mknherhappy Posted April 17, 2009 Share Posted April 17, 2009 Prior to painting or rhino lining, which is a better cleaner, Acetone or Denatured Alcohol? Or is there a better cleaner? Thanks again. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted April 17, 2009 Share Posted April 17, 2009 Mineral spirits, or laquer thinner is the only things Ive ever used. Cheap and you can get them anywhere. good luck! Link to comment Share on other sites More sharing options...
jtdesigns Posted April 17, 2009 Share Posted April 17, 2009 Wax and grease remover from the paint store. But its about the same thing as lighter fluid so I use that when I need to.. Link to comment Share on other sites More sharing options...
MrSimon Posted April 17, 2009 Share Posted April 17, 2009 x2 on the wax and grease remover. Spray it on, let it sit for a few minutes, and wipe it off while its still wet. Link to comment Share on other sites More sharing options...
jbhill Posted April 17, 2009 Share Posted April 17, 2009 denatured alocohol to answer the OP's question. Link to comment Share on other sites More sharing options...
mfpdm Posted April 17, 2009 Share Posted April 17, 2009 Or is there a better cleaner? Mineral spirits, or laquer thinner is the only things Ive ever used. Cheap and you can get them anywhere. good luck! :agree: That's after a good scrubbing with purple power to get rid of any grease or grease residue. :thumbsup: :cheers: Link to comment Share on other sites More sharing options...
flint54 Posted April 18, 2009 Share Posted April 18, 2009 Choice of solvents best if you know what you're removing. Otherwise, the multi-pronged approach recommended, starting with the least agressive. Mechanical (brush) and water, then a good alkaline cleaner (marine clean, tri-sodium phosphate, etc), then a fast evaporating solvent (I prefer acetone or IPA rather than the oily residue mineral spirits or turpentine), followed by acid etch (if needed) then very hot water and warm air to dry. Best test of "really clean" is a water-break test where pure water sheets (rather than beads) on the surface. This well tell you how well the surface will participate in adhesion. Link to comment Share on other sites More sharing options...
brdhntr Posted April 18, 2009 Share Posted April 18, 2009 i use dawn dishsoap and hot water to strip the wax and oils from the surface. then i follow with acetone. it's true that you can tell if you've removed the oils and wax by running water over the surface. if the water "sheets" off, you removed everything. if there is any beading, you need to redo everything. if you want to scuff the surface, use a stiff brush or (better) steel wool to scrub the surface with the dawn. this kills 2 birds with 1 stone. it's quick, cheap, and easy. :thumbsup: Link to comment Share on other sites More sharing options...
mvusse Posted April 18, 2009 Share Posted April 18, 2009 I have always used the thinner/reducer recommended for the paint I was spraying. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted April 19, 2009 Share Posted April 19, 2009 i use dawn dish-soap and hot water to strip the wax and oils from the surface. then i follow with acetone. it's true that you can tell if you've removed the oils and wax by running water over the surface. if the water "sheets" off, you removed everything. if there is any beading, you need to redo everything. if you want to scuff the surface, use a stiff brush or (better) steel wool to scrub the surface with the dawn. this kills 2 birds with 1 stone. it's quick, cheap, and easy. :thumbsup: I also did it this way, only I used "scotch brite" pads instead of the steel wool!! GREAT MINDS think alike!! :yes: :shake: :rotf: :rotf: CW Link to comment Share on other sites More sharing options...
mvusse Posted April 19, 2009 Share Posted April 19, 2009 I used the scotch brite pads, or 330 grit paper on an orbital sander. Link to comment Share on other sites More sharing options...
jtdesigns Posted April 19, 2009 Share Posted April 19, 2009 don't sand anything that has grease and dirt in. It will put deeper scratches in the paint and the grease/oils will get embedded into the paint deeper. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted April 19, 2009 Share Posted April 19, 2009 don't sand anything that has grease and dirt in. It will put deeper scratches in the paint and the grease/oils will get embedded into the paint deeper. Your correct, if your prepping for a paint job... But for my preping it before a hurculiner install.. so scratches are like war wounds...not a problem at all!! :yes: :eek: :D CW Link to comment Share on other sites More sharing options...
jtdesigns Posted April 19, 2009 Share Posted April 19, 2009 don't sand anything that has grease and dirt in. It will put deeper scratches in the paint and the grease/oils will get embedded into the paint deeper. Your correct, if your prepping for a paint job... But for my preping it before a hurculiner install.. so scratches are like war wounds...not a problem at all!! :yes: :eek: :D CW Oh yeah rhino liner isnt going show any scratches.. Link to comment Share on other sites More sharing options...
Comanche County Posted April 20, 2009 Share Posted April 20, 2009 I'm a supervisor in an industrial paint shop. We go through thousands of gallons of two part polyurethane paint a week. It's kinda like rhino liner. I'm still not an expert in coatings, but my advise is to find out whether the product your using bonds physically or chemically. Polyurethanes will bond chemically to themselves, you can recoat prior to full cure. But they bond physically to the substrate. The best way to get most paints to adhere is to prep the surface correctly, usually blasting to create an aggressive profile and good depth. Think micro sized Rocky Mountains, not micro Appalachians. It needs a jagged surface to stick to. There are a lot of good cleaners out there, MEK is about as good as it gets, but has high VOCs. You can clean it perfectly, but if the substrate is smooth as a baby's bottom the paint will eventually come off, or get knocked off. Clean is important, but the blast profile is equally or more important! If they tell you they can paint they truck without blasting, I would be suspicious. If there's no blast, prepare to be ripped off, especially if they are applying over an existing coating. Specific procedures are product dependent. Just follow the manufacturer's recommended prep procedures which are usually found on the product data sheet. Most are available on the manufacturer's website. Link to comment Share on other sites More sharing options...
