maddzz1 Posted January 21, 2009 Share Posted January 21, 2009 I plan on swapping in a 95-96 booster. I know the booster is a direct swap, but is the pedal assemly a direct swap also? Is there anything else I need to grab besides the assembly, brakelight switch, and spacer for switch? Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 21, 2009 Share Posted January 21, 2009 Don't forget the brake light switch bracket and the alum spacer behind the booster. :cheers: Link to comment Share on other sites More sharing options...
mjeff87 Posted January 21, 2009 Share Posted January 21, 2009 grab the spacer, but you may not need it (I didn't use it and don't have any problems). You'll have to splice your brakelight wires into the new switch.....there's 6 wires on the new switch but you only need two of them, the pink and the white ones. Doesn't matter which way you splice them into the two wires in the harness, it's only a contact switch that closes and makes continuity. Jeff Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 21, 2009 Share Posted January 21, 2009 I needed the spacer on my 91 to get the booster rod length aligned correctly with the brake pedal stud. But I also retained my original pedal assembly so that probably was the difference. Link to comment Share on other sites More sharing options...
robfg67 Posted January 21, 2009 Share Posted January 21, 2009 Jim, where did you get your boster/master? I've been looking for a set-up from a '99-'04 Grand Cherokee with no luck. Just not many of these rigs in JY's yet. Link to comment Share on other sites More sharing options...
Windowsrookie Posted January 21, 2009 Share Posted January 21, 2009 Jim, where did you get your boster/master? I've been looking for a set-up from a '99-'04 Grand Cherokee with no luck. Just not many of these rigs in JY's yet. 1995-1996 XJ's booster, master cylinder, and pedal assembly will bolt right up. Link to comment Share on other sites More sharing options...
88 Beast Posted January 23, 2009 Share Posted January 23, 2009 I planning on doing the same, just haven't been able to find a donor at JY. I thought I read somewhere the brake switch also controls something with the AW4? T/C lockup or something. Is this correct? If so any info on wiring it up. Thanks. Link to comment Share on other sites More sharing options...
mfpdm Posted January 23, 2009 Share Posted January 23, 2009 I've put the 96 booster in with the 96 brake pedal. The brake switch is not my biggest problem. It's the cruise control switch that I haven't seen anyone address. The 89 XJ that I got it out of has a bracket on the brake pedal for it but the 96 does not. Did the 96's use a different method for the cruise control switch? :dunno: :cheers: Link to comment Share on other sites More sharing options...
jtdesigns Posted January 23, 2009 Share Posted January 23, 2009 The spacer is pretty easy to make. here's the dimensions,,, Link to comment Share on other sites More sharing options...
mjeff87 Posted January 23, 2009 Share Posted January 23, 2009 I've put the 96 booster in with the 96 brake pedal. The brake switch is not my biggest problem. It's the cruise control switch that I haven't seen anyone address. The 89 XJ that I got it out of has a bracket on the brake pedal for it but the 96 does not. Did the 96's use a different method for the cruise control switch? :dunno: :cheers: I'm assuming that's what at least some of the other four wires are for on the 96 switch :dunno: ....I don't have cruise so I just cut them off on mine. Link to comment Share on other sites More sharing options...
