camjeep3 Posted January 1, 2009 Share Posted January 1, 2009 ok talk to me. pros cons everything and can i reverse this in the future with a new actual locker and gears? convince me why i shouldnt take the welder to my d30 :nuts: Link to comment Share on other sites More sharing options...
Darren Posted January 1, 2009 Share Posted January 1, 2009 If you ever drive it on the street, I wouldn't do it. And on the trail you will have a very hard time turning in high traction situations. But It can be reversed if you get a real locker. Link to comment Share on other sites More sharing options...
camjeep3 Posted January 1, 2009 Author Share Posted January 1, 2009 so i will still feel it in the front in 2wd? Link to comment Share on other sites More sharing options...
Pete M Posted January 1, 2009 Share Posted January 1, 2009 I have a minispool in the front of my 88 (ford axle with hubs) and I love the straight-line traction, but hate it the rest of the time. I've had bind so bad that I couldn't turn the wheel. And that was on muddy trails. It was absolutely dreadful at times in Moab. I'm replacing with a lunchbox locker so it will at least unlock when I shift into 2wd. I went with the minispool because I have hubs I can unlock for the street. Link to comment Share on other sites More sharing options...
camjeep3 Posted January 1, 2009 Author Share Posted January 1, 2009 so this is def not worth it for me becasue i like to drive my truck on the street. aussie locker? opinions Link to comment Share on other sites More sharing options...
smartazz19 Posted January 1, 2009 Share Posted January 1, 2009 i had an aussie locker (detroit EZ locker) in the front of my old XJ, worked fine on the street, i could hardly ever tell it was there until i hit a parking lot, a bit noisy around sharp turns, but some thicker gear dope quiets it down. Off road it was amazing and wouldnt trade it for anything. Never weld a front axle if you don't have manual hubs (or a disconnect font axle). Its just dangerous and you can't turn corners. Link to comment Share on other sites More sharing options...
DirtyComanche Posted January 1, 2009 Share Posted January 1, 2009 I drove with a full spool and drive flanges on the street. Stupid, yes. Dangerous, not really. You have perfect control at anything over about 15km/h, unless you're on snow/ice which is a little harry. Your tires will hate you, however. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted January 1, 2009 Share Posted January 1, 2009 i had an aussie locker (detroit EZ locker) in the front of my old XJ, worked fine on the street, i could hardly ever tell it was there until i hit a parking lot, a bit noisy around sharp turns, but some thicker gear dope quiets it down. Off road it was amazing and wouldnt trade it for anything. Never weld a front axle if you don't have manual hubs (or a disconnect font axle). Its just dangerous and you can't turn corners. Smart man with good advice!! :D :yes: DO NOT RUN A SPOOL in the front on the street! (Welding is in effect the same this as having a spool) I have run a aussie for years in the front and its all but uinvisable. Even in corners mine is fairly quiet, with the raido on you don't even hear it. With the top off yes you can hear it, but its never a problem. CW Link to comment Share on other sites More sharing options...
mvusse Posted January 1, 2009 Share Posted January 1, 2009 If you have a disconnect axle you can do it. If you don't have a disconnect axle, see any of the messages above. Link to comment Share on other sites More sharing options...
Pete M Posted January 1, 2009 Share Posted January 1, 2009 If the axle still has a disconnect, that means it's still running the puny 260 U-joints and that's pretty much a reason unto itself to avoid a spool. :yes: Unless he got some shafts from a 95 YJ. Rumor has it those ones came with 297s. :drool: Link to comment Share on other sites More sharing options...
