so a few more updates ,
got my goferit tre flips welded into the knuckles , got my HD offset tre's ( they are one tonne with stock taper ) threaded inserts and 1.5 od 1/4 wall DOM all welded up . the front axle is almost complete .
been collecting parts for my wvo conversion , got one heated filter assembly put together , i pickled up a pump for hijacking ( aka begging for free wvo from local friendly restaurateurs) as well as a filter setup to pump it directly into my wvo tank .
pulled apart a wj np242 that i have , i have to swap out the output shaft so i can have a speedo ( the wj one is electronic)
ill put in the output from my other np242 .
i have new bearing on the rear 44 carrier and one 44 axleshaft is getting a new bearing and seal .
I found a great deal on e bay for some chev brake lines that will bolt up to the front
good writeup here http://www.universityofjeep.ca/techf.html
finally pulled my RK 4.5 in springs off my old truck as well as my RE trac bar i am going to reuse them but ill have to mod the trac bar to fit . with the high steer and the flip the track bar has to be relocated on the axle .
more to come ..
