kro10000 Posted September 21, 2009 Share Posted September 21, 2009 Hey guys, this is by far the best auto forum ive found so i hope you can help me out, my brother has a 97 tj with a titan 4.7 stroker. recently he checked the dipstick and found he was... Link to comment Share on other sites More sharing options...
kro10000 Posted September 21, 2009 Author Share Posted September 21, 2009 3.5 quarts low :mad: he has only a slight valve cover leak. no idea where it went, now he has valvetrain noise and when he revs the motor up and lets off, oil smoke comes out the tailpipe, any ideas? Link to comment Share on other sites More sharing options...
Eagle Posted September 22, 2009 Share Posted September 22, 2009 Blue smoke from the tailpipe when you let off the gas usually suggests valve seals/guides. When you close the throttle, the engine is sucking hard and making a lot of vacuum, so it'll try to pull in anything it can from anywhere it can. There's oil in the rocker arm chamber, so if it sucks air around the valve stems, it sucks oil with it. Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 22, 2009 Share Posted September 22, 2009 Check over in the stroker forum, Do a search for Titan w. SilverXJ as the poster. He, as well as a couple of others there AFAIK had similar problems with Titan 4.6 & 4.7 strokers. Or shoot him a PM. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted September 22, 2009 Share Posted September 22, 2009 I too was thinking either valve guides or seals, and piston rings. Soetimes when heads are rebuilt, they don't install new guides, they just knurl tem to take up any slack. It is a half assed way of doing the job, and in my opinion a shoddy way of doing it. If thats the case it could cause more oil to make its way through the valve guide if the valve seals arent that great or are bad... maybe some came loose and worked their way up the stem and are no longer sealing. And if some piston rings broke it could cause the same oil usage problem. I know if it was me with all the power of a stroker, I might want to beat on it a little to show off or whatnot. That could cause rings that arent yet broke in to want to break. I agree more research with those who have experience with them is needed. Link to comment Share on other sites More sharing options...
89eliminator Posted September 22, 2009 Share Posted September 22, 2009 i had the exact same thing going on with my 89 4.0. it was the seals. Link to comment Share on other sites More sharing options...
BlueXJ Posted September 22, 2009 Share Posted September 22, 2009 Do a valve job and replace the seals and it will be fine. Link to comment Share on other sites More sharing options...
glundblad Posted September 22, 2009 Share Posted September 22, 2009 :hijack: As I read this, I mentioned to my wife that I am considering stroking my 4.0 engine. She rolled her eyes and called me a discusting pervert. :dunno: Link to comment Share on other sites More sharing options...
Geonovast Posted September 22, 2009 Share Posted September 22, 2009 Could have told her you wanted to stroke your 6 pack :rotf: Link to comment Share on other sites More sharing options...
kro10000 Posted September 24, 2009 Author Share Posted September 24, 2009 K thanks guys, that was about what I was thinking, just in previous experience (mustang) burnt valve seals meant it was gonna burn some oil pretty much all the time. Anyway were gonna pull the plugs soon and see which cylinders have been infected... I hope this goes to show all that just because they're cheap (titan) doesnt mean they're a good idea... If you don't wanna build it yourself, spend the extra $$$ and get a hesco. I have a suspicion that this ain't gonna be the end of our issues. Link to comment Share on other sites More sharing options...
dakal Posted September 24, 2009 Share Posted September 24, 2009 hqaha Link to comment Share on other sites More sharing options...
