snowboard3r411 Posted September 13, 2009 Posted September 13, 2009 ok so I'm a vivid cherokeeforum user but finally got ahold of a comanche worth picking up. its a 1989 2wd 5spd short bed not sure on the specs yet, cause i have not seen the truck in person yet lol i had my mom pick it up and had some pictures took. I'm picking it up next weekend or so. it has a hp 30 already swapped in i have a 4x4 cheroke for all the rest of the parts. oh ya i got it for $750.00 bucks pretty sure it was a steal but here it is Image Not Found Image Not Found Image Not Found Image Not Found Image Not Found Image Not Found Image Not Found Image Not Found Image Not Found
BlueXJ Posted September 13, 2009 Posted September 13, 2009 Nice!! Keep us up to date on the build up. Great platform to begin the build upon.
Geonovast Posted September 13, 2009 Posted September 13, 2009 Welcome to the forum! Got yourself a decent rig there. I'd check the alignment before you drive it around too much. Whoever swapped the D30 on there didn't center the steering wheel, so there's a good chance they didn't adjust the toe-in either.
snowboard3r411 Posted September 13, 2009 Author Posted September 13, 2009 ya I'm getting rid of the front axle anyway i got a hp 30 non disc to go in i well be redoing the whole front end this is going to be my dd
Geonovast Posted September 13, 2009 Posted September 13, 2009 Gearing all the same? When you put in your non-CAD axle, make sure to use the brakes that are on it. The brakes from your CAD axle won't work.
Mongo Posted September 13, 2009 Posted September 13, 2009 Gearing all the same? When you put in your non-CAD axle, make sure to use the brakes that are on it. The brakes from your CAD axle won't work. Not to be ingnorant, but what is the difference in the brake scheme between a CAD/Non CAD axle? I just never noticed.
JeepinSoldier Posted September 13, 2009 Posted September 13, 2009 Love seeing these trucks come back to life! I like the bucket seats and console.
snowboard3r411 Posted September 13, 2009 Author Posted September 13, 2009 i was wounderin about the break lines to. as far as the intrior the guy i bought it fom started switching everything over to a 97+ style interior and i plan on finishing it that way to.
Geonovast Posted September 14, 2009 Posted September 14, 2009 There's no scheme difference per se, they're still both disc brakes and look the same, but there's several generations of brakes all with minor differences, and you can't swap back and forth, it'll cause problems. I know the exact years, it's been posted before but I don't remember what they are.
snowboard3r411 Posted September 16, 2009 Author Posted September 16, 2009 i love the bucket seats and consol to the guy i bought it from started to swich the interior to 97+ i still have not seen my truck in person lol its still at my moms i need a car dolly lol
snowboard3r411 Posted September 16, 2009 Author Posted September 16, 2009 also can anyone tell me my running gear like trans and motor. its a 1989 2wd 4 banger 5 spd short bed :cheers:
dasbulliwagen Posted September 17, 2009 Posted September 17, 2009 also can anyone tell me my running gear like trans and motor. its a 1989 2wd 4 banger 5 spd short bed :cheers: 2.5 litre 4 cylinder with throttle body fuel injection, AX5 5 speed transmission, although my 1987 came with a 5 speed shift knob and a 4 speed transmission, Dana 35 rear axle ( most likely candidate ) Good luck!
S.S.O. Posted September 17, 2009 Posted September 17, 2009 you should have 4.10s in it if you have a 4cyl
snowboard3r411 Posted September 18, 2009 Author Posted September 18, 2009 i want to switch to to a newer 4 bangers i have a 1993 wrangler with the 5 spd and np231 its going to be my donar can anyone help me on the swap. with the motor well the computer work from my manche with the multiport injuction?
dasbulliwagen Posted September 20, 2009 Posted September 20, 2009 Your existing computer and harness will not work with the MPI 2.5. You will need the entire engine wiring harness, computer and probably even the dash harness, You may want to search some different forum classifieds for the correct harness From an MPI 2.5 XJ and get it all so you can easilly swap everything over. I'm not sure if the MPI was ever used in the later MJ's otherwise that would work too. Good luck.. you may want to repost this in the tech section as well to get a better response.
Pete M Posted September 21, 2009 Posted September 21, 2009 you might want to put your tech questions in the tech forum so more people will see it. :thumbsup:
snowboard3r411 Posted October 22, 2009 Author Posted October 22, 2009 so i should have this at my house on sat lol i still have yet to see it in person lol i can't wate. my buddy is towing it back for me on the way back from denver :banana:
snowboard3r411 Posted October 25, 2009 Author Posted October 25, 2009 so i got the truck today it runs great. I'm excited about this truck but no porwer streering is it easy to do the swap any info on this would be good i have a 93 4 banger ax-15 np231 donar for this project. and has power steering how easy would it be to swap it in :cheers:
snowboard3r411 Posted November 23, 2009 Author Posted November 23, 2009 so here's an up date pictures coing soon. i took the flairs off and i swaped in the power steering pump from the 2 door and got it working i used 1/2" spacers to make the pullys line up. i swaped in a non disco hp 30 on the front. next is the ax-15 np231 swap. :cheers:
Pete M Posted November 23, 2009 Posted November 23, 2009 The AX-15 wasn't offered behind 4bangers. It's an AX-5. baby brother to the AX-15. :thumbsup:
snowboard3r411 Posted November 23, 2009 Author Posted November 23, 2009 so here's an up date pictures coing soon. i took the flairs off and i swaped in the power steering pump from the 2 door and got it working i used 1/2" spacers to make the pullys line up. i swaped in a non disco hp 30 on the front. next is the ax-15 np231 swap. :cheers: you sure its coming out of a 92 wrangler i was pretty sure its a ax-15 never even herd of a ax-5
Pete M Posted November 24, 2009 Posted November 24, 2009 The AX-4 and AX-5 were found behind 2.5L engines (and also the 2.8L and 2.1Ls). The AX-15 is found behind 4.0L engines (89.5 - 99). The 2 engines do not share bolt patterns. There are 2 ways to mate an AX-15 to a 2.5L, the first is a complicated process using a bellhousing from a 4banger Dakota (which had AX-15s behind their 4bangers) and the other is with an aftermarket bellhousing.
