onebigmj Posted April 1, 2009 Share Posted April 1, 2009 Sold my old truck and bought this 91 2wd metric ton of my friend who decided to go back to a cherokee. He paid $1500 for the truck, did a complete tune up, 4 new speakers, cd player, and included an ax15,np 231, dual diaphram brake booster,new clutch master cylinder and slave cylinder for $1600. The only pics I have of it are from a jeep ride I decided to take it on for some reason. There is only one verysmall spot of of rust on the driverside rocker. The floors are great too. It runs and drives great, everything on it works and its inspected. This is a first for me. Future plans include. 4wd 5speed swap Wagoneer 44 front 7.5in T&T longarm kit. 4.88 gears and Lockers Bumpers sliders armor blah blah blah. Link to comment Share on other sites More sharing options...
DirtyComanche Posted April 1, 2009 Share Posted April 1, 2009 Cool. Virtually rust free is always a bonus! Don't bother with a LP waggy D44, narrow down a ford HP D44 to waggy width... It's well worth it, IMHO. Link to comment Share on other sites More sharing options...
Pete M Posted April 1, 2009 Share Posted April 1, 2009 And make sure you take the proper steps to keep it rust free. Pull up that carpet and be sure to clean behind the rear wheel wells religiously. :thumbsup: Link to comment Share on other sites More sharing options...
Darren Posted April 2, 2009 Share Posted April 2, 2009 Future plans include. 4wd 5speed swap Wagoneer 44 front 7.5in T&T longarm kit. 4.88 gears and Lockers Bumpers sliders armor blah blah blah. Sounds just like my build Link to comment Share on other sites More sharing options...
onebigmj Posted April 3, 2009 Author Share Posted April 3, 2009 Future plans include. 4wd 5speed swap Wagoneer 44 front 7.5in T&T longarm kit. 4.88 gears and Lockers Bumpers sliders armor blah blah blah. Sounds just like my build Ya. I figured its time to build one right instead of just drolling over yours. Link to comment Share on other sites More sharing options...
Darren Posted April 4, 2009 Share Posted April 4, 2009 ..............instead of just drolling over yours. Thanks, I'm blushing. ;) Link to comment Share on other sites More sharing options...
onebigmj Posted April 5, 2009 Author Share Posted April 5, 2009 Changed my plans for the axles. Picked up a HP 44 and 9in out of a fs bronco for $200. Link to comment Share on other sites More sharing options...
camjeep3 Posted April 5, 2009 Share Posted April 5, 2009 nice. Link to comment Share on other sites More sharing options...
Pete M Posted April 5, 2009 Share Posted April 5, 2009 Going with the radius arms? :brows: Link to comment Share on other sites More sharing options...
onebigmj Posted April 5, 2009 Author Share Posted April 5, 2009 It did come with the radius arms but I think I'm still gonna do the longarms. I don't think the radius arm setup will work well with the amount of lift I'm doing. Link to comment Share on other sites More sharing options...
DirtyComanche Posted April 6, 2009 Share Posted April 6, 2009 What year is the axle? Things got tricky in 78 and later... Although, if you use ford radius arms ultimately that's the same as most 'long arm' setups. Link to comment Share on other sites More sharing options...
Pete M Posted April 6, 2009 Share Posted April 6, 2009 As Dirty said, that might be a challenge if the 44 has the cast-in mounts. Not impossible, but a challenge. How much lift are we talking? I'm at5 or 6 with the Ford arms and they are about level to the ground (just like in a stock 78 Bronco). Link to comment Share on other sites More sharing options...
onebigmj Posted April 6, 2009 Author Share Posted April 6, 2009 78 or 79. Not sure which. Has the cast mounts so its gonna be a pita. I'm going with about 7.5in of lift. Link to comment Share on other sites More sharing options...
Pete M Posted April 6, 2009 Share Posted April 6, 2009 Shouldn't be a problem to do radius arms depending on where you put the mounts on the body. Even though I hate them, there are aftermarket poly C-bushings out there that will rotate the axle back 7 or 10 degrees to accommodate lifts in the broncos. I bought a set during the buildup, but it turned out I didn't need them. But I ran them long enough to realize they don't allow much flex. I won't eat up your build page with pics of my truck, but there are more photos than you cans shake a stick at here: picturetrail.com/petermontie if you want to see what all I did. Link to comment Share on other sites More sharing options...
