Whats up I am new to this site , been wanting to post pics for a while.
This is my new truck its a 2-92 build, for the most part is still in good shape. :chillin:
Thanks !!! I have learned a bunch from this site :bowdown:
These picks are after about two weeks worth of work.
more to come :chillin:
Welcome! Seems you have a valentines MJ...
Nice truck. Enjoy your stay here!
Could you help us out about your TJ bucket conversion? I find the seats in my '03 to be the most comfortable things in the world and would love to have something like them in my MJ.
I have one pic of the mounts . hope this will help .
I started by using a set of clean mounts from a 95 xj and a pair of Best Top tj seats for a newer model
the seats made it easy because the aftermarket seat bolts are adjustable . just move the bolt bracket to line up with
the floor bracket holes . once you have that you can start to center them where you need them in the truck.
This is where the fun begins, stock xj brackets are too tall in the back because xj s have flat floor pans. You can cut the bracket
but i saw that as time consuming and i still wanted the stock sliders to work. What i did was use the upper stock floor bolt (hump side) on
both seats just to center the seat in the truck . with the one bolt on each seat i could see where the the three other holes would line up.
xj brackets do not line up with the stock bolts so , I used my old trusty pal (block o wood) and his friend rubber hammer. i dented neat clean
square grooves where the rear mounts hit the floor . You need about a half inch down thats all I was amazed at how thin the floor pan is so
using grade 8 bolts and big ol gangster grade 8 washers I leveled the seats best i could and drilled the three other holes .
I would use steel washer plates under the truck large as possible bolt right through and bolt it all down together.
I will admit I spent a soapbox.gif load of time in the cold and dark on this one. I m 6 foot 4 and the seat have to be all the way back
and they only fit one way , But I have to agree the tj seats are the best ive ever had :banana:
If you guys want I can post a pic writ-up with more detail. :yes:
ok, ok, you people with badass looking trucks and the upgraded interior should stop posting pictures. :rotfl2: it makes me think to much about mine and how none of that cool stuff will happen to it in the near future :( :rotfl2:
Thanks !!! I plan on doing allot more restoration , It's always been a dream of mine to have one of these trucks , all brand new
and badass like . It's also my daily winter driver . I just broke the 200,000. mark on the od and she still runs strong.
My little gem.
Hey if I ever get rid of some the stock parts I'll post them!!!!! :cheers:
Nice truck. I would love to find a HO. I will just keep swapping them.
Do us a favor and change your sig. Unless my eyes are playing tricks on me. Your truck is a short box.
same goes for me! i wish i had any extra cash bcuz I'm diggin this MJ
welcome to CC :thumbsup:
