waggy Posted November 19, 2009 Share Posted November 19, 2009 does anyone have the length of the rear drive shaft for a lwb 4x4 , preferably with a d44 . Link to comment Share on other sites More sharing options...
jimoshel Posted November 19, 2009 Share Posted November 19, 2009 49in,center of Ujoint to center of Ujoint,'89 MJ with D44,Ax15, 4.0L Link to comment Share on other sites More sharing options...
waggy Posted November 19, 2009 Author Share Posted November 19, 2009 cool thanks , thats a normal drive shaft ? stock no lift ? with a slip yoke ? thanks for the info . :cheers: Link to comment Share on other sites More sharing options...
mvusse Posted November 20, 2009 Share Posted November 20, 2009 Going from memory, I believe my stock 4.0/AW4 D35 measures 48". Link to comment Share on other sites More sharing options...
mvusse Posted November 20, 2009 Share Posted November 20, 2009 Just measured the bent and dented one laying in my driveway. 48.25" center to center on the u joint ears. That's off an 87 4.0/auto 4x4 D35. Link to comment Share on other sites More sharing options...
87Warrior Posted November 20, 2009 Share Posted November 20, 2009 This is from a '91, LWB, 4x4, AW4, NP231, D44 rig: The slip yoke is right at 5" When I set this shaft beside the D35 shaft in my truck, it was clearly shorter as it should be since the pinion is longer on the D44. Sorry, I don't want to crawl under my muddy truck to measure! Link to comment Share on other sites More sharing options...
waggy Posted November 20, 2009 Author Share Posted November 20, 2009 thanks guys , i will be running a aw4 with np242 and a d44 with 5-6 in lift .. i don't think there will be any need for fixed yoke , but maybe a CV driveshaft .. Link to comment Share on other sites More sharing options...
Pete M Posted November 20, 2009 Share Posted November 20, 2009 no real need for a CV shaft. these aren't XJs afterall. :D For that combo and lift, I'd run something close to the 49". Hard to say for sure without measuring the truck with its completed setup. Link to comment Share on other sites More sharing options...
pingpong Posted November 20, 2009 Share Posted November 20, 2009 I know when I had a bed on my Truggy my rig had a 53" driveshaft. The rig was a 4.0w/aw4 np231w/sye and 8.8. Link to comment Share on other sites More sharing options...
akamcbird Posted November 20, 2009 Share Posted November 20, 2009 '86 lwb, 2.8l, tf 3speed, np207, d35 = 54" eye to eye Link to comment Share on other sites More sharing options...
jimoshel Posted November 20, 2009 Share Posted November 20, 2009 FOR SALE: Rubber driveshafts, guaranteed to stretch from 47inches to 54inches. Limited supply so order early. No warranty or guarantee, Cash only, No checks.Also reduce 'driveline shock' making life easier on diff's. Link to comment Share on other sites More sharing options...
