New here. Quick question though. I'm planning to piece together a 6 inch lift from scratch for my 86 comanche
right now i know i atleast have to have this stuff
-6.5 in coils
-shocks all the way around
-pitman arm
-I'm doing a soa in the rear so i know i need the perches
am I'm going to need control arms and a trac bar?
Thanks for any answers
Travis
  • Replies 50
your gonna at least need new adjustable control arms, and ideally drop brackets or longarms. you will need a new tracbar, address the swaybar end links, brake lines, stock steering will suck, shocks all the way around...
What you will need totally depends on what kind of lift you do upfront.
For the rear you will need
Perches
shocks
Depending on intended purpose new flex line
Front...
Drop brackets and stock uppers and lowers work great for 6.5" of lift :brows:
Then use a HD trac bar and mount ( I used Re's)
For shocks get some DT 3000's in the 26" expanded. some jks bayonet eliminators
26" long brake lines
This setup will give you perfect caster angle using stock shims. Just remember to limit your up and down travel
Everything has been said above, except: drop the drop pitman arm. With a coil sprung suspension it is not needed, and it will most likely cause problems down the road.
Your drag link and track bar need to be at the same angle. If you use a drop pitman arm, your angle will be different. This will cause bump steer. If your absolutely had to have a drop pitman arm (which you don't) you would have to drop the track bar frame mount down too.
What are your plans for the truck? Mine is strictly a wheeling rig, and works fine with a full set of adj. arms and no drop brackets. I will be going with long arms in the future, but for now it works.
But I don't break 40mph haha.
Build on my truck:
Front:
6.5" RC coils
Adj UCA from RC
Adj LCA from RC
Adj trackbar from RC (not really thrilled with this one...I'd go for something beefier...it's a VERY important part)
Redrilled bracket and extended hardlines for front brakes
RC sway bar dicsos (used once...too much of a pain. I now run without sway bar. Again, not much street time)
Used RE 6" shocks
Rear:
Perches
Prop Valve Rod extension
New rear hardlines (not needed, but watch out when placing the perches on top of the axle...movement of the lines may be required)
Lowered mount for soft to hard brake line.
New U-bolts
If you re-use your shock mount plates, be sure to use both plates on top of the leafs
Measure for custom application shocks.
CHECK YOUR PINION ANGLES!!
Thats about it. It would take more if I wanted to make this thing highway worthy, but I don't. That's why I have a DD capable of towing the MJ.
It all depends on what you expect from the truck.
its goin to be a farm use and a krawler. i have a chevy 1500 that ive already got lifted and such so i don't expect this thing to go over 50.
I'm on a pretty small budget. I didnt want to have to put control arms on it. i just wanted to use coils, track bar and a simple soa in the rear. i know i keep repeating myself. can someone make me a list so i can see the simplest way i can make it work? i don't want to have to buy control arms, and i still don't understand the pitman arm. do i just completely get rid of it?
you need a pitman arm, just keep the stock one on. you NEED a tracbar, shocks, coils. you have to address the control arm situation too. you could go with drop brackets and stock arms but i wouldnt trust the arms on the trail.
see i keep hearing that i need to get a new pitman arm and i didnt know if i did. so the stock one wil work with the lift?
so tomorow when i go to order the parts i need to get...
-coils
-shocks
-track bar
-perches
-and look into control arms or control arm drop kits?
sorry i get really paranoid when doing my own lift stuff :(
why don't you just buy a decent kit?
thats what i would do to. then you know you will be getting all the things you need.
X2... Kit is the way to go.
Rob L.
kinda what i was thinking.... but i don't really wanna pay the 900 bucks for the 6 inch lift from rough country.
has anyone had any experience with the rocky road kit. i know they run about 500-600 dollars i believe
the rocky road kit is NOT a complete kit. you WILL need to buy more things on top of their "bargain" price.
I think that is what I'm going to go with. even though i really don't have the money to be doing it with my 1500 still being paid off. but i guess you gotta go big or go home :roll:
thanks guys. i will talk to one of my friends at my local ORI tomorow and see what the rough country lift runs at the shop. thanks for helping the new guy out so much :wavey:
hmmmm. I'm not real sure. ive only had it for about 2 weeks. its in the process of getting swapped out for a chevy 283 small block v8. so i havent had a lot of time to figure a lot of that stuff out. how would i find out?
