Luvtohunt Posted April 4, 2009 Share Posted April 4, 2009 Just had a light on my dashboard light up, looked it up and it stated that I needed to change my Oxygen Sensor at 82,000 miles. Can anyone tell me where this is located? Is it something I can do myself? If so, how much and where can I buy one? Thank you very much for your help. Link to comment Share on other sites More sharing options...
Geonovast Posted April 4, 2009 Share Posted April 4, 2009 It's either in the pipe between the exhaust manifold and cat, or in the exhaust manifold. I can't remember if Renix ones were in the manifold or not. Very easy to change, unplug, take the old one out with either an O2 sensor socket, or I just used a wrench. Once it was broke free it was finger loose. Last time I heard a price on them, they were ~ $30-$40 Link to comment Share on other sites More sharing options...
Wildman Posted April 4, 2009 Share Posted April 4, 2009 There mounted on the base of the exhaust manifold, just below the EGR tube. When you get a replacement, make sure you get the 3 wire (Heated) O2 sensor. And the price is closer to $50 for them now :shake: Also, after you replace it, your "Check Engine" lite might still stay lit. You need to remove the Emission Maintenance Timer, mounted on the dash, right of the steering column, you can just unplug it and leave it there, or remove it, and don't bother replacing it, if you can even find one. It only has one purpose, to tell you to replace the O2 sensor, at 82,500 miles :roll: Link to comment Share on other sites More sharing options...
Luvtohunt Posted April 5, 2009 Author Share Posted April 5, 2009 There mounted on the base of the exhaust manifold, just below the EGR tube. When you get a replacement, make sure you get the 3 wire (Heated) O2 sensor. And the price is closer to $50 for them now :shake: Also, after you replace it, your "Check Engine" lite might still stay lit. You need to remove the Emission Maintenance Timer, mounted on the dash, right of the steering column, you can just unplug it and leave it there, or remove it, and don't bother replacing it, if you can even find one. It only has one purpose, to tell you to replace the O2 sensor, at 82,500 miles :roll: Any chance to get a picture of this, or a sight that shows it? Thanks again. Link to comment Share on other sites More sharing options...
ren Posted April 5, 2009 Share Posted April 5, 2009 It is a brown see through box with gears in it, attached to the knee board that makes up the bottom of the dash. It is on the backside of the 'board between the steering column and the ashtray. Link to comment Share on other sites More sharing options...
BLHTAZ Posted April 5, 2009 Share Posted April 5, 2009 The o2 sensor can be a little tough to get to, but not terrible. When I changed mine, I reached up in there with a 1/2" drive ratchet and broke the ceramic housing of the old one off, cut the wires off and left nothing but the nut still in the pipe which made it real easy to get a regular socket on it to remove. The new one is easy to put back in with just a wrench. Link to comment Share on other sites More sharing options...
Wildman Posted April 5, 2009 Share Posted April 5, 2009 There mounted on the base of the exhaust manifold, just below the EGR tube. When you get a replacement, make sure you get the 3 wire (Heated) O2 sensor. And the price is closer to $50 for them now :shake: Also, after you replace it, your "Check Engine" lite might still stay lit. You need to remove the Emission Maintenance Timer, mounted on the dash, right of the steering column, you can just unplug it and leave it there, or remove it, and don't bother replacing it, if you can even find one. It only has one purpose, to tell you to replace the O2 sensor, at 82,500 miles :roll: Any chance to get a picture of this, or a sight that shows it? Thanks again. For the O2 sensor?? And for all Renix sensors-Renix sensors For the EMT- Link to comment Share on other sites More sharing options...
WahooSteeler Posted April 5, 2009 Share Posted April 5, 2009 This just helped explain what one of the unattached plugs under my dash is for, because the timer box is definitely not there. Link to comment Share on other sites More sharing options...
maddzz1 Posted April 6, 2009 Share Posted April 6, 2009 here's one for $20 http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0101443650 Link to comment Share on other sites More sharing options...
jtdesigns Posted April 6, 2009 Share Posted April 6, 2009 here's one for $20 http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0101443650 Nice find!! I just got me one! Link to comment Share on other sites More sharing options...
Luvtohunt Posted April 19, 2009 Author Share Posted April 19, 2009 here's one for $20 http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0101443650 Nice find!! I just got me one! Bought that one also, unfortunately the plug was different, didn't pay any attention until I was ready to plug the new one in. My factory one had a female plug, and the replacement one came with a male plug. Looks like a trip into the parts store......waste of time. Link to comment Share on other sites More sharing options...
Wildman Posted April 21, 2009 Share Posted April 21, 2009 here's one for $20 http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0101443650 Nice find!! I just got me one! Bought that one also, unfortunately the plug was different, didn't pay any attention until I was ready to plug the new one in. My factory one had a female plug, and the replacement one came with a male plug. Looks like a trip into the parts store......waste of time. And, another reason NOT to buy parts on e-bay :roll: Don't feel bad, I've been duked before too :fs1: Link to comment Share on other sites More sharing options...
