did they make one or am i gona have have one cut? the slider in my mj is broke(center glass)and i am just curious if it was an option.
The glass may be discontinued from the factory, but I'd be very surprised if none of the aftermarket suppliers can come up with it. If not, though, it's flat so you can have a glass shop cut one for you. Many years ago I had th replace all the side glass in a 1939 Hudson coupe because the laminate layer had gotten all yellowed and crazed. Naturally, nobody had stock glass for a 30-year old Hudson, but the local glass shop made 'em up on the spot. The laminated glass they can cut -- tempered they can't. I suppose the rear windows today are tempered, but I don't see a big problem with using laminated.
Check with one of your local autoglass shops, they should have one or be able to get it. I checked this out a couple of weeks ago at Speedy and they carry both the replacement window and the slider IIRC :yes: .
i plan on getting the glass company we use at work to get me one cut. now are the seals the same for the slider and solid?
