Bumpstick Posted February 1, 2009 Posted February 1, 2009 My 88 MJ I just bought has that big fuel gauge on the left and the dumby lights. Years ago I had a 88 XJ it had a gauge cluster with the Tach and gauges instead of dumby lights. If I get my hands on a pre-HO gauge cluster with the tach will it plug right up? Would I have to change sending units for the gauges to all work?
chunks6067 Posted February 1, 2009 Posted February 1, 2009 I had to change my temp sending unit and oil pressure sending unit not expensive at all but keep in mind i think some pre HO year gauges were not all compatible so be sure to check some of the topics that have covered it my gauges are part digital with the speedo cable attached manual
88 Beast Posted February 1, 2009 Posted February 1, 2009 I did this swap a few weeks ago. It bolts right in if you have a floor shifted truck. Mine is a column shift auto so I needed to cut an opening in the tach face to mount the PRNDL. Careful measurement and it looks factory.As far as I know there were no column shift gauge clusters. Make sure you get the water temp.and oil pressure senders out of the donor vehicle and you get the cluster from an earlier model vehicle as later models had electronic speedos.
Bumpstick Posted February 2, 2009 Author Posted February 2, 2009 Mine is a column shift auto, I wish I had a floor shift. As of right now I don't have a donor vehicle. Just looking for parts that I'll need.
manche Posted February 2, 2009 Posted February 2, 2009 i did my swap and bolts right in and for colum shift its just a little more work before and after
ricksjeepster Posted February 3, 2009 Posted February 3, 2009 Any pics of the water temp. and oil pressure senders? i got the full gauge set but i had no idea about bringing the donor senders :oops: , if someone has some pictures to see what i´ll be looking for when I get back to the jy
Whamm Posted February 3, 2009 Posted February 3, 2009 uI found this on CC somewhere, it has a great writeup and pics. http://www.naxja.org/forum/showthread.php?t=921205 :cheers: Also thanks to whoever posted this link. :D
