steering box?
Awesome thank you for the follow up. I considered picking up a Junkyard piece but it will undoubtedly need new seals at the least. Is a rebuild much of a headache? A rebuildt unit from Rock Auto is $107.00. Depending on what a used unit from the yard cost a reseal kit is $20. What you guys think?
Edit: Here is a great video on how to rebuild the gear box.
https://youtu.be/661ov4GIXAA
Unless you know exactly what ratio is installed, stay away from the rebuilt boxes as most of them use the slower 14:1 ratio that you have now. To be sure you get the 12.7:1 ratio use a genuine ZJ yard box with low mileage. I picked one up from a 96 ZJ with 65K on it and it worked fine with no leaks that a can on Lucas stop leak couldn't fix. Hasn't leaked for years and is still tight.
I agree with Hornbrod, I got my steering box out of a 98ZJ this last memorial day weekend for 50%off at the pick a part and made a HUGE difference on my MJ, it gives it a much more modern feel best 30 bucks I've spent on the front suspension so far. :banana:
Ok. I can rebuild a stock box myself, the reason i questioned it was that alot of times I think I am saving money by doing things myself when in reality I could of bought new for not much more money and alot less headache. But if the rebuilt boxes possibly have the slower ratio I can justify a Saturday rebuilding a junkyard box, if it needs it. I need to rebuild my CJ box anyways so it will be good practice as they are probably similar. Thanks for all the input!
I'm just gonna scrounge the yard for a ZJ and inspect the boxes for Leaks.  As long as I don't find one leaking like a siv, I will just clean it up as best I can, flush it, install it, and adjust it until I am satisfied.  My current box has 140,000 miles with no leak and only needed a little bit of adjustment.  If I get something around the same miles and condition, I'm good with it.
Quick question: does the ZJ box give the steering any degree of road feel? Coming from my other car's fancy speed-sensitive rack&pinion setup, the MJ's steering seems pretty antiquated. It's also way too easy to turn the wheel IMO.
Go to a later model pump and you'll reduce the pressure, making it feel more normal.
http://www.cherokeeforum.com/f51/durango-steering-box-upgrade-3805/
There's also a 99~ Dodge Durango steering box. iirc you can also get them with hydro assist.
They bolt right in, Are heavier duty, and Are quicker than the mj/xj steering box, Idr the exact ratio though.
You can also swap in the power steering pump from a v8 grand cherokee, Its NEARLY bolt on.. You have to tap the pump to a larger bolt size, Then drill out the mounting bracket & plug one simple return line. Took me maybe 2 hours.
As far as I've read, the Durango steering boxes are even slower than the stock MJ gear. Great off-road box though.
I went with the ZJ box and an 04 Wrangler pump. To me it's a perfect (and cheap) setup for the road. Feels better than my new JK.
I have one installed in my mj, I can assure you they're quicker (Or at least the year i got mine out of)
I'll try to find what ratio it is, I know they came in a few different ones.
