vzehler Posted December 26, 2008 Share Posted December 26, 2008 Did any of the older mj's D35 have a metal drain plug? I was looking at mine and noticed it. Just wanted to make sure I know what I'm equipped with. I just always thought that D35's had rubber plugs. If it helps, I have a 1989 Short Box Comance 4x4, 4.0. I am for sure its not a dana 44 Link to comment Share on other sites More sharing options...
HKB3 Posted December 26, 2008 Share Posted December 26, 2008 Metal plug should be a D44 it will look like this; this is what a Dana35 looks like; note the rubber plug Link to comment Share on other sites More sharing options...
mvusse Posted December 26, 2008 Share Posted December 26, 2008 My 87 D35 has a metal plug. Not with the square extrusion like the D44 pictured, but with a square hole for a 3/8 drive ratchet. Just like the D35 shown in the first post. My buddy's 90 XJ has a D35 with the rubber plug. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 26, 2008 Share Posted December 26, 2008 anyone who tells you that dana 35's only had rubber plugs hasn't had enough jeeps apart yet, or has read about the subject from someone else who is flat out wrong anyways. non c-clip dana 35's should all have metal plugs, and I'm sure some of the early c-clip ones do as well. rubber drain plugs came somewhere around 1990. yes, you do have a dana 35. I'm sorry to bear the bad news :ack: Link to comment Share on other sites More sharing options...
Sir Sam Posted December 26, 2008 Share Posted December 26, 2008 JeepcoMJ said: anyone who tells you that dana 35's only had rubber plugs hasn't had enough jeeps apart yet, or has read about the subject from someone else who is flat out wrong anyways. non c-clip dana 35's should all have metal plugs, and I'm sure some of the early c-clip ones do as well. rubber drain plugs came somewhere around 1990. yes, you do have a dana 35. I'm sorry to bear the bad news :ack: 2nd Link to comment Share on other sites More sharing options...
DirtyComanche Posted December 26, 2008 Share Posted December 26, 2008 This comes up often. Too often. So, where the heck does this HORRIBLE tidbit of misinformation come from? Jeepforum? Jeepsunlimited? NAXJA? Somebody tell me - I'll nip it in the butt or get banned trying... Link to comment Share on other sites More sharing options...
HKB3 Posted December 26, 2008 Share Posted December 26, 2008 Sir Sam said: JeepcoMJ said: anyone who tells you that dana 35's only had rubber plugs hasn't had enough jeeps apart yet, or has read about the subject from someone else who is flat out wrong anyways. non c-clip dana 35's should all have metal plugs, and I'm sure some of the early c-clip ones do as well. rubber drain plugs came somewhere around 1990. yes, you do have a dana 35. I'm sorry to bear the bad news :ack: 2nd FWIW I did NOT say that D35s ONLY have rubber plugs, I said if it has a metal plug it SHOULD be a D44. Information you find on the internet is worth what you pay for it....you always have to do a little follow up research. If the OP did a 5 second Google search he would have found the same D44 pics that I found to compare to his D35 pic he posted after I replied to this thread. :wavey: Link to comment Share on other sites More sharing options...
vzehler Posted December 26, 2008 Author Share Posted December 26, 2008 HKB3 said: Sir Sam said: JeepcoMJ said: anyone who tells you that dana 35's only had rubber plugs hasn't had enough jeeps apart yet, or has read about the subject from someone else who is flat out wrong anyways. non c-clip dana 35's should all have metal plugs, and I'm sure some of the early c-clip ones do as well. rubber drain plugs came somewhere around 1990. yes, you do have a dana 35. I'm sorry to bear the bad news :ack: 2nd FWIW I did NOT say that D35s ONLY have rubber plugs, I said if it has a metal plug it SHOULD be a D44. Information you find on the internet is worth what you pay for it....you always have to do a little follow up research. If the OP did a 5 second Google search he would have found the same D44 pics that I found to compare to his D35 pic he posted after I replied to this thread. :wavey: The OP didn't have to google search anything about D44's because I already knew that it wasn't one. Anyways, thanks for clearing up the confusion. I suspected that it was a d35 but I had heard that one easy way to identify them is the rubber plug. Whoever told me that must have either not known themselves or failed to add that some d35's do have metal plugs. Either way, its a piece of $#!&. Link to comment Share on other sites More sharing options...
Eagle Posted December 26, 2008 Share Posted December 26, 2008 HKB3 said: FWIW I did NOT say that D35s ONLY have rubber plugs, I said if it has a metal plug it SHOULD be a D44. That is exactly what you said. And it is not correct. The AMC non c-clip D35s used metal plugs. The Chrysler c-clip D35s used rubber plugs. Link to comment Share on other sites More sharing options...
Geonovast Posted December 26, 2008 Share Posted December 26, 2008 Shouldn't this all just fall back on the "Nothing about Jeep is for sure, because they did whatever the hell they wanted in the factory" rule? Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted December 26, 2008 Share Posted December 26, 2008 Geonovast said: Shouldn't this all just fall back on the "Nothing about Jeep is for sure, because they did whatever the hell they wanted in the factory" rule? Yes. Link to comment Share on other sites More sharing options...
tazjeeper Posted December 26, 2008 Share Posted December 26, 2008 Thats right nothing in the jeep world is a sure thing. I have a 89 and a 90 mj both with a d44 dearend and they both have the metal plug that you put the 3/8 ratchet in, unlike the d44 in the pick that someone posted. that plug is an outie not an inie.............. Link to comment Share on other sites More sharing options...
DirtyComanche Posted December 28, 2008 Share Posted December 28, 2008 tazjeeper said: Thats right nothing in the jeep world is a sure thing. I have a 89 and a 90 mj both with a d44 dearend and they both have the metal plug that you put the 3/8 ratchet in, unlike the d44 in the pick that someone posted. that plug is an outie not an inie.............. I don't think the 'outie' plugs are very common. I rarely ever see them. Of course, you must realize, I have an internal hexing plug in one of mine. No, it's not factory, since all you need is the correct sized NPT plug which you can source in just about any style. Anyways, what I actually wanted to say is that LOTS of specifics to jeeps are actually fairly consistant save the occasional deviant. However, given that the vehicles in question have probably had 20 years of hit-or-miss maintenace and the potential for being modified, you will run into different things. Bottom line - identifying an axle based on the PLUG is freaking stupid. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 28, 2008 Share Posted December 28, 2008 DirtyComanche said: Bottom line - identifying an axle based on the PLUG is freaking stupid. :clapping: could not have said it better. Link to comment Share on other sites More sharing options...
tazjeeper Posted December 28, 2008 Share Posted December 28, 2008 Quote I don't think the 'outie' plugs are very common. I rarely ever see them. Of course, you must realize, I have an internal hexing plug in one of mine. No, it's not factory, since all you need is the correct sized NPT plug which you can source in just about any style. Anyways, what I actually wanted to say is that LOTS of specifics to jeeps are actually fairly consistant save the occasional deviant. However, given that the vehicles in question have probably had 20 years of hit-or-miss maintenace and the potential for being modified, you will run into different things. Bottom line - identifying an axle based on the PLUG is freaking stupid. :clapping: :rotf: :rotf: :clapping: :rotf: :rotf: :clapping: :rotf: :rotf: :banana: :rotf: :rotf: :rotf: Link to comment Share on other sites More sharing options...
