment Share on other sites More sharing options...
