neohic Posted December 5, 2009 Share Posted December 5, 2009 Does anyone know what trans and transfercase would be behind a 1985 Cherokee with the 2.1L diesel? I'm into weird Jeep stuff and I found one for sale pretty cheap... the guy says it runs like a champ, but the trans falls out of gear and the transfer case growls. I know the early front axles and drive shafts in them were junk, but I have a 30/35 set in 4.10 gears that are just sitting around. It has a five speed in it... maybe an AX-15 and a 231 combination would bolt up behind it? Any help or advice would be great! Link to comment Share on other sites More sharing options...
mvusse Posted December 5, 2009 Share Posted December 5, 2009 Don't know about what bolts up, but 4.10 gears sound awfully steep for a diesel. Link to comment Share on other sites More sharing options...
Pete M Posted December 5, 2009 Share Posted December 5, 2009 if it's a manual trans it should be an AX-5, and the t-case for an 85 should be an np-207. AX-15 won't bolt up, but anything from any year 2.5L will. :thumbsup: my Liberty CRD has 3.73s. I'd have no problems with 4.10s behind a diesel with even less power. :thumbsup: Also, there's nothing really different about the front axle in an 85 (about the same as any MJ front axle), but yes, the front driveshaft was pretty darn pathetic. :D Link to comment Share on other sites More sharing options...
mfpdm Posted December 5, 2009 Share Posted December 5, 2009 If the diesel has the same bellhousing bolt pattern that the 2.5L has, he could use one of the hard to find dakota AX-15's bellhousing that came behind their 4 banger. Forgot what year they were but it's the cheap way to get a AX-15 behind our 2.5L and he could use whatever AX-15 he can get his hands on then. I'm thinking early 90's. :dunno: Or am I out to lunch on this one. :???: :cheers: Link to comment Share on other sites More sharing options...
Pete M Posted December 5, 2009 Share Posted December 5, 2009 Hmmm... For 2.5s it's not quite as easy as just finding that bellhousing. But the 2.1 might not have as many issues. hard to say since I can only assume the 2.1 would be similar to the 2.5 inside the bellhousing. hmmm... Blazing new territory... :D Link to comment Share on other sites More sharing options...
mnkyboy Posted December 5, 2009 Share Posted December 5, 2009 Ive read about the dakota bell housing swap,from what i can tell its not hard to do. here is a write up i found http://www.naxja.org/forum/showthread.php?t=956031 advance adapters also makes a conversion kit to go AX5-AX15 but its $450-$500 Link to comment Share on other sites More sharing options...
Pete M Posted December 5, 2009 Share Posted December 5, 2009 after much searching, I finally found mention of a CPS mounting location (the one on Pirate), which apparently does exist on the Dak housing. :typing: still doesn't apply to the 2.1 of course. :D Link to comment Share on other sites More sharing options...
mfpdm Posted December 5, 2009 Share Posted December 5, 2009 Ive read about the dakota bell housing swap,from what i can tell its not hard to do.here is a write up i found http://www.naxja.org/forum/showthread.php?t=956031 advance adapters also makes a conversion kit to go AX5-AX15 but its $450-$500 I was looking for that link to throw in but couldn't find it. :thumbsup: Went to save the link and I found were I put it, under AX-15 swap. :doh: Here's a pic of the two side by side from that link. Shows a good comparison of the bellhousings. Guy did a nice write up and the parts list is great. Oh and like Pete said, it's a little more than just swapping the bellhousing. :cheers: Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 5, 2009 Share Posted December 5, 2009 Don't know about what bolts up, but 4.10 gears sound awfully steep for a diesel. not too steep. a 2.1 renault turbo diesel with 5 speed would need (and comes with) 4.10 gears. the transmission is an ax5. the transfer case is an np207. there is one problem, if you're going to fix it...you need to know how to pull an ax5 apart. the reason for this is that the renault 2.1 ax5 has a different input shaft than the typical jeep ax5. an ax15 WON'T bolt behind a 2.1, as there is no bellhousing to make it fit.. how much is this cherokee? you could probably make a quick buck selling it to me...I'm always looking for parts for my 86 comanche diesel. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 5, 2009 Share Posted December 5, 2009 If the diesel has the same bellhousing bolt pattern that the 2.5L has, he could use one of the hard to find dakota AX-15's bellhousing that came behind their 4 banger. Forgot what year they were but it's the cheap way to get a AX-15 behind our 2.5L and he could use whatever AX-15 he can get his hands on then. I'm thinking early 90's. :dunno: Or am I out to lunch on this one. :???: :cheers: nice idea, but the 2.1 has a completely different bellhousing from a 2.5. Link to comment Share on other sites More sharing options...
