My 1989 MJ (Commander Cheese)
Guest
This is my first Jeep and definately not my last. I recently purchased this MJ for $500, its in relatively good condition. Needs a floor but the drivetrain and frame are in great shape. Its a red SporTruck model. manual steering which is being converted to power within the month, its got the 2.5L 4cyl with the AX-4 4speed. Its a great little 2wd truck and will be a Work In Progress for a month atleast before it gets plated. Going to be a great little truck. I will have a few pictures coming soon.
Hah, mine looks exactly like the one in your avatar! Pics as soon as I get around to registering for photo-hosting. Its going to stay 2wd as I need a daily driver that is cheap on insurance (I'm 17)
The name Commander Cheese is just a slight play on Comanche. Coman= Commander, Che= Cheese. My username comes from my name (Rob) and the fact that I am a die-hard MOPAR fan.
My insurance (State Farm) and I had a big go-round when I converted mine. They go by the VIN, not by what's actually under the rig :nuts: IT's both good and bad, tho......good is that the premium is cheaper, but bad if I ever file a claim to get anything replaced driveline-wise. I doubt they'd honor it, but I had them put a letter I wrote in my file saying the truck is 4WD but they refuse to insure it as such because of the VIN.
But, considering it's an almost 20 yr old vehicle, I'll take my chances :D
Jeff
Finally figured out ImageShack!
Here's a quick look-see at my '89 MJ.
It is a bone-stock, no-option truck. Just heat, the radio is shot, bench seat. 2.5L straight 4 and the AX-4 4speed manual. Only 2wd but when I get another $#!&mobile for a DD, Ill dump some cash into my 'manche and maker'er 4x4, a few inches taller and a whole lot beefier with the H.O Straight-6. Anyone ever done slant-6 conversions? I have a 1968 Mopar Slant-6 at my disposal, and might be able to track down the 4speed it has.
When he says 'modding' he means cut the unibody and inner fenders off flush with the front of the cab, and make new frame rails in the front, and bend up some tube to hang the sheetmetal from. While you're at it, he strongly advises chopping the rear off, and again adding more tube, and a full exo cage.
:rotfl2:
ugh, this thing is driving me off the wall :)
Ive gotten it down to a rough $500 to get it roadworthy. Hopefully it will be on the road by September, if not, I'm going to have a fun time biking to work in the snow.
I "roughly" had mine figured to $950. $4000 later...
Mechanic just over from my house says that to have new calipers, rotors, drums, pads/shoes and the split flex line replaced it would come to just over $700. I'm doing it all myself, so its just parts I'll have to pay. And if its half finished by september, Ill toss some old plates on it, drive it to school and finish it up there.
I too have to replace all of the front brake parts (even though I have 2 complete axles to choose from), but I find it much less painful than when I replace other parts. All new brakes are an infinitely good thing. :D
I did all new brakes on mine when I did the axle swap, it's cheap. I bet I've got $200 in brakes and that includes new hardlines on the rear axle and a new rubber line in the rear.
New Calipers, pads, rotors up front
New wheel cylinders, shoes and hardware out back. my drums were good so I reused those.
  • 5 weeks later...
Stuff Still to do:
Steering linkage and joints.
Floor
brake lines
e-brake.
Things Done:
Sheet metal cutouts for the floor
Brake assemblies replaced
Reverse lights working
Still needs small stuff like oil and some antifreeze. Its coming along, slowly but surely. I'm extatic that my reverse lights are working!
my insurance is really cheap (around here) for mine. mine is an 86 4x4 and i am only 19. the price is $60 and it is with drive. they seemed to be the cheapest for basic ins for these things. they were even cheaper for my 2wd elim. might be something to look into.
Alex
Woo!, it needs ball joints....
I found a donor MJ though. A guy my dad works with has one, I6, '88 LWB. I am going to get a good look at it, its been in an accident. I'm going to yank the PS pump, hoses, lines and box from it, if its accutally worth salvaging, I'm going to swap in my old 'Armstrong' steering and get another MJ to myself !
Dual MJs! You're on the path to MJ success.
And at 17 too. I'm hoping the LWB is in decent shape, I'm really hoping. I may do a bit of work and sell the sucker and put some more new parts on my little red MJ. if its not, Parts Truck!
