tdkoon Posted December 5, 2011 Share Posted December 5, 2011 Ok. If I can get a full harness from a newer xj, I CAN make it work with my current drive train though? Link to comment Share on other sites More sharing options...
HKB3 Posted September 1, 2012 Share Posted September 1, 2012 Bumping an old thread rather then starting a new one. Are the pin outs the same for a 1992 MJ 2.5L & 1992 MJ 4.0L? I have a lot of wiring ahead, I want to swap in a replacement fuse panel, A/C, pw, pl from a HO era XJ. I will be keeping the MJ dash just replacing the heater box. Thanks Link to comment Share on other sites More sharing options...
MiNi Beast Posted October 4, 2012 Share Posted October 4, 2012 On 5/30/2011 at 2:53 AM, mfpdm said: Yep like shelby said. :thumbsup: The "P" doesn't show in your diagram because it is not used however you will see it labeled on the flat connector on the steering column. :cheers: I understand all this but what I'm missing is a 11 pin flat. I had one on my old steering column, MJ one but not on my XJ one, so what does that mean? Link to comment Share on other sites More sharing options...
MiNi Beast Posted October 4, 2012 Share Posted October 4, 2012 On 5/30/2011 at 12:48 AM, dave92cherokee said: I'm working on getting the wiring done on the manche. It's a full 93 dash, harness, everything and I'm having trouble placing one last wire. It says that pin 11 on the XJ black connector (in my case white/tan) needs to connect to pin P on the turn hazard switch. However on the HO dash and harness I see no such pin and wanted to see if anyone could tell me which wire to splice into. Here's a couple of pictures from the FSM for an 88 and a 93 showing the two differences. Here's the 88: Here's the 93: Thanks for the help ahead of time as this thread has saved me a major headache trying to trace out all the wires. dealing with same issue now myself. What do you do when you don't have the old column and have no 11 pin flat coming out of your column well I just figured out what you do. instead of running the white and tan wire out of the xj black connector to "P",( which you do not have with newer column), just splice into tan and dark green wire (stop and rh turn wire) that runs out the connector in same area, This should take care of the brake light issues. :) Link to comment Share on other sites More sharing options...
Lee21490 Posted November 17, 2012 Share Posted November 17, 2012 Spent hours figuring this out, Figure i'd post it here so no one has to mess with it like i did. If you do a HO Full dash / STEERING COLUMN swap like i did, Instead of running the brake lights to the 11 pin flat connector in the first post.. The brake lights go to Pin 14 (empty pin) On the multi-function/Turn signal/Hazard switch. Link to comment Share on other sites More sharing options...
Slifter Posted April 19, 2013 Share Posted April 19, 2013 thank you thank you thank you... left my trailer wiring hanging and rolled over it, this was very useful.... Link to comment Share on other sites More sharing options...
bottomline89 Posted January 28, 2014 Share Posted January 28, 2014 I'm trying to do this exact thing with a 96 and i cannot find the diagram for the plug that comes from the xj dash. has anyone else had this problem? Link to comment Share on other sites More sharing options...
Herc Posted June 16, 2014 Share Posted June 16, 2014 Bumpin this back up, excellent thread sir! very enlightening. :cheers: Link to comment Share on other sites More sharing options...
WiscoXJ Posted January 26, 2015 Share Posted January 26, 2015 Awsome info Link to comment Share on other sites More sharing options...
WiscoXJ Posted January 27, 2015 Share Posted January 27, 2015 Maybe i missed it but I'm swapping a 94 HO xj into a 90 Comanche with the column shift. I'd like to leave the comanche column shift in. Is that connector plug and play or do i have to rewire that as well? Link to comment Share on other sites More sharing options...
Futurecomancheowner Posted April 10, 2015 Share Posted April 10, 2015 I am doing this harness adapter to wore my 92 xj harness to my 88 mj rear harness, and have some leftover wires after soldering by and following the charts, am I supposed to have leftover wires? Btw the xj harness I am using is from a cherokee laredo with all of the power options in it. Link to comment Share on other sites More sharing options...
WiscoXJ Posted April 10, 2015 Share Posted April 10, 2015 According to the charts what wires are left? I did it for the ho swap and had the hazard wire and parking brake one left over Link to comment Share on other sites More sharing options...
Futurecomancheowner Posted April 10, 2015 Share Posted April 10, 2015 I'll have to check tonight Link to comment Share on other sites More sharing options...
Futurecomancheowner Posted April 10, 2015 Share Posted April 10, 2015 I still have pins 7,8,9,10,11,12,13,14,15,16 sticking out not soldered to anything on the black HO xj dash harness. And on the grey HO xj dash harness I still have pins 8,11,12,13,14,15,16 to connect. What do I do with These wires? the chart I followed was the HO xj dash to rear renix mj harness, but it doesn't say where to connect these wires? Link to comment Share on other sites More sharing options...
Futurecomancheowner Posted April 10, 2015 Share Posted April 10, 2015 If I'm correct the two xj connectors (black and grey) should have 32 pins all together, and the two mj connectors (black and grey) should only have 16 pins total, so unless I'm missing something shouldn't there be 16 pins from the two xj connectors (black and grey) leftover? Link to comment Share on other sites More sharing options...
