cocco78 Posted May 31, 2009 Share Posted May 31, 2009 do they make an a/c bypass pulley for an 88 4.0L? What does it look like? I bought one off ebay that was listed for an 88 cherokee 4.0L and it looks to attach like the newer ones with the 4 bolts, like 91 and newer. Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 31, 2009 Share Posted May 31, 2009 Can't you just pull the A/C compressor and get a new shorter belt for a 4.0 Renix w/o air conditioning and route it appropriately? Like you say, the only A/C delete bracket and pulley assemblies I've seen are for the 91 and up HO 4.0 engines. Link to comment Share on other sites More sharing options...
BLHTAZ Posted June 1, 2009 Share Posted June 1, 2009 Can't you just pull the A/C compressor and get a new shorter belt for a 4.0 Renix w/o air conditioning and route it appropriately? Like you say, the only A/C delete bracket and pulley assemblies I've seen are for the 91 and up HO 4.0 engines. I haven't looked it up in the dealer parts, but I am pretty sure this is correct...they are all for '91+. Link to comment Share on other sites More sharing options...
cocco78 Posted June 1, 2009 Author Share Posted June 1, 2009 Yeah only thing was I just bought a new goodyear gatorback belt a couple months ago... I was just thinking if I could get a a pulley I could reuse my belt, oh well. Anyone have a link to the non a/c belt routing? Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 1, 2009 Share Posted June 1, 2009 http://jeepgarage.free.fr/OWN/drive%20belt%20routing.pdf Link to comment Share on other sites More sharing options...
Eagle Posted June 1, 2009 Share Posted June 1, 2009 http://jeepgarage.free.fr/OWN/drive%20belt%20routing.pdf ^^^ Page 17. The 4.0L uses an idler pulley to replace the a/c compressor. Link to comment Share on other sites More sharing options...
mjtjnj Posted June 1, 2009 Share Posted June 1, 2009 Not to hijack, but I was just thinking of this today with my 87 2.5L. When I had the engine out last year, I replaced the radiator and condenser, though I knew the compressor is probably shot, just in case I'd want to get it going someday. So now the compressor clutch bearing is getting noisy, and I don't want it to seize and snap my belt. Can the bearing be changed on-vehicle? Should I just find another used compressor? I don't care if it works right now, but I guess if I'm going to swap it out, maybe I should find a good used one....thoughts? Is there an idler pulley on old 2.5s? I wouldn't mind bypassing it for now, either. Tom Link to comment Share on other sites More sharing options...
Mongo Posted June 1, 2009 Share Posted June 1, 2009 I bought my "87 " 4.0 L without A/C, the bracket part number for this is [5300 2904 BRACKET, Idler Pulley Mounting - w/o Air Conditioning]. It has an additional idler pulley. Sorry, I don't have a picture hosting site, so I can't post one for you. Doubtful that you could find one in the bone yard, chrysler has it listed for $61 Link to comment Share on other sites More sharing options...
redneck23ms Posted June 1, 2009 Share Posted June 1, 2009 my 87 has the a/c delete bracket and pulley on it. i can take a picture of it if you need me to Link to comment Share on other sites More sharing options...
BJA814 Posted June 1, 2009 Share Posted June 1, 2009 I'll have a whole assembly available in a week or so. Let me know. From a 1988 4.0l w/o AC Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 1, 2009 Share Posted June 1, 2009 Sure does Eagle, Figure 18. What about pulling the guts out of the compressor clutch then reassembling? Doable? Either that or start hittin' the yards for an A/C-less 4.0 idler bracket and pulley. Link to comment Share on other sites More sharing options...
mvusse Posted June 1, 2009 Share Posted June 1, 2009 Instead of putting the stock idler pulley there, move the alternator to that spot and run a 77" belt. The stock location for the alternator is one of the worst designs I have ever seen. I'm still kicking myself for not doing it sooner. Link to comment Share on other sites More sharing options...
johnnyc Posted June 1, 2009 Share Posted June 1, 2009 I have a Renix A/C delete pulley and bracket available. $30 shipped. It probably needs a new bearing, but they cost about $3 at any parts store. I find these in the junkyards every now and then. 90% of them have been for 87-90 Renix engines. I've only ever seen one that was for an HO. Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted June 1, 2009 Share Posted June 1, 2009 Last I checked the bypass pulley is NLA from the dealer. They used to be worth their weight in gold for guys wanting to do the conversion and not having to "fix" the ac pump. Within the last 2 years aftermarket support has stepped up and you can now buy them new for about $25. eBay Link Link to comment Share on other sites More sharing options...
BJA814 Posted June 1, 2009 Share Posted June 1, 2009 Last I checked the bypass pulley is NLA from the dealer. They used to be worth their weight in gold for guys wanting to do the conversion and not having to "fix" the ac pump. Within the last 2 years aftermarket support has stepped up and you can now buy them new for about $25. eBay Link Looks like the one for a HO to me :dunno: Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 1, 2009 Share Posted June 1, 2009 It is. :cheers: I've never seen a Renix aftermarket A/C delete pulley/bracket assembly except the factory unit. Link to comment Share on other sites More sharing options...
wood walker95 Posted January 7, 2023 Share Posted January 7, 2023 Looking for a ac delete assembly for 1990 Comanche 4.0 Link to comment Share on other sites More sharing options...
