jeepaholic Posted November 3, 2009 Share Posted November 3, 2009 My truck died on me in the middle of a mud hole...pulled it out...unplugged and plugged the cps connector and it cranked back up...Ran a little and began skipping like hell and eventually died again...went to unplug/plug again and the wires were so hot they had began to melt...I am thinking I have a ground problem an attribute it to changing transmissions and transmission xmembers...What you guys think? Ever ran into this? Link to comment Share on other sites More sharing options...
pilotblake Posted November 3, 2009 Share Posted November 3, 2009 Holy rubber :bowdown: you have a build thread for that monster? Link to comment Share on other sites More sharing options...
Geonovast Posted November 3, 2009 Share Posted November 3, 2009 Are the CPS wires pinched anywhere? They could also be getting too close to the exhaust, especially since motors like to get fairly hot when revving through mud. Link to comment Share on other sites More sharing options...
89eliminator Posted November 3, 2009 Share Posted November 3, 2009 Are the CPS wires pinched anywhere? They could also be getting too close to the exhaust, especially since motors like to get fairly hot when revving through mud. x2. the wires on my CPS got melted by the exhaust causing the exact same problems your having. Link to comment Share on other sites More sharing options...
sinkrun Posted November 3, 2009 Share Posted November 3, 2009 There was a post awhile back about the tallest manche on the site? I think we found it! Link to comment Share on other sites More sharing options...
cruiser54 Posted November 3, 2009 Share Posted November 3, 2009 Probably is a melted/shorted CPS harness. But, I can't stress enough the need to CLEAN the engine grounds at the dipstick tube bracket and on the driver side firewall. Also make sure the ground strap is tight on the back of the head. By CLEAN, I mean remove the eyelet, scrape the paint off the engine/firewall, and reinstall. When I was service manager at a Jeep dealership from 1980 thru 1992, and thru the introduction of the XJ and MJ, I can't tell you how many weird problems we fixed by cleaning the above mentioned grounds. Link to comment Share on other sites More sharing options...
jeepaholic Posted November 9, 2009 Author Share Posted November 9, 2009 Oh yeah the cps wire is melted for sure..Already put new grounds on the battery and cleaned the ones at the block...Now i gotta get the one at the firewall...I think I am going to add another one or two also just to help..As far as updates on the build i will get some up soon..I have added the winch, bumpers, hydraulic assist steering..Fixing to start on a exo-cage and add on board air.. Link to comment Share on other sites More sharing options...
