project88mj Posted December 30, 2008 Share Posted December 30, 2008 its on a cherokee? Link to comment Share on other sites More sharing options...
Boilermaker Posted December 30, 2008 Share Posted December 30, 2008 No. Link to comment Share on other sites More sharing options...
Motion Offroad Posted December 30, 2008 Share Posted December 30, 2008 Thats an 8.25" Link to comment Share on other sites More sharing options...
tazjeeper Posted December 30, 2008 Share Posted December 30, 2008 looks like a D20 if ya ask me. Link to comment Share on other sites More sharing options...
shelbyluvv Posted December 30, 2008 Share Posted December 30, 2008 Motion Offroad said: Thats an 8.25" :agree: Link to comment Share on other sites More sharing options...
gogetemturbo Posted December 31, 2008 Share Posted December 31, 2008 That is definitely an 8.25 Link to comment Share on other sites More sharing options...
BLHTAZ Posted December 31, 2008 Share Posted December 31, 2008 tazjeeper said: looks like a D20 if ya ask me. :hmm: I think you mean an M20... ;) There is no such thing as a D20. The Model 20 is perfectly round and the one in that pic is definitely oblong and is an 8.25 :thumbsup: Link to comment Share on other sites More sharing options...
Motion Offroad Posted December 31, 2008 Share Posted December 31, 2008 tazjeeper said: looks like a D20 if ya ask me. A Dana 20 is a transfer case. If your talking about an AMC 20 (axle) it's similar but not quite the same. The XJ's only had the D35, D44, and Chrysler 8.25" (all in a few different varieties). Link to comment Share on other sites More sharing options...
Pete M Posted December 31, 2008 Share Posted December 31, 2008 My almighty M-20. :D Link to comment Share on other sites More sharing options...
tazjeeper Posted December 31, 2008 Share Posted December 31, 2008 Pete M said: My almighty M-20. :D yep thats what I was thinking and yes I see the diff now and the diff between. lol :popcorn: So to answer NO not a D44 Link to comment Share on other sites More sharing options...
mvusse Posted December 31, 2008 Share Posted December 31, 2008 So whereabouts does the 8.25 rate between the D35, D44, Ford 8.8 and AMC 20? Link to comment Share on other sites More sharing options...
Pete M Posted December 31, 2008 Share Posted December 31, 2008 27 spline versions are a bit above the Dana 35. 29 spline versions are a bit below the Dana 44. I would rate the MJ version of the M-20 just a bit below the MJ/XJ Dana 44. Link to comment Share on other sites More sharing options...
project88mj Posted December 31, 2008 Author Share Posted December 31, 2008 i found this on a cherokee and noticed it looked different than the d35 would it be worth the 175.00 they want for it? what are some differences between the d35 and 8.25? :dunno: (i've never heard of it) Link to comment Share on other sites More sharing options...
Motion Offroad Posted December 31, 2008 Share Posted December 31, 2008 Depends on if it's a 27 spline or a 29 spline. If it's a 29 spline than that's a decent price for it. Link to comment Share on other sites More sharing options...
project88mj Posted December 31, 2008 Author Share Posted December 31, 2008 any way too tell what it is? Link to comment Share on other sites More sharing options...
tazjeeper Posted December 31, 2008 Share Posted December 31, 2008 project88mj said: i found this on a cherokee and noticed it looked different than the d35 would it be worth the 175.00 they want for it? what are some differences between the d35 and 8.25? :dunno: (i've never heard of it) :smart: so what year is the cherokee? :smart: Link to comment Share on other sites More sharing options...
smartazz19 Posted December 31, 2008 Share Posted December 31, 2008 project88mj said: any way too tell what it is? If its under a 96 or below its a 27-spline. (1996 was a crossover year so some have 29-splines it the plant ran out of the 27s, but uncommon) If its under a 1997-2001 its a 29-spline. Link to comment Share on other sites More sharing options...
project88mj Posted January 1, 2009 Author Share Posted January 1, 2009 okay i need to go check on that any luck on you guys knowing the gear ratios they came with? Link to comment Share on other sites More sharing options...
1990 Pioneer 4x4 Posted January 1, 2009 Share Posted January 1, 2009 Boilermaker said: No. From looking at the illustration, it appears that the D44 lowers your ground clearance a few inches over the D35…? Link to comment Share on other sites More sharing options...
smartazz19 Posted January 1, 2009 Share Posted January 1, 2009 3.07s if its a 6-cyl manual 3.55s if its a 6-cyl auto (most likely the combo) 4.10s ifs its a 4-popper. project88mj said: okay i need to go check on that any luck on you guys knowing the gear ratios they came with? Link to comment Share on other sites More sharing options...
project88mj Posted January 2, 2009 Author Share Posted January 2, 2009 smartazz19 said: 3.07s if its a 6-cyl manual3.55s if its a 6-cyl auto (most likely the combo) 4.10s ifs its a 4-popper. project88mj said: okay i need to go check on that any luck on you guys knowing the gear ratios they came with? what does that meen? Link to comment Share on other sites More sharing options...
mvusse Posted January 2, 2009 Share Posted January 2, 2009 4 cylinder engine means it would have 4.10 ratio gears. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted January 2, 2009 Share Posted January 2, 2009 1990 Pioneer 4x4 said: From looking at the illustration, it appears that the D44 lowers your ground clearance a few inches over the D35…? does it really even matter? a dana 35 is junk in every way shape and form. smartazz19 said: 3.07s if its a 6-cyl manual3.55s if its a 6-cyl auto (most likely the combo) 4.10s ifs its a 4-popper. the 4.0 5 speed definitely is 3.07's the auto could also have 3.73's if it's got a tow package. that's only a possibility, no guarantee. the 4 cylinder gears vary ALOT. 4 cyl 5 speed = 3.55, 3,73, 4.10 gears as available choice. 4 cyl 4 speed = 3.55 4 cyl auto = 3.73, 4.10, 4.56 with 4.10 or 4.56 being more likely. a 87-88 xj with aw4 auto guaranteed has 4.56 gears. it is the only guarantee with them other than the 4 cyl 4 speed with an 8.25 if it is a 4 cylinder it will more than likely have 3.55 gears, and same goes for a 4.0 equipped jeep. Link to comment Share on other sites More sharing options...
project88mj Posted January 2, 2009 Author Share Posted January 2, 2009 cool I'm going back tomarrow to take a look and find out more about the jeep by the way no one said if it was worth the swap? d35 to 8.25 Link to comment Share on other sites More sharing options...
Pete M Posted January 2, 2009 Share Posted January 2, 2009 All depends on the gears. A 97+ 8.25 is a much stronger axle and worth swapping if there is no disadvantage in gear ratio. The earlier 8.25s are only a slightly stronger axle. Not really worth swapping unless there is a benefit in gear ratio. Link to comment Share on other sites More sharing options...
