stonehands Posted August 8, 2009 Share Posted August 8, 2009 A lot of guys have done a lot of things for a stroker. Looking for oppinions and facts. What combination of the 4.0L engine line will give the most reliable gains in HP and TQ? Stock items:(from any year-make) Block= Head= Intake= Injectors= Headers= Ignition control=(unless a buyout is needed) Crank=(258)right Con. Rods=(258)right Anything missing? Buyout items: Cam= Anything missng? This is for a 1987 Comanche Metric Ton 4x4 auto. Must be as bolt in as possible. If not please list mods needed. Blueprinting and balancing is an after thought. I was thinking of a Megaquirt in this any comments appreciated. Thanks, Stonehands Link to comment Share on other sites More sharing options...
Geonovast Posted August 8, 2009 Share Posted August 8, 2009 While you can probably get some good info on here, you may also want to check out http://www.jeepstrokers.com/forum/ Link to comment Share on other sites More sharing options...
87Warrior Posted August 8, 2009 Share Posted August 8, 2009 When I was looking at doing the same thing, I found this: 4.0 Block Mid 90's 4.0 Head 99+ 4.0 Intake The 21 (or is it 24) lb mustang injectors Ignition, pre 2000 4.0, with adjustable fuel pressure regulator Header.... probably 2 piece later model 4.0 for reduced cracking Pre 1987 258 Crank, Had more weights providing more torque 258 rods I had a hard time finding pistons for my 4.0 rebuild, went through Jeep *edit* Cam was going to be the Mopar performance cam I never got to build it, just did a rebuild. Next time though.... Link to comment Share on other sites More sharing options...
Geonovast Posted August 8, 2009 Share Posted August 8, 2009 Summit racing has stock and overbore pistons for the 4.0 Link to comment Share on other sites More sharing options...
jpnjim Posted August 8, 2009 Share Posted August 8, 2009 I never built one, but here's my opinion: A lot of guys have done a lot of things for a stroker. Looking for oppinions and facts. What combination of the 4.0L engine line will give the most reliable gains in HP and TQ? Stock items:(from any year-make) Block= 87-90 Renix supposed to be stronger, 96+ has HVN improvements & girdle Head= 1991-1995 my 1st choice 1996-1999 2nd choice, 99.5+'s may have cracking issues Intake= WJ style (2000.5+?) Injectors= depends on how you build it/cam Headers= stock is good, Borla knock off probably better, you also have the duel out cast iron option, tho I've never seen any HP comparisons Ignition control=(unless a buyout is needed) Renix if you want the knock sensor, 91-95 if you want simplicity, Megasquirt if you want to build your own Crank=(258)right there's atleast 3 versions: heavyweight/light weight/lightweight w/ factory serpentine belt. I put a serpentine type aside for simplicity, but many like the strength of the heavyweight Con. Rods=(258)right I like 4.0L rods better (stronger/lighter), but require custom pistons Anything missing? Pistons/quench/compression ratio Buyout items: Cam= Depends on FI type & use Anything missng? bored TB This is for a 1987 Comanche Metric Ton 4x4 auto. Must be as bolt in as possible. If not please list mods needed. Blueprinting and balancing is an after thought. I was thinking of a Megaquirt in this any comments appreciated. Thanks, Stonehands Link to comment Share on other sites More sharing options...
dakal Posted August 9, 2009 Share Posted August 9, 2009 megasquit is work but totally tunable Link to comment Share on other sites More sharing options...
james750 Posted August 9, 2009 Share Posted August 9, 2009 Are you doing just a stroker, or are you boring out the block as well? Just a big bore will give you about the same results as just a stroker kit would, so both boring out the motor and stroking it would definitely be the best for torque and HP gain because you would get the most displacement out of the engine. Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 9, 2009 Share Posted August 9, 2009 Here's a good place to start: http://www.angelfire.com/my/fan/stroker.html Link to comment Share on other sites More sharing options...
Darren Posted August 9, 2009 Share Posted August 9, 2009 Good link. Thanks Don. Link to comment Share on other sites More sharing options...
