robfg67 Posted January 11, 2009 Posted January 11, 2009 I know that nothing is a given from the factory, but what gears should this one have? http://burlington.craigslist.org/cto/987458923.html
garmj Posted January 11, 2009 Posted January 11, 2009 My 1990 2.5 Manual has 4:10 gears from what I have seen its pretty common.
summerinmaine Posted January 11, 2009 Posted January 11, 2009 My 1990 2.5 Manual has 4:10 gears from what I have seen its pretty common. Where does it say it's a manual? I must have missed that.
robfg67 Posted January 12, 2009 Author Posted January 12, 2009 Yeah, it doesn't list the transmission in the ad. If this baby has 4.10's, I'll drive the 5 hours to pick her up.
Eagle Posted January 12, 2009 Posted January 12, 2009 I dunno what they used for the base tranny in 1990. I have an 86 2.5L 4-speed and an 88 2.5L 4-speed that both have 3.55 gears. 4.10s were with the 5-speed.
BookspanS Posted January 12, 2009 Posted January 12, 2009 If you get it, can I buy the nose bra from you if you don't want it?
robfg67 Posted January 12, 2009 Author Posted January 12, 2009 Good eye on that! It's yours if I get it.
mfpdm Posted January 12, 2009 Posted January 12, 2009 I dunno what they used for the base tranny in 1990. I have an 86 2.5L 4-speed and an 88 2.5L 4-speed that both have 3.55 gears. 4.10s were with the 5-speed. I got jipped then. The 87 I'm parting out had the 2.5 w/5spd but has a 3.55 rear. Did they differ from 2wd and 4wd? :dunno:
Pete M Posted January 12, 2009 Posted January 12, 2009 Not that we know of. I guess that then the trans could have been swapped in. It's a direct swap for the 4-speed.
shelbyluvv Posted January 12, 2009 Posted January 12, 2009 In the rare case that it is an auto it should have 4:56s. AX-5 normally 4:10s AX-4 normally 3:55s