neohic Posted December 5, 2009 Author Share Posted December 5, 2009 the transmission is an ax5. the transfer case is an np207. Any idea what the spine count is on the 207 and if aything else bolts up in its place? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 5, 2009 Share Posted December 5, 2009 the transmission is an ax5. the transfer case is an np207. Any idea what the spine count is on the 207 and if aything else bolts up in its place? 21 spline. a long input 21 spline np231 will bolt up in it's place. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 5, 2009 Share Posted December 5, 2009 ...I hope you intend this for daily driving. the renault 2.1 puts out 89 horses at best, and less than 200ft/lbs torque. the starters go out frequently, and are a 3 hour job to replace, if you can get them. Link to comment Share on other sites More sharing options...
neohic Posted December 6, 2009 Author Share Posted December 6, 2009 Any idea what they get for mileage? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 6, 2009 Share Posted December 6, 2009 Any idea what they get for mileage? city around 26, highway up to 35mpg. my dad's 86 comanche turbo diesel has a cracked head and a crack in the #3 cylinder wall., and still gets 33mpg etc. these are an interference motor. they require frequent timing belt adjustment, and the timing belt MUST be replaced every 90,000 miles. chances are, if you're buying it, you should replace the timing belt. do it now before it blows. if it blows, it will break the rocker assemblys off the valve train, and maybe bend valves...the only parts place for them that I've found was in iowa, but they're out of business. that aside, you *may* still be able to find a winnebego lesharo parts place that has parts for it. there are no interchangeable parts w/ any other jeep when it comes to things like the alternator, power steering pump, vacuum pump (yes, it has a vacuum pump...if it goes you cannot replace it except used parts. if it goes, you will have no CAD functions and no heat), and even the starter is used. it's a paris rone (or however you spell it) starter that you'll be lucky to find anywhere. all in all, very rare parts. Link to comment Share on other sites More sharing options...
mnkyboy Posted December 6, 2009 Share Posted December 6, 2009 I checked that starter on Napa pro link there are 3 options BSH SR6505X bosch direct drive $385 list NAE 17005 direct drive Paris-Rhone $223 list NAE 17085 Gear reduction Paris-Rhone $200 list they are not showing them in stock but might be worth checking there were also 3 alternators listed 2 Paris-Rhone and 1 Bosch i wonder if the bosch parts might be easier to find. I'm getting listings for most of the parts but they are all saying none in stock. Link to comment Share on other sites More sharing options...
Pete M Posted December 6, 2009 Share Posted December 6, 2009 My family's Libby CRD is only 3 years old and certain parts can be hard to come by. I couldn't imagine a 20 year old diesel. :wall: Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 6, 2009 Share Posted December 6, 2009 I've checked with napa and the parts are in their list, but they can't get them (or don't want to take the effort to try. Pete, I picked up a complete, BRAND NEW motor for the diesel for $75 on some guys trailer...noticed it from the oil pan, it was upside down and destined for scrap because he couldn't figure out how to make it work as a log splitter motor :P Link to comment Share on other sites More sharing options...
neohic Posted December 6, 2009 Author Share Posted December 6, 2009 This was fun, but I moved too slow on it... the guy sold it to some kid who said he would lift it and "go out and play with it". :( Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 6, 2009 Share Posted December 6, 2009 This was fun, but I moved too slow on it... the guy sold it to some kid who said he would lift it and "go out and play with it". :( crying shame. I hate when idiots don't know what they have, and don't care. that thing may as well have gone to cash for clunkers... a diesel cherokee is WAAAY more than any hick can handle Link to comment Share on other sites More sharing options...
Automan2164 Posted December 6, 2009 Share Posted December 6, 2009 This was fun, but I moved too slow on it... the guy sold it to some kid who said he would lift it and "go out and play with it". :( :( Rob L. Link to comment Share on other sites More sharing options...
freakjeep93 Posted December 6, 2009 Share Posted December 6, 2009 but it off the kid seriously thats a nice find Link to comment Share on other sites More sharing options...
