did i find a D44?
i found this on a cherokee and noticed it looked different than the d35
would it be worth the 175.00 they want for it?
what are some differences between the d35 and 8.25? :dunno: (i've never heard of it)
:smart: so what year is the cherokee?
:smart:
3.07s if its a 6-cyl manual
3.55s if its a 6-cyl auto (most likely the combo)
4.10s ifs its a 4-popper.
okay i need to go check on that
any luck on you guys knowing the gear ratios they came with?
what does that meen?
From looking at the illustration, it appears that the D44 lowers your ground clearance a few inches over the D35…?
does it really even matter? a dana 35 is junk in every way shape and form.
the 4.0 5 speed definitely is 3.07's
the auto could also have 3.73's if it's got a tow package. that's only a possibility, no guarantee.
the 4 cylinder gears vary ALOT.
4 cyl 5 speed = 3.55, 3,73, 4.10 gears as available choice.
4 cyl 4 speed = 3.55
4 cyl auto = 3.73, 4.10, 4.56 with 4.10 or 4.56 being more likely. a 87-88 xj with aw4 auto guaranteed has
4.56 gears. it is the only guarantee with them other than the 4 cyl 4 speed
with an 8.25 if it is a 4 cylinder it will more than likely have 3.55 gears, and same goes for a 4.0 equipped jeep.
All depends on the gears. A 97+ 8.25 is a much stronger axle and worth swapping if there is no disadvantage in gear ratio. The earlier 8.25s are only a slightly stronger axle. Not really worth swapping unless there is a benefit in gear ratio.