WiscoXJ Posted April 10, 2015 Share Posted April 10, 2015 On 4/10/2015 at 4:19 PM, Futurecomancheowner said: I still have pins 7,8,9,10,11,12,13,14,15,16 sticking out not soldered to anything on the black HO xj dash harness. And on the grey HO xj dash harness I still have pins 8,11,12,13,14,15,16 to connect. What do I do with These wires? the chart I followed was the HO xj dash to rear renix mj harness, but it doesn't say where to connect these wires? read through this list: pin 1 (db/or) Speaker return right rear pin 2 (db/wt) Speaker feed right rear pin 3 (or/bk) panel illumination pin 4 (bk) ground pin 5 (pk) courtesy lamps pin 6 (br/lb) speaker return left rear pin 7 (br/yl) speaker feed left rear pin 8 pin 9 (yl) switched ground pin 10 (lg) seat belt switch pin 11 (br/rd) rear wiper run pin 12 (wt) rear wiper park pin 13 (or/vt) lock relay pin 14 (pk/wt) unlock relay pin 15 (vt/yl) security alarm liftgate pin 16 (pk/or) keyless arm input 92 XJ Black body connector (wire colors in parentheses): pin 1 (dg/tn) Fuel Pump pin 2 (tn/dg) Right Rear Turn Signal pin 3 (db/rd) Parking Lamps pin 3 (db/rd) Parking Lamps pin 4 (db) Fuel Gauge pin 5 (br/lg) Backup Lamp Signal pin 6 (lg/bk) Left Rear Turn Signal pin 7 (gy/or) Brake Pressure Warning SW/ Park Brake Light pin 7 (gn) Brake Pressure Warning Switch pin 8 (bk/rd) Rear Defogger pin 9 pin 10 (bk/wt) Rear Washer Feed pin 11 (wt/tn) Stop Lamps pin 11 (wt/tn) Stop Lamps pin 12 pin 13 pin 14 pin 15 (db/or) Illuminated Entry Signal pin 15 (dg/or) Right front door security pin 16 (lg/or) Left front door security the pins you haven't connected are things the MJ doesn't have. I unpinned those wires from the harness. with a small screw driver you can push the tab up un pull out the wires. Link to comment Share on other sites More sharing options...
WiscoXJ Posted April 10, 2015 Share Posted April 10, 2015 don't forget about these though Pin 7 on XJ Black connector needs to be attached to the E-brake switch.* Pin 11 on XJ Black connector, need to run a wire to pin P on the turn signal/hazard switch.(11 pin flat connector on lower steering column) This will provide proper wiring for the brake lights. Link to comment Share on other sites More sharing options...
Futurecomancheowner Posted April 10, 2015 Share Posted April 10, 2015 Thanks, that's what I initially thought, until I read further and you guys were saying you didn't have any extras Link to comment Share on other sites More sharing options...
WiscoXJ Posted April 10, 2015 Share Posted April 10, 2015 technically no extra's for the mj. if you wanted all the power options youd have to keep it all Link to comment Share on other sites More sharing options...
Futurecomancheowner Posted April 12, 2015 Share Posted April 12, 2015 So I did the ho to renix swap in my 88 4.0 comanche, I used a 92 xj laredo as a donor, I swapped all of the interior (dash, gauge cluster, etc.) I also used all of the interior wiring from the cherokee, as well as the engine wiring harness. I followed the chart for the renix to ho splicing, and I turned my truck over today, it turned over just fine, but I did not hear the fuel pump running. I have not checked to see if the tail lights work yet, can anyone help me out? Is there a ground wire somewhere I could have missed? Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 13, 2015 Share Posted April 13, 2015 The fuel pump and tail lamps ground behind the left tail lamp. Did you disconnect it? Link to comment Share on other sites More sharing options...
Futurecomancheowner Posted April 14, 2015 Share Posted April 14, 2015 That would be it. Thanks! Link to comment Share on other sites More sharing options...
kc91987 Posted November 29, 2016 Share Posted November 29, 2016 boilermaker I know you had said you were going to do a 96 to renix. I'm trying to find the wire colors for the dash harness from a 96 xj ho to connect to rear harness on a renix mj. There are 13 wires to black plug and 10 wires to gray plug. Any help or a point in the right direction is appreciated. Thanks Link to comment Share on other sites More sharing options...
AeroNautical Posted February 10, 2018 Share Posted February 10, 2018 On 11/17/2012 at 12:05 AM, Lee21490 said: Spent hours figuring this out, Figure i'd post it here so no one has to mess with it like i did. If you do a HO Full dash / STEERING COLUMN swap like i did, Instead of running the brake lights to the 11 pin flat connector in the first post.. The brake lights go to Pin 14 (empty pin) On the multi-function/Turn signal/Hazard switch. Expand I'm trying to figure out exactly where this connector is, it's not on the column as far as I can see. I did swap a 93 tilt column in, along with the same HO harness. Link to comment Share on other sites More sharing options...
